[开发工具]
PellesC9.0出正式版了
1217|6
643757107|  楼主 | 2018-8-26 13:20 | 显示全部楼层 |阅读模式
http://www.christian-heffner.de/files/900/setup.exe
643757107|  楼主 | 2018-8-26 13:21 | 显示全部楼层
http://www.christian-heffner.de/index.php?page=download&lang=en
目前唯一靠谱支持win10的C编译器,方便我们测试某个算法或者函数。
643757107|  楼主 | 2018-8-26 14:08 | 显示全部楼层
Pelles C IDE, Compiler, Linker, Librarys, Helpfiles, Examples, Registryeditor for 64-bit Windows
From this version on there is only a 64-bit build available and the Add-In SDK is now part of the main Setup.
Support for 32- and 64-bit projects
Languages: English, Swedish, German, French, Greek
This version of Pelles C supports Windows Vista/7/8/10.
Please uninstall any older version of Pelles C before installing version 9.00.
小明的同学| | 2018-8-26 19:01 | 显示全部楼层
好软件,谢谢。
xuanhuanzi| | 2018-8-26 19:30 | 显示全部楼层
这个软件好用,兼容性好,又不大,十几个M
dongliushui| | 2018-8-26 20:49 | 显示全部楼层
替换Dev-C的好东西。
DEV C++好多年没更新了 ,现在就靠这个了
