[应用相关]
关于OLED iic驱动
3445|41
hanzhen654|  楼主 | 2018-9-16 23:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
enum _i2c_transfer_states
    kIdleState = 0x0U,             /*!< I2C bus idle. */
    kCheckAddressState = 0x1U,     /*!< 7-bit address check state. */
    kSendCommandState = 0x2U,      /*!< Send command byte phase. */
    kSendDataState = 0x3U,         /*!< Send data transfer phase. */
    kReceiveDataBeginState = 0x4U, /*!< Receive data transfer phase begin. */
    kReceiveDataState = 0x5U,      /*!< Receive data transfer phase. */
enum _i2c_flag_constants
/*! All flags which are cleared by the driver upon starting a transfer. */
#if defined(FSL_FEATURE_I2C_HAS_START_STOP_DETECT) && FSL_FEATURE_I2C_HAS_START_STOP_DETECT
    kClearFlags = kI2C_ArbitrationLostFlag | kI2C_IntPendingFlag | kI2C_StartDetectFlag | kI2C_StopDetectFlag,
    kIrqFlags = kI2C_GlobalInterruptEnable | kI2C_StartStopDetectInterruptEnable,
#elif defined(FSL_FEATURE_I2C_HAS_STOP_DETECT) && FSL_FEATURE_I2C_HAS_STOP_DETECT
    kClearFlags = kI2C_ArbitrationLostFlag | kI2C_IntPendingFlag | kI2C_StopDetectFlag,
    kIrqFlags = kI2C_GlobalInterruptEnable | kI2C_StopDetectInterruptEnable,
#else
    kClearFlags = kI2C_ArbitrationLostFlag | kI2C_IntPendingFlag,
    kIrqFlags = kI2C_GlobalInterruptEnable,
#endif
hanzhen654|  楼主 | 2018-9-16 23:02 | 只看该作者
const uint16_t s_i2cDividerTable[] = {20,   22,   24,   26,   28,   30,   34,   40,   28,   32,   36,   40,  44,
                                      48,   56,   68,   48,   56,   64,   72,   80,   88,   104,  128,  80,  96,
                                      112,  128,  144,  160,  192,  240,  160,  192,  224,  256,  288,  320, 384,
                                      480,  320,  384,  448,  512,  576,  640,  768,  960,  640,  768,  896, 1024,
                                      1152, 1280, 1536, 1920, 1280, 1536, 1792, 2048, 2304, 2560, 3072, 3840};
hanzhen654|  楼主 | 2018-9-16 23:09 | 只看该作者
uint32_t I2C_GetInstance(I2C_Type *base)
    uint32_t instance;
    /* Find the instance index from base address mappings. */
    for (instance = 0; instance < FSL_FEATURE_SOC_I2C_COUNT; instance++)
        if (s_i2cBases[instance] == base)
            break;
    assert(instance < FSL_FEATURE_SOC_I2C_COUNT);
    return instance;
hanzhen654|  楼主 | 2018-9-16 23:10 | 只看该作者
static status_t I2C_InitTransferStateMachine(I2C_Type *base, i2c_master_handle_t *handle, i2c_master_transfer_t *xfer)
    status_t result = kStatus_Success;
    i2c_direction_t direction = xfer->direction;
    uint16_t timeout = UINT16_MAX;
    /* Initialize the handle transfer information. */
    handle->transfer = *xfer;
    /* Save total transfer size. */
    handle->transferSize = xfer->dataSize;
    /* Initial transfer state. */
    if (handle->transfer.subaddressSize > 0)
        handle->state = kSendCommandState;
        if (xfer->direction == kI2C_Read)
            direction = kI2C_Write;
    else
        handle->state = kCheckAddressState;
    /* Wait until the data register is ready for transmit. */
    while ((!(base->S & kI2C_TransferCompleteFlag)) && (--timeout))
    /* Failed to start the transfer. */
    if (timeout == 0)
        return kStatus_I2C_Timeout;
    /* Clear all status before transfer. */
    I2C_MasterClearStatusFlags(base, kClearFlags);
    /* If repeated start is requested, send repeated start. */
    if (handle->transfer.flags & kI2C_TransferRepeatedStartFlag)
        result = I2C_MasterRepeatedStart(base, handle->transfer.slaveAddress, direction);
    else /* For normal transfer, send start. */
        result = I2C_MasterStart(base, handle->transfer.slaveAddress, direction);
    return result;
hanzhen654|  楼主 | 2018-9-16 23:11 | 只看该作者
static status_t I2C_CheckAndClearError(I2C_Type *base, uint32_t status)
    /* Check arbitration lost. */
    if (status & kI2C_ArbitrationLostFlag)
        /* Clear arbitration lost flag. */
