[嵌入式linux]
Freeing init memory: 172K 启动卡在这里执行不下去
1158|1
jackyid|  楼主 | 2018-7-13 10:26 | 显示全部楼层 |阅读模式
U-Boot 1.3.3 (Jul 25 2012 - 13:36:07)
I2C:   ready
DRAM:  64 MB
In:    serial
Out:   serial
Err:   serial
ARM Clock : 300000000 Hz
EEPROM @ 0x50 read FAILED!!!
Ethernet switch start failed!
More than one PHY detected.
Hit any key to stop autoboot:  0
8192 KiB W25Q64 at 0:0 is now current device
## Booting kernel from Legacy Image at c0700000 ...
   Image Name:   Linux-2.6.18_pro500-da830_omapl1
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1689208 Bytes =  1.6 MB
   Load Address: c0008000
   Entry Point:  c0008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux................................................................................................................. done, booting the kernel.
Linux version 2.6.18_pro500-da830_omapl137_evm-arm_v5t_le (root@PPC_440.localdomain) (gcc 版本 4.2.0 20070126 (prerelease) (MontaVista 4.2.0-3.0.0.0702771 2007-03-10)) #1 PREEMPT Wed Aug 1 09:29:51 CST 2012
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
Machine: DaVinci DA8XX EVM
Memory policy: ECC disabled, Data cache writethrough
DA830 variant 0x9
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
CPU0: D cache: 16384 bytes, associativity 4, 32 byte lines, 128 sets
Built 1 zonelists.  Total pages: 8192
Kernel command line: mem=32M console=ttyS2,115200n8 ip=192.168.0.187:192.168.0.1::255.255.255.0 noinitrd root=/dev/mtdblock4 rw rootfstype=yaffs2 rw
PID hash table entries: 256 (order: 8, 1024 bytes)
Clock event device timer0_0 configured with caps set: 07
Console: colour dummy device 80x30
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 32MB = 32MB total
Memory: 28748KB available (2892K code, 601K data, 172K init)
Security Framework v1.0.0 initialized
Capability LSM initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
DaVinci: 128 gpio irqs
Generic PHY: Registered new driver
NET: Registered protocol family 2
IP route cache hash table entries: 256 (order: -2, 1024 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 1024 bind 512)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
squashfs: version 3.1 (2006/08/19) Phillip Lougher
JFFS version 1.0, (C) 1999, 2000  Axis Communications AB
JFFS2 version 2.2. (NAND) (SUMMARY)  (C) 2001-2006 Red Hat, Inc.
yaffs Aug  1 2012 09:40:20 Installing.
SGI XFS with no debug enabled
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
LTT : ltt-facilities init
LTT : ltt-facility-core init in kernel
DAVINCI-WDT: DaVinci Watchdog Timer: heartbeat 3 sec
Serial: 8250/16550 driver $Revision: 1.90 $ 3 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO map 0x1c42000 mem 0xfec42000 (irq = 25) is a 16550A
serial8250.0: ttyS1 at MMIO map 0x1c20400 mem 0xfed0c000 (irq = 53) is a 16550A
serial8250.0: ttyS2 at MMIO map 0x1d0d000 mem 0xfed0d000 (irq = 61) is a 16550A
RAMDISK driver initialized: 1 RAM disks of 32768K size 1024 blocksize
Davinci EMAC MII Bus: probed
MAC address is 02:00:10:00:00:00
TI DaVinci EMAC Linux version updated 4.0
i2c /dev entries driver
nand_davinci nand_davinci.0: Using 4-bit hardware ECC
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron NAND 512MiB 3,3V 8-bit)
Creating 5 MTD partitions on "nand_davinci.0":
0x00000000-0x00020000 : "bootloader"
0x00020000-0x00040000 : "params"
0x00040000-0x00240000 : "kernel"
0x00240000-0x00440000 : "filesystem0"
0x00440000-0x20000000 : "filesystem1"
nand_davinci nand_davinci.0: hardware revision: 2.5
Creating 3 MTD partitions on "Windbond spi nand flash":
0x00000000-0x00040000 : "U-Boot"
0x00040000-0x00044000 : "U-Boot Environment"
0x00044000-0x00800000 : "Linux"
dm_spi.0: davinci SPI Controller driver at 0xc285e000 (irq = 20) use_dma=1
Pin GPIO3_10 already used for UART1_TXD.
dm_spi.1: davinci SPI Controller driver at 0xc286a000 (irq = 56) use_dma=1
mice: PS/2 mouse device common for all mice
rtc-da8xx rtc-da8xx.0: rtc intf: proc
rtc-da8xx rtc-da8xx.0: rtc intf: dev (254:0)
rtc-da8xx rtc-da8xx.0: rtc core: registered rtc-da8xx as rtc0
######### RTC--DA8xx: platform_get_irq=19 pass.
######### RTC--DA8xx:post request_irq ret=0.
######### RTC--DA8xx: request_irq pass.
######### RTC--DA8xx: da8xx_rtc_mmr_unlock pass.
######### RTC--DA8xx: da8xx_rtc_read( pass.
######### RTC--DA8xx: da8xx_rtc_write( pass.
######### RTC--DA8xx: da8xx_rtc_config pass.
######### RTC--DA8xx: da8xx_rtc_start pass.
rtc-da8xx rtc-da8xx.0: TI DA8xx Real Time Clock driver.
Pin MMCSD_DAT_0 already used for EMA_D_0.
Trying to free nonexistent resource <0000000000000011-0000000000000011>
davinci-mmc: probe of davinci-mmc.0 failed with error -16
IPv4 over IPv4 tunneling driver
TCP bic registered
NET: Registered protocol family 17
rtc-da8xx rtc-da8xx.0: setting the system clock to 2000-01-01 00:00:00 (946684800)
Time: timer0_1 clocksource has been installed.
Clock event device timer0_0 configured with caps set: 08
Switched to high resolution mode on CPU 0
IP-Config: Complete:
      device=eth0, addr=192.168.0.187, mask=255.255.255.0, gw=255.255.255.255,
     host=192.168.0.187, domain=, nis-domain=(none),
     bootserver=192.168.0.1, rootserver=192.168.0.1, rootpath=
yaffs: dev is 32505860 name is "mtdblock4"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.4, "mtdblock4"
block 4059 is bad
block 4060 is bad
block 4061 is bad
block 4062 is bad
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs2 filesystem).
jackyid|  楼主 | 2018-7-13 10:27 | 显示全部楼层
OMAP L137系列,  可能是什么问题?
