(转)Z-stack3.0 数据收发
1299|7
guanjiaer|  楼主 | 2018-7-24 09:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以light和switch demo 为例子
1.在light 例子中可以参见profile 属性表注册
  • static zclGeneral_AppCallbacks_t zclSampleLight_CmdCallbacks =
  •   zclSampleLight_BasicResetCB,            // Basic Cluster Reset command
  •   NULL,                                   // Identify Trigger Effect command
  •   zclSampleLight_OnOffCB,                 // On/Off cluster commands
  •   NULL,                                   // On/Off cluster enhanced command Off with Effect
  •   NULL,                                   // On/Off cluster enhanced command On with Recall Global Scene
  •   NULL,                                   // On/Off cluster enhanced command On with Timed Off
  • #ifdef ZCL_LEVEL_CTRL
  •   zclSampleLight_LevelControlMoveToLevelCB, // Level Control Move to Level command
  •   zclSampleLight_LevelControlMoveCB,        // Level Control Move command
  •   zclSampleLight_LevelControlStepCB,        // Level Control Step command
  •   zclSampleLight_LevelControlStopCB,        // Level Control Stop command
  • #endif
  • #ifdef ZCL_GROUPS
  •   NULL,                                   // Group Response commands
  • #endif
  • #ifdef ZCL_SCENES
  •   NULL,                                  // Scene Store Request command
  •   NULL,                                  // Scene Recall Request command
  •   NULL,                                  // Scene Response command
  • #endif
  • #ifdef ZCL_ALARMS
  •   NULL,                                  // Alarm (Response) commands
  • #endif
  • #ifdef SE_UK_EXT
  •   NULL,                                  // Get Event Log command
  •   NULL,                                  // Publish Event Log command
  • #endif
  •   NULL,                                  // RSSI Location command
  •   NULL                                   // RSSI Location Response command
guanjiaer|  楼主 | 2018-7-24 09:11 | 只看该作者
2.在 zclSampleLight_Init()中注册
  • void zclSampleLight_Init( byte task_id )
  •   zclSampleLight_TaskID = task_id;
  •   // Set destination address to indirect
  •   zclSampleLight_DstAddr.addrMode = (afAddrMode_t)AddrNotPresent;
  •   zclSampleLight_DstAddr.endPoint = 0;
  •   zclSampleLight_DstAddr.addr.shortAddr = 0;
  •   // Register the Simple Descriptor for this application
  •   bdb_RegisterSimpleDescriptor( &zclSampleLight_SimpleDesc );
  •   // Register the ZCL General Cluster Library callback functions
  •   zclGeneral_RegisterCmdCallbacks( SAMPLELIGHT_ENDPOINT, &zclSampleLight_CmdCallbacks );
  •   // Register the application's attribute list
  •   zclSampleLight_ResetAttributesToDefaultValues();
  •   zcl_registerAttrList( SAMPLELIGHT_ENDPOINT, zclSampleLight_NumAttributes, zclSampleLight_Attrs );
  •   zclSampleLight_LevelLastLevel = zclSampleLight_LevelCurrentLevel;
  • #endif