        base->S = kI2C_ArbitrationLostFlag;
        result = kStatus_I2C_ArbitrationLost;
    /* Check NAK */
    else if (status & kI2C_ReceiveNakFlag)
        result = kStatus_I2C_Nak;
    else
    return result;
hanzhen654|  楼主 | 2018-9-16 23:12 | 只看该作者
static status_t I2C_MasterTransferRunStateMachine(I2C_Type *base, i2c_master_handle_t *handle, bool *isDone)
    uint32_t statusFlags = base->S;
    *isDone = false;
    volatile uint8_t dummy = 0;
    bool ignoreNak = ((handle->state == kSendDataState) && (handle->transfer.dataSize == 0U)) ||
                     ((handle->state == kReceiveDataState) && (handle->transfer.dataSize == 1U));
    /* Add this to avoid build warning. */
    dummy++;
    /* Check & clear error flags. */
    result = I2C_CheckAndClearError(base, statusFlags);
    /* Ignore Nak when it's appeared for last byte. */
    if ((result == kStatus_I2C_Nak) && ignoreNak)
    if (result)
        return result;
    /* Handle Check address state to check the slave address is Acked in slave
       probe application. */
    if (handle->state == kCheckAddressState)
        if (statusFlags & kI2C_ReceiveNakFlag)
            return kStatus_I2C_Nak;
        else
            if (handle->transfer.direction == kI2C_Write)
                /* Next state, send data. */
                handle->state = kSendDataState;
            else
                /* Next state, receive data begin. */
                handle->state = kReceiveDataBeginState;
    /* Run state machine. */
    switch (handle->state)
        /* Send I2C command. */
        case kSendCommandState:
            if (handle->transfer.subaddressSize)
                handle->transfer.subaddressSize--;
                base->D = ((handle->transfer.subaddress) >> (8 * handle->transfer.subaddressSize));
            else
                    /* Send first byte of data. */
                    if (handle->transfer.dataSize > 0)
                        base->D = *handle->transfer.data;
                        handle->transfer.data++;
                        handle->transfer.dataSize--;
                else
                    /* Send repeated start and slave address. */
                    result = I2C_MasterRepeatedStart(base, handle->transfer.slaveAddress, kI2C_Read);
            break;
        /* Send I2C data. */
        case kSendDataState:
            /* Send one byte of data. */
            else
                *isDone = true;
            break;
        /* Start I2C data receive. */
        case kReceiveDataBeginState:
            base->C1 &= ~(I2C_C1_TX_MASK | I2C_C1_TXAK_MASK);
            /* Send nak at the last receive byte. */
            if (handle->transfer.dataSize == 1)
                base->C1 |= I2C_C1_TXAK_MASK;
            /* Read dummy to release the bus. */
            dummy = base->D;
            /* Next state, receive data. */
            handle->state = kReceiveDataState;
            break;
        /* Receive I2C data. */
        case kReceiveDataState:
            /* Receive one byte of data. */
            if (handle->transfer.dataSize--)
                if (handle->transfer.dataSize == 0)
                    *isDone = true;
                    /* Send stop if kI2C_TransferNoStop is not asserted. */
                    if (!(handle->transfer.flags & kI2C_TransferNoStopFlag))
                        result = I2C_MasterStop(base);
                /* Send NAK at the last receive byte. */
                /* Read the data byte into the transfer buffer. */
                *handle->transfer.data = base->D;
            break;
        default:
            break;
    return result;
static void I2C_TransferCommonIRQHandler(I2C_Type *base, void *handle)
    /* Check if master interrupt. */
    if ((base->S & kI2C_ArbitrationLostFlag) || (base->C1 & I2C_C1_MST_MASK))
        s_i2cMasterIsr(base, handle);
    else
        s_i2cSlaveIsr(base, handle);
