[应用相关]
这个ADC与stm32驱动的区别?
1464|15
gaoke231|  楼主 | 2018-9-16 22:28 | 显示全部楼层 |阅读模式
static uint32_t ADC16_GetInstance(ADC_Type *base)
    uint32_t instance;
    /* Find the instance index from base address mappings. */
    for (instance = 0; instance < FSL_FEATURE_SOC_ADC16_COUNT; instance++)
        if (s_adc16Bases[instance] == base)
            break;
    assert(instance < FSL_FEATURE_SOC_ADC16_COUNT);
    return instance;
gaoke231|  楼主 | 2018-9-16 22:30 | 显示全部楼层
ADC初始化
void ADC16_Init(ADC_Type *base, const adc16_config_t *config)
    assert(NULL != config);
    uint32_t tmp32;
    /* Enable the clock. */
    CLOCK_EnableClock(s_adc16Clocks[ADC16_GetInstance(base)]);
    /* ADCx_CFG1. */
    tmp32 = ADC_CFG1_ADICLK(config->clockSource) | ADC_CFG1_MODE(config->resolution);
    if (kADC16_LongSampleDisabled != config->longSampleMode)
        tmp32 |= ADC_CFG1_ADLSMP_MASK;
    tmp32 |= ADC_CFG1_ADIV(config->clockDivider);
    if (config->enableLowPower)
        tmp32 |= ADC_CFG1_ADLPC_MASK;
    base->CFG1 = tmp32;
    /* ADCx_CFG2. */
    tmp32 = base->CFG2 & ~(ADC_CFG2_ADACKEN_MASK | ADC_CFG2_ADHSC_MASK | ADC_CFG2_ADLSTS_MASK);
        tmp32 |= ADC_CFG2_ADLSTS(config->longSampleMode);
    if (config->enableHighSpeed)
        tmp32 |= ADC_CFG2_ADHSC_MASK;
    if (config->enableAsynchronousClock)
        tmp32 |= ADC_CFG2_ADACKEN_MASK;
    base->CFG2 = tmp32;
    /* ADCx_SC2. */
    tmp32 = base->SC2 & ~(ADC_SC2_REFSEL_MASK);
    tmp32 |= ADC_SC2_REFSEL(config->referenceVoltageSource);
    base->SC2 = tmp32;
    /* ADCx_SC3. */
    if (config->enableContinuousConversion)
        base->SC3 |= ADC_SC3_ADCO_MASK;
    else
        base->SC3 &= ~ADC_SC3_ADCO_MASK;
ADC复位
void ADC16_Deinit(ADC_Type *base)
    /* Disable the clock. */
    CLOCK_DisableClock(s_adc16Clocks[ADC16_GetInstance(base)]);
gaoke231|  楼主 | 2018-9-16 22:32 | 显示全部楼层
void ADC16_GetDefaultConfig(adc16_config_t *config)
    config->referenceVoltageSource = kADC16_ReferenceVoltageSourceVref;
    config->clockSource = kADC16_ClockSourceAsynchronousClock;
    config->enableAsynchronousClock = true;
    config->clockDivider = kADC16_ClockDivider8;
    config->resolution = kADC16_ResolutionSE12Bit;
    config->longSampleMode = kADC16_LongSampleDisabled;
    config->enableHighSpeed = false;
    config->enableLowPower = false;
    config->enableContinuousConversion = false;
#if defined(FSL_FEATURE_ADC16_HAS_CALIBRATION) && FSL_FEATURE_ADC16_HAS_CALIBRATION
status_t ADC16_DoAutoCalibration(ADC_Type *base)
    bool bHWTrigger = false;
    uint32_t tmp32;
    status_t status = kStatus_Success;
    /* The calibration would be failed when in hardwar mode.