  •   // Register the Application to receive the unprocessed Foundation command/response messages
  •   zcl_registerForMsg( zclSampleLight_TaskID );
  • #ifdef ZCL_DISCOVER
  •   // Register the application's command list
  •   zcl_registerCmdList( SAMPLELIGHT_ENDPOINT, zclCmdsArraySize, zclSampleLight_Cmds );
  • #endif
guanjiaer|  楼主 | 2018-7-24 09:12 | 只看该作者
3.数据处理函数
  • uint16 zclSampleSw_event_loop( uint8 task_id, uint16 events )
  •   afIncomingMSGPacket_t *MSGpkt;
  •   (void)task_id;  // Intentionally unreferenced parameter
  •   //Send toggle every 500ms
  •   if( events & SAMPLESW_TOGGLE_TEST_EVT )
  •     osal_start_timerEx(zclSampleSw_TaskID,SAMPLESW_TOGGLE_TEST_EVT,500);
  •     zclGeneral_SendOnOff_CmdToggle( SAMPLESW_ENDPOINT, &zclSampleSw_DstAddr, FALSE, 0 );
  •     // return unprocessed events
  •     return (events ^ SAMPLESW_TOGGLE_TEST_EVT);
  •   if ( events & SYS_EVENT_MSG )
  •     while ( (MSGpkt = (afIncomingMSGPacket_t *)osal_msg_receive( zclSampleSw_TaskID )) )
  •       switch ( MSGpkt->hdr.event )
  •         case ZCL_INCOMING_MSG:
  •           // Incoming ZCL Foundation command/response messages
  •           zclSampleSw_ProcessIncomingMsg( (zclIncomingMsg_t *)MSGpkt );
  •           break;
4.switch 是如何控制light的,在switch中可以找到按键的这个code
  • void zclSampleSw_UiActionToggleLight(uint16 keys)
  •   if (zclSampleSw_OnOffSwitchActions == ON_OFF_SWITCH_ACTIONS_TOGGLE)
  •     if (keys & UI_KEY_SW_5_PRESSED)
  •       zclGeneral_SendOnOff_CmdToggle( SAMPLESW_ENDPOINT, &zclSampleSw_DstAddr, FALSE, bdb_getZCLFrameCounter() );
  •   else if (((keys & UI_KEY_SW_5_PRESSED) && (zclSampleSw_OnOffSwitchActions == ON_OFF_SWITCH_ACTIONS_ON))
  •     || ((keys & UI_KEY_SW_5_RELEASED) && (zclSampleSw_OnOffSwitchActions == ON_OFF_SWITCH_ACTIONS_OFF)))
  •     zclGeneral_SendOnOff_CmdOn( SAMPLESW_ENDPOINT, &zclSampleSw_DstAddr, FALSE, bdb_getZCLFrameCounter() );
  •   else
  •     zclGeneral_SendOnOff_CmdOff( SAMPLESW_ENDPOINT, &zclSampleSw_DstAddr, FALSE, bdb_getZCLFrameCounter() );
配合上light的上profile回调中的on/off属性回调就可以完成switch对light控制。
guanjiaer|  楼主 | 2018-7-24 09:13 | 只看该作者
5.如果发送自己的数据呢
在swicth中使用zcl_SendReportCmd函数
  • * @fn      zcl_SendReportCmd
  • * @brief   Send a Report command
  • * @param   dstAddr - destination address
  • * @param   clusterID - cluster ID
  • * @param   reportCmd - report command to be sent
  • * @param   direction - direction of the command
  • * @param   seqNum - transaction sequence number
  • * @return  ZSuccess if OK
  • ZStatus_t zcl_SendReportCmd( uint8 srcEP, afAddrType_t *dstAddr,
  •                              uint16 clusterID, zclReportCmd_t *reportCmd,
  •                              uint8 direction, uint8 disableDefaultRsp, uint8 seqNum )
  •   uint16 dataLen = 0;
  •   uint8 *buf;
  •   ZStatus_t status;
  •   uint8 i;
  •   // calculate the size of the command
  •   for ( i = 0; i < reportCmd->numAttr; i++ )
  •     zclReport_t *reportRec = &(reportCmd->attrList);