hanzhen654|  楼主 | 2018-9-16 23:13 | 只看该作者
void I2C_MasterInit(I2C_Type *base, const i2c_master_config_t *masterConfig, uint32_t srcClock_Hz)
    assert(masterConfig && srcClock_Hz);
    /* Temporary register for filter read. */
    uint8_t fltReg;
#if defined(FSL_FEATURE_I2C_HAS_HIGH_DRIVE_SELECTION) && FSL_FEATURE_I2C_HAS_HIGH_DRIVE_SELECTION
    uint8_t c2Reg;
#endif
    /* Enable I2C clock. */
    CLOCK_EnableClock(s_i2cClocks[I2C_GetInstance(base)]);
    /* Disable I2C prior to configuring it. */
    base->C1 &= ~(I2C_C1_IICEN_MASK);
    /* Clear all flags. */
    /* Configure baud rate. */
    I2C_MasterSetBaudRate(base, masterConfig->baudRate_Bps, srcClock_Hz);
    /* Configure high drive feature. */
    c2Reg = base->C2;
    c2Reg &= ~(I2C_C2_HDRS_MASK);
    c2Reg |= I2C_C2_HDRS(masterConfig->enableHighDrive);
    base->C2 = c2Reg;
#endif
    /* Read out the FLT register. */
    fltReg = base->FLT;
#if defined(FSL_FEATURE_I2C_HAS_STOP_HOLD_OFF) && FSL_FEATURE_I2C_HAS_STOP_HOLD_OFF
    /* Configure the stop / hold enable. */
    fltReg &= ~(I2C_FLT_SHEN_MASK);
    fltReg |= I2C_FLT_SHEN(masterConfig->enableStopHold);
#endif
    /* Configure the glitch filter value. */
    fltReg &= ~(I2C_FLT_FLT_MASK);
    fltReg |= I2C_FLT_FLT(masterConfig->glitchFilterWidth);
    /* Write the register value back to the filter register. */
    base->FLT = fltReg;
    /* Enable the I2C peripheral based on the configuration. */
    base->C1 = I2C_C1_IICEN(masterConfig->enableMaster);
hanzhen654|  楼主 | 2018-9-16 23:14 | 只看该作者
void I2C_MasterDeinit(I2C_Type *base)
    /* Disable I2C module. */
    I2C_Enable(base, false);
    /* Disable I2C clock. */
    CLOCK_DisableClock(s_i2cClocks[I2C_GetInstance(base)]);
void I2C_MasterGetDefaultConfig(i2c_master_config_t *masterConfig)
    assert(masterConfig);
    /* Default baud rate at 100kbps. */
    masterConfig->baudRate_Bps = 100000U;
/* Default pin high drive is disabled. */
    masterConfig->enableHighDrive = false;
#endif
/* Default stop hold enable is disabled. */
    masterConfig->enableStopHold = false;
#endif
    /* Default glitch filter value is no filter. */
    masterConfig->glitchFilterWidth = 0U;
    /* Enable the I2C peripheral. */
    masterConfig->enableMaster = true;
hanzhen654|  楼主 | 2018-9-16 23:17 | 只看该作者
void I2C_EnableInterrupts(I2C_Type *base, uint32_t mask)
    if (mask & kI2C_GlobalInterruptEnable)
        base->C1 |= I2C_C1_IICIE_MASK;
#if defined(FSL_FEATURE_I2C_HAS_STOP_DETECT) && FSL_FEATURE_I2C_HAS_STOP_DETECT
    if (mask & kI2C_StopDetectInterruptEnable)
        base->FLT |= I2C_FLT_STOPIE_MASK;
#endif /* FSL_FEATURE_I2C_HAS_STOP_DETECT */
    if (mask & kI2C_StartStopDetectInterruptEnable)
        base->FLT |= I2C_FLT_SSIE_MASK;
#endif /* FSL_FEATURE_I2C_HAS_START_STOP_DETECT */
void I2C_DisableInterrupts(I2C_Type *base, uint32_t mask)
        base->C1 &= ~I2C_C1_IICIE_MASK;
        base->FLT &= ~I2C_FLT_STOPIE_MASK;
        base->FLT &= ~I2C_FLT_SSIE_MASK;
void I2C_MasterSetBaudRate(I2C_Type *base, uint32_t baudRate_Bps, uint32_t srcClock_Hz)
    uint32_t multiplier;
    uint32_t computedRate;
    uint32_t absError;
    uint32_t bestError = UINT32_MAX;
    uint32_t bestMult = 0u;
    uint32_t bestIcr = 0u;
    uint8_t mult;
    uint8_t i;
    /* Search for the settings with the lowest error. Mult is the MULT field of the I2C_F register,
     * and ranges from 0-2. It selects the multiplier factor for the divider. */
    for (mult = 0u; (mult <= 2u) && (bestError != 0); ++mult)
        multiplier = 1u << mult;
        /* Scan table to find best match. */
        for (i = 0u; i < sizeof(s_i2cDividerTable) / sizeof(uint16_t); ++i)
            computedRate = srcClock_Hz / (multiplier * s_i2cDividerTable[i]);
            absError = baudRate_Bps > computedRate ? (baudRate_Bps - computedRate) : (computedRate - baudRate_Bps);
            if (absError < bestError)
                bestMult = mult;
