[技术问答]
关于N76E003中断例程
2057|16
ClimberAzure|  楼主 | 2018-8-29 10:10 | 显示全部楼层 |阅读模式
有关于对这个程序的详解吗,不是很能理解
ClimberAzure|  楼主 | 2018-8-29 10:25 | 显示全部楼层
怎么从主函数跳到中断函数
jasontu| | 2018-8-29 11:40 | 显示全部楼层
在网路上找下8051中断,应该就以理解。
ClimberAzure|  楼主 | 2018-8-29 16:09 | 显示全部楼层
N76E003  IO中断怎么触发
ClimberAzure 发表于 2018-8-29 16:09
N76E003  IO中断怎么触发
例程里面怎么触发的没看懂
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 I/O Interrupt demo code
#include "N76E003.h"
#include "SFR_Macro.h"
#include "Function_define.h"
#include "Common.h"
#include "Delay.h"
#if 0
//Following setting in Function_define.h
//   Enable INT port 0~3
//#define         Enable_INT_Port0                                        PICON &= 0xFB;
//#define                Enable_INT_Port1                                        PICON |= 0x01;
//#define                Enable_INT_Port2                                        PICON |= 0x02;
//#define                Enable_INT_Port3                                        PICON |= 0x03;
// Enable each bit low level trig mode
//#define                Enable_BIT7_LowLevel_Trig                        PICON&=0x7F;PINEN|=0x80;PIPEN&=0x7F
//#define                Enable_BIT6_LowLevel_Trig                        PICON&=0x7F;PINEN|=0x40;PIPEN&=0xBF
//#define                Enable_BIT5_LowLevel_Trig                        PICON&=0xBF;PINEN|=0x20;PIPEN&=0xDF
//#define                Enable_BIT4_LowLevel_Trig                        PICON&=0xBF;PINEN|=0x10;PIPEN&=0xEF
//#define                Enable_BIT3_LowLevel_Trig                        PICON&=0xDF;PINEN|=0x08;PIPEN&=0xF7
//#define                Enable_BIT2_LowLevel_Trig                        PICON&=0xEF;PINEN|=0x04;PIPEN&=0xFB
//#define                Enable_BIT1_LowLevel_Trig                        PICON&=0xF7;PINEN|=0x02;PIPEN&=0xFD
//#define                Enable_BIT0_LowLevel_Trig                        PICON&=0xFD;PINEN|=0x01;PIPEN&=0xFE
// Enable each bit high level trig mode
//#define                Enable_BIT7_HighLevel_Trig                        PICON&=0x7F;PINEN&=0x7F;PIPEN|=0x80
//#define                Enable_BIT6_HighLevel_Trig                        PICON&=0x7F;PINEN&=0xBF;PIPEN|=0x40
//#define                Enable_BIT5_HighLevel_Trig                        PICON&=0xBF;PINEN&=0xDF;PIPEN|=0x20
//#define                Enable_BIT4_HighLevel_Trig                        PICON&=0xBF;PINEN&=0xEF;PIPEN|=0x10
//#define                Enable_BIT3_HighLevel_Trig                        PICON&=0xDF;PINEN&=0xF7;PIPEN|=0x08
//#define                Enable_BIT2_HighLevel_Trig                        PICON&=0xEF;PINEN&=0xFB;PIPEN|=0x04
//#define                Enable_BIT1_HighLevel_Trig                        PICON&=0xF7;PINEN&=0xFD;PIPEN|=0x02
//#define                Enable_BIT0_HighLevel_Trig                        PICON&=0xFD;PINEN&=0xFE;PIPEN|=0x01
// Enable each bit falling edge trig mode
//#define                Enable_BIT7_FallEdge_Trig                        PICON|=0x80;PINEN|=0x80;PIPEN&=0x7F
//#define                Enable_BIT6_FallEdge_Trig                        PICON|=0x80;PINEN|=0x40;PIPEN&=0xBF
//#define                Enable_BIT5_FallEdge_Trig                        PICON|=0x40;PINEN|=0x20;PIPEN&=0xDF
//#define                Enable_BIT4_FallEdge_Trig                        PICON|=0x40;PINEN|=0x10;PIPEN&=0xEF
//#define                Enable_BIT3_FallEdge_Trig                        PICON|=0x20;PINEN|=0x08;PIPEN&=0xF7
//#define                Enable_BIT2_FallEdge_Trig                        PICON|=0x10;PINEN|=0x04;PIPEN&=0xFB
