[STM32F4]
(转)STM32F407上移植emwin
3530|11
xiaoqizi|  楼主 | 2018-7-28 10:59 | 显示全部楼层 |阅读模式
本文博客链接:http://blog.csdn.net/jdh99,作者:jdh
环境:
主机:WIN8
开发环境:MDK5.13
emwin版本:STemWinLibrary522
mcu: stm32f407VGT6
开发板:安富莱STM32-X3
TFT型号:艾蓝2.8寸TFT,主控芯片:ILI9325
说明:
在STM32F407上移植emwin,驱动屏幕接口为FSMC
移植步骤:
1.MDK新建文件结构:
2.GUIConf.c文件修改
    a)增加宏定义:
  • #define GUI_NUMBYTES  (1024 * 80)
  • #define GUI_BLOCKSIZE 0x80
  b)GUI_X_Config(void)函数中增加语句:
GUI_ALLOC_SetAvBlockSize(GUI_BLOCKSIZE);
   修改后:
[cpp] view plain copy
  • <code class="language-cpp">/*********************************************************************
  • *       GUI_X_Config
  • * Purpose:
  • *   Called during the initialization process in order to set up the
  • *   available memory for the GUI.
  • void GUI_X_Config(void) {
  •   // 32 bit aligned memory area
  •   static U32 aMemory[GUI_NUMBYTES / 4];
  •   // Assign memory to emWin
  •   GUI_ALLOC_AssignMemory(aMemory, GUI_NUMBYTES);
  •     GUI_ALLOC_SetAvBlockSize(GUI_BLOCKSIZE);
  •   // Set default font
  •   GUI_SetDefaultFont(GUI_FONT_6X8);
  • }</code>
3.LCDConf_FlexColor_Template.c文件修改
    a)增加宏定义:
  • #define LCD_REG_ADDRESS                   BANK1_LCD_REG
  • #define LCD_DATA_ADDRESS                  BANK1_LCD_RAM
      这两个BANK宏定义在tft驱动文件中定义:
  • #define BANK1_BASE                ((uint32_t)(0x60000000 | 0x00000000))
  • #define BANK1_LCD_RAM        *(__IO uint16_t *)(BANK1_BASE +  (1 << (18 + 1)))        /* FSMC 16位总线模式下,FSMC_A18口线对应物理地址A19 */
  • #define BANK1_LCD_REG        *(__IO uint16_t *)(BANK1_BASE)
       具体值和接线相关
     b)具体函数修改
  • *       Local functions
  • *       LcdWriteReg
  • * Function description:
  • *   Sets display register
  • static void LcdWriteReg(U16 Data) {
  •   // ... TBD by user
  •         LCD_REG_ADDRESS = Data;
  • *       LcdWriteData
  • *   Writes a value to a display register
  • static void LcdWriteData(U16 Data) {
  •         LCD_DATA_ADDRESS=Data;
  • *       LcdWriteDataMultiple
  • *   Writes multiple values to a display register.
  • static void LcdWriteDataMultiple(U16 * pData, int NumItems) {
  •   while (NumItems--) {
  •           LCD_DATA_ADDRESS=*pData++;
  • *       LcdReadDataMultiple
  • *   Reads multiple values from a display register.
  • static void LcdReadDataMultiple(U16 * pData, int NumItems) {
  •           *pData++=LCD_DATA_ADDRESS;
  • *       Public functions
  • *       LCD_X_Config
  • *   display driver configuration.
