有关迭代法图像二值化程序代码的问题!
813|5
麓山电玩|  楼主 | 2018-8-3 15:09 | 显示全部楼层 |阅读模式
求助各位大佬~~这个迭代法图像二值化的程序设定的长宽是180*320,但是我屏幕是240*320,所以有一部分屏幕是看不到东西的,但是我把宽调成240以后整个屏幕都不亮了!是数据类型定义出问题了么?求助各位大佬帮帮小弟!
#define PIXEL_W      320
#define PIXEL_H    180
#define PIXEL_BREAK  100
//»Ò¶ÈÖ±·½Í¼ÊýÖµ£¬ÓÃÀ´Åжϰ´Í¼ÏñÖÊÁ¿
u32 gray_test_value[26];   //ÏñËصãÊýÊý¾Ý
u8 gray_test_send[28];     //·¢Ë͸øÉÏλ»úµÄÊý¾Ý
//ãÐÖµ·Ö¸î»Ò¶Èͼ
u8 gray_itera_threshold[256];
u16 threshold_h[256];
#define GRAY_BREAK_RANGE     1    //ãÐÖµÔÊÐí²ÎÊý
static u8 pixel[PIXEL_H][PIXEL_W];
/*       320
*|                   |  240
void ImagDisp_T(void)
        uint16_t i=0, j=0;
        uint16_t Camera_Data;
        uint16_t R,G,B;uint32_t mux;
  //mux_later;
//        float data = 0.0;
//        LCD_SetCursor(0,0); È·¶¨Òº¾§É¨Ãè·½Ïò
//        LCD_WriteIndex(0x22);ÇåÆÁ×¼±¸Ð´ÈëÊý¾Ý
  ILI9341_GramScan ( 3 );
        for(i = 0; i<PIXEL_H; i++)
                for(j = 0; j<PIXEL_W; j++)
                 //READ_FIFO_PIXEL(Camera_Data);                /* ´ÓFIFO¶Á³öÒ»¸örgb565ÏñËص½Camera_Data±äÁ¿ */
                 //ת»»³É»Ò¶Èͼ
                        R = (uint16_t)GETR_FROM_RGB16(Camera_Data);
                        G = (uint16_t)GETG_FROM_RGB16(Camera_Data);
                        B = (uint16_t)GETB_FROM_RGB16(Camera_Data);
                        mux = (R*30+G*59+B*11)/100;
////                 mux = G;
                        pixel[i][j] = mux;
    //pixel[i][j] = GETGRAY_FROM_RGB16(R,G,B);
  //    mux = pixel[i][j];
//     Camera_Data =  GRAY_TO_RGB(mux);
//     ILI9341_Write_Data(Camera_Data);
* º¯ÊýÃû£ºItera_Threshold
* ¹¦  ÄÜ£ºµü´úãÐÖµ·¨£¬Äܹ»ÕÒµ½»Ò¶ÈͼµÄ×î¼Ñ¶þÖµ»¯µã
void Itera_Threshold(void)
  u16 i=0,j=0,k=0,cnt=0,mux=0,Camera_Data=0;
        u8 newthreshold=0;
        u16 Pmax=0,Pmin=0;
        u32 sum_h1=0,sum_h2=0;
        //Êý¾ÝÇå¿Õ
        for( i=0; i<256; i++ )
          gray_test_value[i] = 0;
        for( i=0; i<PIXEL_H; i++ )
          for( j=0; j<PIXEL_W; j++ )
                  mux = pixel[i][j];//»ñÈ¡»Ò¶ÈͼµÄÊý¾Ý
                        //ÏñËصãÊý×ÔÔö
                        gray_itera_threshold[mux]++;
        Pmin = gray_itera_threshold[0];
        Pmax = gray_itera_threshold[0];
        for( cnt=0; cnt<256; cnt++ )
      if( Pmin>gray_itera_threshold[cnt] )
        Pmin = gray_itera_threshold[cnt];
      if( Pmax<gray_itera_threshold[cnt] )
        Pmax = gray_itera_threshold[cnt];
        printf("the Pmax is %d\r \n",Pmax);
        printf("the Pmin is %d \r\n",Pmin);
        //³õʼãÐÖµ
        threshold_h[0] = ( Pmax + Pmin ) / 2;
        //Ñ°ÕÒ×î¼ÑãÐÖµ
        for( k=0; k<256; k++ )
                //·Ö¸îÇ°¾°ºÍ±³¾°
                for( cnt=0; cnt<threshold_h[k]; cnt++ )
                        sum_h1 += gray_itera_threshold[cnt];
                for( cnt=threshold_h[k]; cnt<256; cnt++ )
                        sum_h2 += gray_itera_threshold[cnt];
                sum_h1 /= threshold_h[k];
                sum_h2 /= (256-threshold_h[k]);
                //¼ÆËã³öеÄãÐÖµ
                threshold_h[k+1] = ( sum_h1 + sum_h2 ) / 2;
                if( fabs(threshold_h[k]-threshold_h[k+1]) <= GRAY_BREAK_RANGE )
                        newthreshold = threshold_h[k+1];
                  break;
                sum_h1 = 0;
                sum_h2 = 0;
        printf("the newthreshold is %d\r\n",newthreshold);
//        //ÔÚÒº¾§ÆÁÉÏÃæдÈëͼÏñ·Ö¸îºóµÄͼÏñ
//        LCD_WriteIndex(0x22);                                        //×¼±¸Ð´ÈëÊý¾Ý
        //¸ù¾Ý×î¼ÑãÐÖµ½«Í¼Ïñ¶þÖµ»¯
//  ILI9341_Clear ( 0, 0, 240, 320, macWHITE);
                  mux = pixel[i][j];                     //»ñÈ¡»Ò¶ÈͼµÄÊý¾Ý
                  //ͼÏñ¶þÖµ»¯
                        if( mux > newthreshold )
                          mux = 255;
                        else
                          mux = 0;
caijie001| | 2018-8-3 21:55 | 显示全部楼层
采集是按比例的吧,
不能随意改变比例吧。。。按照你说的单纯修改宏应该是没啥问题的
麓山电玩|  楼主 | 2018-8-4 14:02 | 显示全部楼层
对呀,我就是修改了宏定义但是为啥他有数值限制,好奇怪哇,只能定义到188以下,再大整个屏幕不亮了哇
caijie001| | 2018-8-4 14:03 | 显示全部楼层
麓山电玩 发表于 2018-8-4 14:02
对呀,我就是修改了宏定义但是为啥他有数值限制,好奇怪哇,只能定义到188以下,再大整个屏幕不亮了哇 ...
这个看传感器手册,具体我也不知道
麓山电玩|  楼主 | 2018-8-4 15:42 | 显示全部楼层
caijie001 发表于 2018-8-4 14:03
这个看传感器手册,具体我也不知道
看摄像头还是屏幕呀,就用了这个算法才会出现这种问题,别的显示都没问题
