[技术讨论]
【问题求助】 error: A1355U: A Label was found which was in no AREA
1297|0
xiaok1051|  楼主 | 2018-8-23 21:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
编译错误:..\..\User\uCOS-III\Ports\os_cpu_a.s(15): error: A1355U: A Label was found which was in no AREA
keil编译汇编出错。
OSStartHighRdy
        LDR                R0, =NVIC_SYSPRI14                ;ÉèÖÃPendSVÒì³£ÓÅÏȼ¶Îª×îµÍ
        LDR                R1, =NVIC_PENDSV_PRI
        STRB        R1, [R0]
        MOVS        R0, #0                                        ;ÉèÖÃpspµÄֵΪ0£¬¿ªÊ¼µÚÒ»´ÎÉÏÏÂÎÄÇл»
        MSR                PSP, R0
        LDR                R0, =NVIC_INT_CTRL                ;´¥·¢PendSVÒì³£
        LDR                R1, =NVIC_PENDSVSET
        STR                R1, [R0]
        CPSIE        I                                                ;ʹÄÜ×ÜÖжϣ¬NMIºÍHardFault³ýÍ⣬½øÈëÖжϷþÎñ³ÌÐò
OSStartHang
        B                OSStartHang                                ;³ÌÐòÓ¦¸ÃÓÀÔ¶²»»áÔËÐе½ÕâÀï
