[应用方案]
472的篡改检测复位备份演示
556|4
zhuotuzi|  楼主 | 2018-9-9 10:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
不知道翻译的对不对,请高手来讲解啊
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Date: 14/07/31 1:44p $
* [url=home.php?mod=space&uid=247401]@brief[/url]    NUC472/NUC442 General Purpose I/O Driver Sample Code
*           Connect PB.3 and PD.7 to test IO In/Out
*           Test PB2, PC5, PA0(INT0) and PF0(INT5) interrupts
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC472_442.h"
#include "gpio.h"
#define PLLCON_SETTING      CLK_PLLCON_84MHz_HXT
#define PLL_CLOCK           84000000
* @brief       GPIO IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The GPIO default IRQ, declared in startup_NUC472_442.s.
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable External XTAL (4~24 MHz) */
    CLK->PWRCTL |= CLK_PWRCTL_HXTEN_Msk; // XTAL12M (HXT) Enabled
    /* Waiting for 12MHz clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Switch HCLK clock source to XTAL */
    CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLKSEL_Msk;
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLKSEL_HXT;
    /* Enable IP clock */
    CLK->APBCLK0 |= CLK_APBCLK0_UART0CKEN_Msk; // UART0 Clock Enable
    CLK->APBCLK0 |= CLK_APBCLK0_RTCCKEN_Msk; // RTC Clock Enable
    /* Select IP clock source */
    CLK->CLKSEL1 &= ~CLK_CLKSEL1_UARTSEL_Msk;
    CLK->CLKSEL1 |= (0x0 << CLK_CLKSEL1_UARTSEL_Pos);// Clock source from external 12 MHz or 32 KHz crystal clock
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PG multi-function pins for UART0 RXD, TXD */
    SYS->GPG_MFPL &= ~(SYS_GPG_MFPL_PG1MFP_Msk | SYS_GPG_MFPL_PG2MFP_Msk);
    SYS->GPG_MFPL |= (SYS_GPG_MFPL_PG1MFP_UART0_RXD | SYS_GPG_MFPL_PG2MFP_UART0_TXD);
    /* Lock protected registers */
//    SYS_LockReg();
void RTC_init(void)
    S_RTC_TIME_DATA_T sRTC_Time;
    /* Time Setting */
    sRTC_Time.u32Year       = 2016;
    sRTC_Time.u32Month      = 12;
    sRTC_Time.u32Day        = 13;
    sRTC_Time.u32Hour       = 12;
    sRTC_Time.u32Minute     = 59;
    sRTC_Time.u32Second     = 50;
    sRTC_Time.u32DayOfWeek  = RTC_TUESDAY;
    sRTC_Time.u32TimeScale  = RTC_CLOCK_24;
    RTC_Open(&sRTC_Time);
    RTC_EnableTamperDetection(RTC_TAMPER_0, 1, 0, 1, 1);
    RTC_EnableTamperDetection(RTC_TAMPER_1, 1, 0, 1, 1);
/* MAIN function        */
void RTC_AccessEnable()
    RTC->RWEN = RTC_WRITE_KEY;
    while(!(RTC->RWEN & RTC_RWEN_RWENF_Msk));
int main (void)
    int32_t Spare_Data, i;
    SYS_Init();
    /* Init UART to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    SYS->GPA_MFPL &= ~(SYS_GPA_MFPL_PA1MFP_Msk | SYS_GPA_MFPL_PA2MFP_Msk | SYS_GPA_MFPL_PA0MFP_Msk);
    GPIO_SetMode(PA, (BIT0 | BIT1 | BIT2), GPIO_MODE_OUTPUT);
    PA0 = 0;
    PA1 = 0;
    PA2 = 0;
    SYS->GPA_MFPL |= (SYS_GPA_MFPL_PA0MFP_TAMPER0  | SYS_GPA_MFPL_PA1MFP_TAMPER1);
    RTC_init();
   // Enable spare register
    RTC_EnableSpareAccess();
    // Write spare register
    for(i = 0; i < 24; i++) {
        RTC_AccessEnable();
        RTC_WRITE_SPARE_REGISTER(i, i+1);
        while(!(RTC->SPRCTL & RTC_SPRCTL_SPRRWRDY_Msk));
     while (1)
        // Check spare register data
            RTC_AccessEnable();
            Spare_Data = RTC_READ_SPARE_REGISTER(i);
            if(Spare_Data != i+1)
                PA2 = 0;
            else
                PA2 = 1;
zhuotuzi|  楼主 | 2018-9-9 10:42 | 只看该作者
NUC472_442 侦测RTC PA[1:0] Tamper pin, 若异常将清除96 bytes spare registers Sample Code.
antusheng| | 2018-9-9 19:44 | 只看该作者
貌似一个RTC的应用,没见过。
dongliushui| | 2018-9-9 19:47 | 只看该作者
目前还没用过这个功能。MARK,学习一下。
幸福小强| | 2018-9-9 21:21 | 只看该作者
没看懂啥意思。