  •     dataLen += 2 + 1; // Attribute ID + data type
  •     // Attribute Data
  •     dataLen += zclGetAttrDataLength( reportRec->dataType, reportRec->attrData );
  •   buf = zcl_mem_alloc( dataLen );
  •   if ( buf != NULL )
  •     // Load the buffer - serially
  •     uint8 *pBuf = buf;
  •       *pBuf++ = LO_UINT16( reportRec->attrID );
  •       *pBuf++ = HI_UINT16( reportRec->attrID );
  •       *pBuf++ = reportRec->dataType;
  •       pBuf = zclSerializeData( reportRec->dataType, reportRec->attrData, pBuf );
  •     status = zcl_SendCommand( srcEP, dstAddr, clusterID, ZCL_CMD_REPORT, FALSE,
  •                               direction, disableDefaultRsp, 0, seqNum, dataLen, buf );
  •     zcl_mem_free( buf );
  •   else
  •     status = ZMemError;
  •   return ( status );
  • #endif
在light中case ZCL_CMD_REPORT: // zclSampleLight_ProcessInReportCmd( pInMsg );中解析
  • static void zclSampleLight_ProcessIncomingMsg( zclIncomingMsg_t *pInMsg )
  •   switch ( pInMsg->zclHdr.commandID )
  • #ifdef ZCL_READ
  •     case ZCL_CMD_READ_RSP:
  •       zclSampleLight_ProcessInReadRspCmd( pInMsg );
  •       break;
  • #endif
  • #ifdef ZCL_WRITE
  •     case ZCL_CMD_WRITE_RSP:
  •       zclSampleLight_ProcessInWriteRspCmd( pInMsg );
  •       break;
  • #endif
  •     case ZCL_CMD_CONFIG_REPORT:
  •     case ZCL_CMD_CONFIG_REPORT_RSP:
  •     case ZCL_CMD_READ_REPORT_CFG:
  •     case ZCL_CMD_READ_REPORT_CFG_RSP:
  •     case ZCL_CMD_REPORT:
  •       //bdb_ProcessIncomingReportingMsg( pInMsg );
  •       break;
  •     case ZCL_CMD_DEFAULT_RSP:
  •       zclSampleLight_ProcessInDefaultRspCmd( pInMsg );
  •       break;
  •     case ZCL_CMD_DISCOVER_CMDS_RECEIVED_RSP:
  •       zclSampleLight_ProcessInDiscCmdsRspCmd( pInMsg );
  •       break;
  •     case ZCL_CMD_DISCOVER_CMDS_GEN_RSP:
  •       break;
  •     case ZCL_CMD_DISCOVER_ATTRS_RSP:
  •       zclSampleLight_ProcessInDiscAttrsRspCmd( pInMsg );
  •       break;
  •     case ZCL_CMD_DISCOVER_ATTRS_EXT_RSP:
  •       zclSampleLight_ProcessInDiscAttrsExtRspCmd( pInMsg );
  •       break;
  • #endif
  •     default:
  •       break;
  •   if ( pInMsg->attrCmd )
  •     osal_mem_free( pInMsg->attrCmd );
guanjiaer|  楼主 | 2018-7-24 09:14 | 只看该作者
6.举例说明
swicth 发送
  • zclReportCmd_t reportCmd;
  • reportCmd.numAttr = 1;
  • reportCmd.attrList[0].attrID = ATTRID_MS_CMD;
  • reportCmd.attrList[0].dataType = ZCL_DATATYPE_UINT8;
  • reportCmd.attrList[0].attrData = &data;
  • zcl_SendReportCmd(ENDPOINT,
  •          &DstAddr,
  •          ZCL_CLUSTER_ID_LIGHT,
  •           &reportCmd,TRUE,FALSE,TRUE);
light接收:
  • if (pInMsg->clusterId == ZCL_CLUSTER_ID_LIGHT)
  •   rpt_cmd= (zclReportCmd_t *)pInMsg->attrCmd;;
wowu| | 2018-7-24 13:18 | 只看该作者
请问 demo在哪里下载
dirtwillfly| | 2018-7-24 20:26 | 只看该作者
wowu 发表于 2018-7-24 13:18
请问 demo在哪里下载
你用的哪个无线mcu?不同的mcu会不同
楼住贴的这个在官网提供的协议栈里就有
http://www.ti.com.cn/tool/cn/z-stack
