[应用相关]
STM32单片机 配置 PLL锁相环的应用2
3984|20
東南博士|  楼主 | 2018-7-30 15:55 | 显示全部楼层 |阅读模式
//HMC830
#define HMC830_GPIO                        GPIOB
#define HMC830_CSN_PIN                GPIO_Pin_15
#define HMC830_MOSI_PIN                GPIO_Pin_14
#define HMC830_SCK_PIN                GPIO_Pin_13
#define HMC830_MISO_PIN                GPIO_Pin_12
#define HMC830_CSN_H            GPIO_SetBits( HMC830_GPIO, HMC830_CSN_PIN )
#define HMC830_CSN_L                GPIO_ResetBits( HMC830_GPIO, HMC830_CSN_PIN )
#define HMC830_MOSI_H            GPIO_SetBits( HMC830_GPIO, HMC830_MOSI_PIN )
#define HMC830_MOSI_L                GPIO_ResetBits( HMC830_GPIO, HMC830_MOSI_PIN )
#define HMC830_SCK_H            GPIO_SetBits( HMC830_GPIO, HMC830_SCK_PIN )
#define HMC830_SCK_L                GPIO_ResetBits( HMC830_GPIO, HMC830_SCK_PIN )
#define HMC830_MISO_GET()        (HMC830_GPIO->IDR & HMC830_MISO_PIN)
void WR_data(unsigned char Addr,long Data);
unsigned long RD_data(unsigned char Addr);
void HMC830(void);
void HMC829(void);
unsigned char Get_LockStatus(void);
void Init_HMC830(void);
void Init_HMC830_Port(void)
        /* Configure GPIO in output pushpull mode */
        GPIO_InitStructure.GPIO_Pin = HMC830_CSN_PIN | HMC830_SCK_PIN | HMC830_MOSI_PIN ;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
        GPIO_Init( HMC830_GPIO, &GPIO_InitStructure);
        /* Configure GPIO in Input pullup mode */
        GPIO_InitStructure.GPIO_Pin = HMC830_MISO_PIN ;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
void _delay_hmc(unsigned char t)
        unsigned char i;
        for(i = 0; i < t; i++)
        _nop_();
東南博士|  楼主 | 2018-7-30 15:56 | 显示全部楼层
void WR_start()
        HMC830_CSN_L;
        HMC830_MOSI_L;
        HMC830_SCK_L;    //先将三个端口拉低
        _nop_();
        HMC830_CSN_H;
    _nop_();
        HMC830_MOSI_L;
        _nop_();
        HMC830_SCK_H;     /*发送起始信号*/
        _nop_();     /* SCLK to SDI hold time 3ns*/
        HMC830_SCK_L;
        _nop_();     /*SDI to SCLK setup time 3ns*/
void WR_stop()
        HMC830_SCK_L;
        _nop_();
        HMC830_SCK_H;
        HMC830_CSN_L;  /*发送接收条件的数据信号*/
        _nop_();
東南博士|  楼主 | 2018-7-30 15:57 | 显示全部楼层
void WR_data(unsigned char addr,long dat)
        unsigned long dat_temp =0;
        unsigned char dat_index = 0;
        unsigned char addr_index;
        unsigned char addr_temp = 0;
        unsigned char index;
        WR_start();
        addr_temp = addr << 2;
        for( addr_index = 0; addr_index < 6; addr_index++ )
                if((addr_temp<<addr_index)&0x80)
                        HMC830_MOSI_H;
                else
                        HMC830_MOSI_L;
                HMC830_SCK_L;
                _delay_hmc(3);
                HMC830_SCK_H;
                _delay_hmc(3);
        dat_temp = dat;
        for(index = 0; index < 3; index++)