  • void LCD_X_Config(void) {
  •   GUI_DEVICE * pDevice;
  •   CONFIG_FLEXCOLOR Config = {0};
  •   GUI_PORT_API PortAPI = {0};
  •   // Set display driver and color conversion
  •   pDevice = GUI_DEVICE_CreateAndLink(GUIDRV_FLEXCOLOR, GUICC_565, 0, 0);
  •   // Display driver configuration, required for Lin-driver
  •   LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
  •   LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
  •   // Orientation
  •   //Config.Orientation = GUI_SWAP_XY | GUI_MIRROR_Y;
  •   Config.FirstCOM = 0;
  •   Config.FirstSEG = 0;
  •   //Config.Orientation = GUI_MIRROR_X | GUI_MIRROR_Y;
  •   Config.NumDummyReads = 2;
  •   GUIDRV_FlexColor_Config(pDevice, &Config);
  •   // Set controller and operation mode
  •   PortAPI.pfWrite16_A0  = LcdWriteReg;
  •   PortAPI.pfWrite16_A1  = LcdWriteData;
  •   PortAPI.pfWriteM16_A1 = LcdWriteDataMultiple;
  •   PortAPI.pfReadM16_A1  = LcdReadDataMultiple;
  •   GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66708, GUIDRV_FLEXCOLOR_M16C0B16);
  •         //GUIDRV_FlexColor_SetFunc(pDevice, &PortAPI, GUIDRV_FLEXCOLOR_F66709, GUIDRV_FLEXCOLOR_M16C0B16);
      其中:GUIDRV_FlexColor_SetFunc函数说明:
       因为主控芯片为ILI9325,所以参数选择GUIDRV_FLEXCOLOR_F66708
4.GUI_X.c文件修改
      此文件控制的是GUI中的延时,可以用定时器配合实现,修改如下:
  • *       Global data
  • volatile GUI_TIMER_TIME OS_TimeMS;
  • *      Timing:
  • *                 GUI_X_GetTime()
  • *                 GUI_X_Delay(int)
  •   Some timing dependent routines require a GetTime
  •   and delay function. Default time unit (tick), normally is
  •   1 ms.
  • extern __IO int32_t g_iRunTime;
  • GUI_TIMER_TIME GUI_X_GetTime(void) {
  •   //return OS_TimeMS;
  •         return g_iRunTime;
  • void GUI_X_Delay(int ms) {
  • //  int tEnd = OS_TimeMS + ms;
  • //  while ((tEnd - OS_TimeMS) > 0);
  •         int tEnd = g_iRunTime + ms;
  •         while ((tEnd - g_iRunTime) > 0);
5.主函数实现:
  • int main(void)
  •                 ST固件库中的启动文件已经执行了 SystemInit() 函数,该函数在 system_stm32f4xx.c 文件,主要功能是
  •         配置CPU系统的时钟,内部Flash访问时序,配置FSMC用于外部SRAM
  •         bsp_Init();                /* 硬件初始化 */
  •         Printf**();        /* 打印例程信息到串口1 */
  •         vLCDInit();
  • //        vClearScreen(Green);
  • //        vSetTextColor(Red);
  • //        vPutString(20,0, "NanJing RF Tracking!!!!!");
  • //        ShowImage();
  •         //DemoFatFS();        /* SD卡文件系统演示程序 */
  •         //RCC_AHBPeriphClockCmd(RCC_AHBPeriph_CRC, ENABLE);
  •         RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_CRC, ENABLE);
  •     GUI_Init();
  •     GUI_DispString("I am jdh!");
  •         while (1)
  •                 GUI_Delay(1000);
注意:
函数是必须的,否则GUI将不工作,这是ST公司防止其他芯片用此GUI的措施。
效果:
参考资料:
1.STemWin5.22移植笔记
2.《野火emwin实战指南V1.0.0》
3.安富莱源程序:x3开发板_裸机STemWin5.20
stm32jy| | 2018-7-28 12:01 | 显示全部楼层
GUI就用emwin
huangcunxiake| | 2018-7-28 20:43 | 显示全部楼层
多谢分享
wahahaheihei| | 2018-7-28 22:05 | 显示全部楼层
666
mmuuss586| | 2018-7-29 10:40 | 显示全部楼层
感谢分享;
huahuagg| | 2018-7-29 14:31 | 显示全部楼层
我试试能否移植我的板子上。
xiaoqizi|  楼主 | 2018-8-4 09:20 | 显示全部楼层
huahuagg 发表于 2018-7-29 14:31
我试试能否移植我的板子上。
欢迎尝试 呵呵呵
paotangsan| | 2018-8-4 10:46 | 显示全部楼层
emwin,我也不知道是干嘛用的 自己平时都是直接生成代码
labasi| | 2018-8-4 10:54 | 显示全部楼层
emWin图形库由德国SEGGER公司开发,可为图形LCD设计提供高级支持,极大简化了LCD设计并缩短上市时间。为恩智浦ARM微控制器用户免费提供的emWin图形库,以其免费提供商业图库、使用简单、提升MCU运行表现和色彩逼真
paotangsan| | 2018-8-4 11:11 | 显示全部楼层
感谢楼上的解答
xiaoqizi|  楼主 | 2018-8-6 13:04 | 显示全部楼层
谢谢各位热心网友
wowu| | 2018-8-10 13:06 | 显示全部楼层
这个的通用性还是很好的