                bestIcr = i;
                bestError = absError;
                /* If the error is 0, then we can stop searching because we won't find a better match. */
                if (absError == 0)
                    break;
    /* Set frequency register based on best settings. */
    base->F = I2C_F_MULT(bestMult) | I2C_F_ICR(bestIcr);
hanzhen654|  楼主 | 2018-9-16 23:18 | 只看该作者
status_t I2C_MasterStart(I2C_Type *base, uint8_t address, i2c_direction_t direction)
    uint32_t statusFlags = I2C_MasterGetStatusFlags(base);
    /* Return an error if the bus is already in use. */
    if (statusFlags & kI2C_BusBusyFlag)
        result = kStatus_I2C_Busy;
    else
        /* Send the START signal. */
        base->C1 |= I2C_C1_MST_MASK | I2C_C1_TX_MASK;
#if defined(FSL_FEATURE_I2C_HAS_DOUBLE_BUFFERING) && FSL_FEATURE_I2C_HAS_DOUBLE_BUFFERING
        while (!(base->S2 & I2C_S2_EMPTY_MASK))
#endif /* FSL_FEATURE_I2C_HAS_DOUBLE_BUFFERING */
        base->D = (((uint32_t)address) << 1U | ((direction == kI2C_Read) ? 1U : 0U));
    return result;
hanzhen654|  楼主 | 2018-9-16 23:19 | 只看该作者
status_t I2C_MasterRepeatedStart(I2C_Type *base, uint8_t address, i2c_direction_t direction)
    uint8_t savedMult;
    uint8_t timeDelay = 6;
    /* Return an error if the bus is already in use, but not by us. */
    if ((statusFlags & kI2C_BusBusyFlag) && ((base->C1 & I2C_C1_MST_MASK) == 0))
    else
        savedMult = base->F;
        base->F = savedMult & (~I2C_F_MULT_MASK);
        /* We are already in a transfer, so send a repeated start. */
        base->C1 |= I2C_C1_RSTA_MASK;
        /* Restore the multiplier factor. */
        base->F = savedMult;
        /* Add some delay to wait the Re-Start signal. */
        while (timeDelay--)
            __NOP();
    return result;
hanzhen654|  楼主 | 2018-9-16 23:20 | 只看该作者
status_t I2C_MasterStop(I2C_Type *base)
    /* Issue the STOP command on the bus. */
    base->C1 &= ~(I2C_C1_MST_MASK | I2C_C1_TX_MASK | I2C_C1_TXAK_MASK);
    /* Wait until data transfer complete. */
    while ((base->S & kI2C_BusBusyFlag) && (--timeout))
    if (timeout == 0)
        result = kStatus_I2C_Timeout;
    return result;
uint32_t I2C_MasterGetStatusFlags(I2C_Type *base)
#ifdef I2C_HAS_STOP_DETECT
    /* Look up the STOPF bit from the filter register. */
    if (base->FLT & I2C_FLT_STOPF_MASK)
        statusFlags |= kI2C_StopDetectFlag;
#endif
    /* Look up the STARTF bit from the filter register. */
    if (base->FLT & I2C_FLT_STARTF_MASK)
        statusFlags |= kI2C_StartDetectFlag;
    return statusFlags;
hanzhen654|  楼主 | 2018-9-16 23:21 | 只看该作者
status_t I2C_MasterWriteBlocking(I2C_Type *base, const uint8_t *txBuff, size_t txSize)
    uint8_t statusFlags = 0;
    while (!(base->S & kI2C_TransferCompleteFlag))
    /* Clear the IICIF flag. */
    base->S = kI2C_IntPendingFlag;
    /* Setup the I2C peripheral to transmit data. */
    base->C1 |= I2C_C1_TX_MASK;
    while (txSize--)
        /* Send a byte of data. */
        base->D = *txBuff++;
        while (!(base->S & kI2C_IntPendingFlag))
        /* Check if arbitration lost or no acknowledgement (NAK), return failure status. */
        if (statusFlags & kI2C_ArbitrationLostFlag)
            base->S = kI2C_ReceiveNakFlag;
        if (result != kStatus_Success)
            /* Breaking out of the send loop. */
            break;
    return result;
status_t I2C_MasterReadBlocking(I2C_Type *base, uint8_t *rxBuff, size_t rxSize)
    dummy++;
    /* Setup the I2C peripheral to receive data. */
    /* If rxSize equals 1, configure to send NAK. */
    if (rxSize == 1)
        /* Issue NACK on read. */
    /* Do dummy read. */
    dummy = base->D;
    while ((rxSize--))
        /* Single byte use case. */
        if (rxSize == 0)
            /* Read the final byte. */
        if (rxSize == 1)
        /* Read from the data register. */
        *rxBuff++ = base->D;
    return result;