                dat_temp = dat_temp <<8;
                for( dat_index = 0; dat_index < 8; dat_index++ )
                        if((dat_temp << dat_index) & 0x80000000)
                                HMC830_MOSI_H;
                        else
                HMC830_MOSI_L;
                        HMC830_SCK_L;
                        _delay_hmc(2);
                        HMC830_SCK_H;
                        _delay_hmc(2);
        WR_stop();
void RD_start()
        HMC830_CSN_L;
        HMC830_MOSI_L;
        HMC830_SCK_L;
        HMC830_CSN_H;
        HMC830_MOSI_H;
        _delay_hmc(2);
        HMC830_SCK_H;
        _delay_hmc(2);
        HMC830_SCK_L;
        _delay_hmc(2);
void RD_stop()
        HMC830_SCK_H;
        _delay_hmc(2);
        HMC830_CSN_L;
        _delay_hmc(2);
        HMC830_SCK_L;
東南博士|  楼主 | 2018-7-30 15:58 | 显示全部楼层
        unsigned long   Data;
    unsigned long   data_temp;
    unsigned char   Addr_temp;
        //unsigned char   Addr_index;
        RD_start();
        Addr_temp =Addr<<2;
        SCK =0;
        for(index=0;index<6;index++ )
                if((Addr_temp<<index) & 0x80)
                        HMC830_MOSI_H;
                else
                        HMC830_MOSI_L;
                HMC830_SCK_H;
                _delay_hmc(2);
                HMC830_SCK_L;
                _delay_hmc(2);
        for(index=0;index<24;index++)
                HMC830_SCK_H;
                _delay_hmc(2);
                data_temp=(unsigned long)LD_SDO;
                Data = Data|data_temp;
                if(index <23) Data = Data << 1;
                HMC830_SCK_H;
                _delay_hmc(2);
                SCK  = 0;
                _delay_hmc(2);
        RD_stop();
        return Data;
void HMC830_2097M(void)//参考40MHz
        WR_data(0x01,0x00000002);
        WR_data(0x02,0x00000001);//参考频标预分频寄存器
        WR_data(0x05,0x00001628);//VCO_reg5
        WR_data(0x05,0x000060A0);//VCO_reg4
    WR_data(0x05,0x00000898);//VCO_reg3,单端输出898,差分输出818
        WR_data(0x05,0x0000E090);//VCO_reg2,VCO输出分频为1
    //WR_data(0x05,0x0000E190);//VCO_reg2,VCO输出分频为2
        WR_data(0x05,0x00000000);//VCO_reg0
        //WR_data(0x06,0x000307CA);//整数模式Mode B,PFD>50M
    //WR_data(0x06,0x002007CA);//整数模式Mode B,PFD<50M
        //WR_data(0x06,0x00030F4A);//小数模式 Mode B
    //WR_data(0x06,0x00000F4A);//小数模式 Mode B,PFD<50M
    WR_data(0x06,0x00200B4A);//小数模式 Mode B,PFD<50M
    WR_data(0x07,0x0000014D);//锁定窗口设置
        WR_data(0x08,0x00C1BEFF);
        //WR_data(0x09,0x0000376E);//
    //WR_data(0x09,0x00501E3C);//电荷泵电流
    //WR_data(0x09,0x00513264);//电荷泵电流2mA
    //WR_data(0x09,0x00489932);//电荷泵电流1
    WR_data(0x09,0x00557EFD);//电荷泵电流2.5
        WR_data(0x0A,0x00002046);//
        //WR_data(0x0B,0x0007C061);//
    WR_data(0x0B,0x0007C021);// disable PD DN output