     * Remember the hardware trigger state here and restore it later if the hardware trigger is enabled.*/
    if (0U != (ADC_SC2_ADTRG_MASK & base->SC2))
        bHWTrigger = true;
        base->SC2 &= ~ADC_SC2_ADTRG_MASK;
    /* Clear the CALF and launch the calibration. */
    base->SC3 |= ADC_SC3_CAL_MASK | ADC_SC3_CALF_MASK;
    while (0U == (kADC16_ChannelConversionDoneFlag & ADC16_GetChannelStatusFlags(base, 0U)))
        /* Check the CALF when the calibration is active. */
        if (0U != (kADC16_CalibrationFailedFlag & ADC16_GetStatusFlags(base)))
            status = kStatus_Fail;
            break;
    /* Restore the hardware trigger setting if it was enabled before. */
    if (bHWTrigger)
        base->SC2 |= ADC_SC2_ADTRG_MASK;
    /* Check the CALF at the end of calibration. */
    if (kStatus_Success != status) /* Check if the calibration process is succeed. */
        return status;
    /* Calculate the calibration values. */
    tmp32 = base->CLP0 + base->CLP1 + base->CLP2 + base->CLP3 + base->CLP4 + base->CLPS;
    tmp32 = 0x8000U | (tmp32 >> 1U);
    base->PG = tmp32;
#if defined(FSL_FEATURE_ADC16_HAS_DIFF_MODE) && FSL_FEATURE_ADC16_HAS_DIFF_MODE
    tmp32 = base->CLM0 + base->CLM1 + base->CLM2 + base->CLM3 + base->CLM4 + base->CLMS;
    base->MG = tmp32;
#endif /* FSL_FEATURE_ADC16_HAS_DIFF_MODE */
    return kStatus_Success;
#endif /* FSL_FEATURE_ADC16_HAS_CALIBRATION */
gaoke231|  楼主 | 2018-9-16 22:33 | 显示全部楼层
#if defined(FSL_FEATURE_ADC16_HAS_MUX_SELECT) && FSL_FEATURE_ADC16_HAS_MUX_SELECT
void ADC16_SetChannelMuxMode(ADC_Type *base, adc16_channel_mux_mode_t mode)
    if (kADC16_ChannelMuxA == mode)
        base->CFG2 &= ~ADC_CFG2_MUXSEL_MASK;
    else /* kADC16_ChannelMuxB. */
        base->CFG2 |= ADC_CFG2_MUXSEL_MASK;
#endif /* FSL_FEATURE_ADC16_HAS_MUX_SELECT */
void ADC16_SetHardwareCompareConfig(ADC_Type *base, const adc16_hardware_compare_config_t *config)
    uint32_t tmp32 = base->SC2 & ~(ADC_SC2_ACFE_MASK | ADC_SC2_ACFGT_MASK | ADC_SC2_ACREN_MASK);
    if (!config) /* Pass "NULL" to disable the feature. */
        base->SC2 = tmp32;
        return;
    /* Enable the feature. */
    tmp32 |= ADC_SC2_ACFE_MASK;
    /* Select the hardware compare working mode. */
    switch (config->hardwareCompareMode)
        case kADC16_HardwareCompareMode0:
            break;
        case kADC16_HardwareCompareMode1:
            tmp32 |= ADC_SC2_ACFGT_MASK;
            break;
        case kADC16_HardwareCompareMode2:
            tmp32 |= ADC_SC2_ACREN_MASK;
            break;
        case kADC16_HardwareCompareMode3:
            tmp32 |= ADC_SC2_ACFGT_MASK | ADC_SC2_ACREN_MASK;
            break;
        default:
            break;
    base->SC2 = tmp32;
    /* Load the compare values. */
    base->CV1 = ADC_CV1_CV(config->value1);
    base->CV2 = ADC_CV2_CV(config->value2);
