[STM32F1] 波形出不来
991|15
 楼主| songqian17 发表于 2018-7-26 22:52 | 显示全部楼层 |阅读模式
TI, IO, ST, pi, ni
GPIO_Configuration();
NVIC_Configuration4();
  TIM4_Configuration();
TIM_ClearFlag(TIM4, TIM_FLAG_Update);
  TIM_ARRPreloadConfig(TIM4, DISABLE);
  TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE);
        TIM_SelectOutputTrigger(TIM4,TIM_TRGOSource_Update);
  TIM_Cmd(TIM4, ENABLE);
main(1)
void NVIC_Configuration4(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void TIM4_Configuration(void)
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
        TIM_DeInit(TIM4);
  TIM_TimeBaseStructure.TIM_Period = (10-1); //100K
  TIM_TimeBaseStructure.TIM_Prescaler = (60-1);
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
        /* Output Compare Active Mode configuration: Channel1 */
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; //PWM??2
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //??????
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;//??????
TIM_OCInitStructure.TIM_Pulse = 5; //????
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //????
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High; //??????
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;TIM_OC1Init(TIM2,&TIM_OCInitStructure); //??1
TIM_OC3Init(TIM4, &TIM_OCInitStructure); //??TIM_OCInitStruct???????????TIMx
TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable); //??TIMx?CCR3????????
TIM_ARRPreloadConfig(TIM4, ENABLE); //??TIMx?ARR????????
/* TIM4 enable counter */
TIM_Cmd(TIM4, ENABLE); //??TIMx??
        TIM_CtrlPWMOutputs(TIM4, ENABLE);
void GPIO_Configuration(void)
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA|RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOC, ENABLE);
//PB
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; //
         GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//GPIO_Mode_Out_PP;//;
        GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;
        //GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
void TIM4_IRQHandler(void)
        /*if (TIM_GetITStatus(TIM4, TIM_IT_CC2) != RESET)
TIM_ClearITPendingBit(TIM4, TIM_IT_CC2);
TIM_SetCompare2(TIM4, TIM_GetCapture2(TIM4) + 5);
        if(TIM_GetITStatus(TIM4, TIM_IT_Update))            //????update????
        TIM_ClearITPendingBit(TIM4, TIM_IT_Update);     //??update??????
                        test_TIM4++;
        flag_time=1;}
这是原程序,怎么波形就出不来呢?
jlyuan 发表于 2018-7-26 22:55 | 显示全部楼层
我用的不是F2,希望可以有人帮你解决。。。
 楼主| songqian17 发表于 2018-7-26 22:58 | 显示全部楼层
我的系统里面怎么就没有TIM_HandleTypeDef这个结构体呢?
gongche 发表于 2018-7-26 23:00 | 显示全部楼层
//TIM4CH3应该是PD14,哥们你是不是没有配置这个引脚,配置的时候需要配置为复用引脚,楼下是我的
        GPIO_PinAFConfig(GPIOE, GPIO_PinSource9, GPIO_AF_TIM1);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOE,&GPIO_InitStructure);
huwr 发表于 2018-7-26 23:01 | 显示全部楼层
楼上正解,相应引脚要配置为复用功能
huanghuac 发表于 2018-7-26 23:03 | 显示全部楼层
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN; 换成 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
tian111 发表于 2018-7-26 23:05 | 显示全部楼层
你没有输出PWM吧,所以测不到
zhuhuis 发表于 2018-7-26 23:07 | 显示全部楼层
PD14的复用功能是不是没有配置
wenfen 发表于 2018-7-26 23:08 | 显示全部楼层
能够进定时器中断吗?
guanjiaer 发表于 2018-7-27 08:20 | 显示全部楼层
地板说的很有道理 需要配置相关io口
一路向北lm 发表于 2018-7-27 08:26 | 显示全部楼层
PWM波吗?参考原子或者火哥的,一看就懂
站在巨人的肩膀上。
萧洛毫 发表于 2018-7-27 10:26 | 显示全部楼层
使用官方的cubemx直接生成定时器的代码就好了,直接可以使用。
android2 发表于 2018-7-27 17:24 | 显示全部楼层
需要配置相关io口
happy_10 发表于 2018-7-28 08:05 | 显示全部楼层
 楼主| songqian17 发表于 2018-7-28 08:06 | 显示全部楼层
好的,我明天去单位试一下,多谢各位大侠了哈,结贴了先