        WR_data(0x0F,0x00000081);//GPO_SPI_RDIV
        WR_data(0x03,0x00000034);//整数部分50
    WR_data(0x04,0x006CCCCD);//小数部分50
東南博士|  楼主 | 2018-7-30 15:59 | 显示全部楼层
void HMC830_260M(void)//参考100MHz
        WR_data(0x02,0x00000005);//参考频标预分频寄存器
        //WR_data(0x05,0x0000E090);//VCO_reg2,VCO输出分频为1
        WR_data(0x05,0x0000E510);//VCO_reg2,fo/10
    //WR_data(0x06,0x00200B4A);//小数模式 Mode B,PFD<50M
        WR_data(0x03,0x00000082);//整数部分50
    //WR_data(0x04,0x006CCCCD);//小数部分50
void HMC829_60M(void)
    WR_data(0x05,0x00000818);//VCO_reg3,单端输出898,差分输出818
    WR_data(0x05,0x00009E10);//VCO_reg2,VCO输出分频为60
        WR_data(0x03,0x0000005A);//整数部分50
void HMC830_140_340_STEP_2M(void)
1、使用整数模式,参考频率100MHz,PFD=20MHz
2、VCO频率定为2800~3400MHz,输出频率210MHZ为分界点
340*6=3040
140*14=1960
150*14=2100
unsigned long Freq830_Integer = 260;//140~340取偶数
//unsigned long []
void HMC830_140_340_STEP_2M(void)//已锁定
        WR_data(0x01,0x00000002);//CEN由SPI程序控制
        WR_data(0x02,0x00000005);//R分频器
        if(Freq830_Integer<=150 & Freq830_Integer>=140)//VCO=2800~3000
        WR_data(0x05,0x0000EA10);//VCO_reg2,fo/20
                Freq830_Integer=Freq830_Integer;
        else if(Freq830_Integer>150 & Freq830_Integer<=300)//VCO=1500~3000
        Freq830_Integer=Freq830_Integer/2;
        else if(Freq830_Integer>300 & Freq830_Integer<=340)//VCO=1800~2040
                WR_data(0x05,0x0000E510);//VCO_reg2,fo/6
    //WR_data(0x06,0x00030F4A);//小数模式Mode B
        WR_data(0x07,0x0000214D);//锁定窗口设置
        WR_data(0x08,0x00C1BEFF);//如果输入参考频率小于200MHz,可以不写
    WR_data(0x09,0x00513264);//CP
        WR_data(0x0F,0x00000081);//锁定指示输出
        WR_data(0x03,Freq830_Integer);//
        //WR_data(0x04,0x00D99999);//
東南博士|  楼主 | 2018-7-30 16:00 | 显示全部楼层
void HMC829(void)//已锁定
        WR_data(0x02,0x00000001);//R分频器
        WR_data(0x05,0x00007E28);//VCO_reg5
        WR_data(0x05,0x0000B6A0);//VCO_reg4
        WR_data(0x05,0x0000E190);//VCO_reg2,fo/2
        //WR_data(0x09,0x0000376E);//CP
    //WR_data(0x09,0x00003FFF);//CP
        WR_data(0x03,0x00000068);//
東南博士|  楼主 | 2018-7-30 16:02 | 显示全部楼层
unsigned long Freq_Integer = 210;
//Freq_Integer = Freq_HMC829/
/*使用整数模式,参考频率100MHz,PFD=20MHz
void HMC829_140_340_STEP_2M(void)//已锁定
    if(Freq_Integer<=210 & Freq_Integer>=140)
        if(Freq_Integer>210 & Freq_Integer<=340)
        Freq_Integer=Freq_Integer/2;
    //WR_data(0x05,0x0000E090);//VCO_reg2,fo/2
        //WR_data(0x03,0x00000096);//
        WR_data(0x03,Freq_Integer);//
東南博士|  楼主 | 2018-7-30 16:03 | 显示全部楼层
        if(HMC830_MISO_GET())
                return 1;
        else
                return 0;
東南博士|  楼主 | 2018-7-30 16:06 | 显示全部楼层
        Init_HMC830_Port();
        HMC830_2097M();
zhangxiaoxiao87| | 2019-4-18 18:24 | 显示全部楼层
楼主好人啊!!!!
東南博士|  楼主 | 2019-4-29 20:25 | 显示全部楼层
你有用的吗?