#if defined(FSL_FEATURE_ADC16_HAS_HW_AVERAGE) && FSL_FEATURE_ADC16_HAS_HW_AVERAGE
void ADC16_SetHardwareAverage(ADC_Type *base, adc16_hardware_average_mode_t mode)
    uint32_t tmp32 = base->SC3 & ~(ADC_SC3_AVGE_MASK | ADC_SC3_AVGS_MASK);
    if (kADC16_HardwareAverageDisabled != mode)
        tmp32 |= ADC_SC3_AVGE_MASK | ADC_SC3_AVGS(mode);
    base->SC3 = tmp32;
#endif /* FSL_FEATURE_ADC16_HAS_HW_AVERAGE */
#if defined(FSL_FEATURE_ADC16_HAS_PGA) && FSL_FEATURE_ADC16_HAS_PGA
void ADC16_SetPGAConfig(ADC_Type *base, const adc16_pga_config_t *config)
    uint32_t tmp32;
    if (!config) /* Passing "NULL" is to disable the feature. */
        base->PGA = 0U;
        return;
    /* Enable the PGA and set the gain value. */
    tmp32 = ADC_PGA_PGAEN_MASK | ADC_PGA_PGAG(config->pgaGain);
    /* Configure the misc features for PGA. */
    if (config->enableRunInNormalMode)
        tmp32 |= ADC_PGA_PGALPb_MASK;
#if defined(FSL_FEATURE_ADC16_HAS_PGA_CHOPPING) && FSL_FEATURE_ADC16_HAS_PGA_CHOPPING
    if (config->disablePgaChopping)
        tmp32 |= ADC_PGA_PGACHPb_MASK;
#endif /* FSL_FEATURE_ADC16_HAS_PGA_CHOPPING */
#if defined(FSL_FEATURE_ADC16_HAS_PGA_OFFSET_MEASUREMENT) && FSL_FEATURE_ADC16_HAS_PGA_OFFSET_MEASUREMENT
    if (config->enableRunInOffsetMeasurement)
        tmp32 |= ADC_PGA_PGAOFSM_MASK;
#endif /* FSL_FEATURE_ADC16_HAS_PGA_OFFSET_MEASUREMENT */
    base->PGA = tmp32;
#endif /* FSL_FEATURE_ADC16_HAS_PGA */
gaoke231|  楼主 | 2018-9-16 22:34 | 显示全部楼层
uint32_t ADC16_GetStatusFlags(ADC_Type *base)
    uint32_t ret = 0;
    if (0U != (base->SC2 & ADC_SC2_ADACT_MASK))
        ret |= kADC16_ActiveFlag;
    if (0U != (base->SC3 & ADC_SC3_CALF_MASK))
        ret |= kADC16_CalibrationFailedFlag;
    return ret;
gaoke231|  楼主 | 2018-9-16 22:35 | 显示全部楼层
void ADC16_ClearStatusFlags(ADC_Type *base, uint32_t mask)
    if (0U != (mask & kADC16_CalibrationFailedFlag))
        base->SC3 |= ADC_SC3_CALF_MASK;
gaoke231|  楼主 | 2018-9-16 22:36 | 显示全部楼层
void ADC16_SetChannelConfig(ADC_Type *base, uint32_t channelGroup, const adc16_channel_config_t *config)
    assert(channelGroup < ADC_SC1_COUNT);
    uint32_t sc1 = ADC_SC1_ADCH(config->channelNumber); /* Set the channel number. */
    /* Enable the differential conversion. */
    if (config->enableDifferentialConversion)
        sc1 |= ADC_SC1_DIFF_MASK;
    /* Enable the interrupt when the conversion is done. */
    if (config->enableInterruptOnConversionCompleted)
        sc1 |= ADC_SC1_AIEN_MASK;
    base->SC1[channelGroup] = sc1;
uint32_t ADC16_GetChannelStatusFlags(ADC_Type *base, uint32_t channelGroup)
    uint32_t ret = 0U;
    if (0U != (base->SC1[channelGroup] & ADC_SC1_COCO_MASK))
        ret |= kADC16_ChannelConversionDoneFlag;
    return ret;
晓伍| | 2018-10-9 10:37 | 显示全部楼层
感谢楼主分享
观海| | 2018-10-9 11:31 | 显示全部楼层
米看明白楼主想问啥
wowu| | 2018-10-9 13:02 | 显示全部楼层
没看出来有什么区别啊