//#define                Enable_BIT1_FallEdge_Trig                        PICON|=0x08;PINEN|=0x02;PIPEN&=0xFD
//#define                Enable_BIT0_FallEdge_Trig                        PICON|=0x04;PINEN|=0x01;PIPEN&=0xFE
// Enable each bit rasing edge trig mode
//#define                Enable_BIT7_RasingEdge_Trig                        PICON|=0x80;PINEN&=0x7F;PIPEN|=0x80
//#define                Enable_BIT6_RasingEdge_Trig                        PICON|=0x80;PINEN&=0xBF;PIPEN|=0x40
//#define                Enable_BIT5_RasingEdge_Trig                        PICON|=0x40;PINEN&=0xDF;PIPEN|=0x20
//#define                Enable_BIT4_RasingEdge_Trig                        PICON|=0x40;PINEN&=0xEF;PIPEN|=0x10
//#define                Enable_BIT3_RasingEdge_Trig                        PICON|=0x20;PINEN&=0xF7;PIPEN|=0x08
//#define                Enable_BIT2_RasingEdge_Trig                        PICON|=0x10;PINEN&=0xFB;PIPEN|=0x04
//#define                Enable_BIT1_RasingEdge_Trig                        PICON|=0x08;PINEN|=0xFD;PIPEN&=0x02
//#define                Enable_BIT0_RasingEdge_Trig                        PICON|=0x04;PINEN|=0xFE;PIPEN&=0x01
#endif
* FUNCTION_PURPOSE: I/O Pin interrupt Service Routine
void EXT_INT0(void) interrupt 0
                                clr_GPIO1;
                        Timer0_Delay1ms(100);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                                clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
void PinInterrupt_ISR (void) interrupt 7
        if(PIF == 0x01)
    PIF = 0x00;                             //clear interrupt flag
                        clr_GPIO1;
                        Timer1_Delay10ms(10);
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
        else if (PIF == 0x80)
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
                        clr_GPIO1;
                        set_GPIO1;
The main C function.  Program execution starts
here after stack initialization.
void main (void)
    P07_Input_Mode;
                set_P0S_7;
                P00_Input_Mode;
                P01_Input_Mode;
                set_P0S_1;
                P12_PushPull_Mode;
                P30_PushPull_Mode;
                P05_PushPull_Mode;
//        P0.5 set as highlevel trig pin interrupt function
//  Keep P0.5 connect to VDD LED will tickle
//  otherwise, MCU into power down mode.
                Enable_INT_Port2;
//                Enable_BIT7_LowLevel_Trig;
                Enable_BIT0_LowLevel_Trig;
                P30 =1;
                P05 = 0;
    set_EPI;                                                        // Enable pin interrupt
                set_EX0;
    set_EA;        // global enable bit
    while(1)
                        P01=0;
                        P30=0;
                        P01=1;
                        P30=1;
wanduzi| | 2018-8-30 09:41 | 显示全部楼层
什么中断的?
zhuomuniao110| | 2018-9-1 22:19 | 显示全部楼层
例程里面怎么触发的没看懂
看那个if判断啊。
zhuomuniao110| | 2018-9-1 22:21 | 显示全部楼层
你看那个使能什么边沿触发就知道怎么触发了,有上升沿,下降沿等。
zhuomuniao110| | 2018-9-1 22:22 | 显示全部楼层
一般IO触发方式有4种:上升沿,下降沿,高电平,低电平。
上升沿只在上升的一瞬间触发,高电平是一直触发。其实用起来是差不多。
Linzeran| | 2018-9-5 11:03 | 显示全部楼层
N76E003AT20 P20做IO输入中断例程有吗
598330983| | 2018-9-5 17:21 | 显示全部楼层
干嘛非要用P20
上面那个人好奇怪。
yiyigirl2014| | 2018-9-6 09:59 | 显示全部楼层
手册仔细研究后,再看例子。
yiyigirl2014| | 2018-9-6 16:38 | 显示全部楼层
楼主是不是已经玩的很666了。
捉虫天师| | 2018-9-6 19:40 | 显示全部楼层
楼主要用到哪些中断?
weiyi123| | 2018-9-22 11:45 | 显示全部楼层
捉虫天师 发表于 2018-9-6 19:40
楼主要用到哪些中断?
层主 有ADC 中断例层吗?求分享呀
