[技术问答]
关于N76E003 TIMER2输入捕获问题
1511|8
c475301174|  楼主 | 2018-9-17 16:42 | 显示全部楼层 |阅读模式
输入捕获每次捕捉到的数据都相差很大 换算出来的周期也跟实际不相符   不知道什么原因   有了解的看看,解答解答
wanduzi| | 2018-9-17 18:19 | 显示全部楼层
对象是稳定的周期信号吗
heisexingqisi| | 2018-9-17 23:31 | 显示全部楼层
/* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technoledge Corp.
//  Website: http://www.nuvoton.com
//  E-Mail : MicroC-8bit@nuvoton.com
//  Date   : Apr/21/2017
//  File Function: N76E003 Timer2 Capture Mode demo code
#include "N76E003.h"
#include "Common.h"
#include "Delay.h"
#include "SFR_Macro.h"
#include "Function_define.h"
//*****************  The Following is in define in Fucntion_define.h  ***************************
//****** Always include Function_define.h call the define you want, detail see main(void) *******
#if 0
////-------------------- Timer2 Capture define --------------------
////--- Falling Edge -----
//#define IC0_P12_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC1_P11_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x01;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC2_P10_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x02;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC3_P00_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x03;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC3_P04_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x04;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC4_P01_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x05;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC5_P03_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x06;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC6_P05_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x07;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC7_P15_CAP0_FallingEdge_Capture                CAPCON1&=0xFC;CAPCON3&=0xF0;CAPCON3|=0x08;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define IC0_P12_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define        IC1_P11_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x10;CAPCON0|=SET_BIT5;CAPCON0|=SET_BIT5
//#define        IC2_P10_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x20;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define        IC3_P00_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x30;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define        IC3_P04_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x40;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define        IC4_P01_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x50;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define        IC5_P03_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x60;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define        IC6_P05_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x70;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define        IC7_P15_CAP1_FallingEdge_Capture                CAPCON1&=0xF3;CAPCON3&=0x0F;CAPCON3|=0x80;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define IC0_P12_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
//#define        IC1_P11_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x10;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
//#define        IC2_P10_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x20;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
//#define        IC3_P00_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x30;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
//#define        IC3_P04_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x40;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
//#define        IC4_P01_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x50;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
//#define        IC5_P03_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x60;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
//#define        IC6_P05_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x70;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
//#define        IC7_P15_CAP2_FallingEdge_Capture                CAPCON1&=0x0F;CAPCON4&=0xF0;CAPCON4|=0x80;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6
////----- Rising edge ----
//#define IC0_P12_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define        IC1_P11_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x01;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define        IC2_P10_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x02;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define        IC3_P00_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x03;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define        IC3_P04_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x04;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define        IC4_P01_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x05;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define        IC5_P03_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x06;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define        IC6_P05_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x07;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define        IC7_P15_CAP0_RisingEdge_Capture                        CAPCON1&=0xFC;CAPCON1|=0x01;CAPCON3&=0xF0;CAPCON3|=0x08;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4;
//#define IC0_P12_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0FCAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC1_P11_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x10;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC2_P10_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x20;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC3_P00_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x30;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC3_P04_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x40;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC4_P01_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x50;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC5_P03_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x60;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC6_P05_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x70;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC7_P15_CAP1_RisingEdge_Capture                        CAPCON1&=0xF3;CAPCON1|=0x04;CAPCON3&=0x0F;CAPCON3|=0x80;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define IC0_P12_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC1_P11_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x01;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC2_P10_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x02;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC3_P00_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x03;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC3_P04_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x04;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC4_P01_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x05;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC5_P03_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x06;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC6_P05_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x07;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC7_P15_CAP3_RisingEdge_Capture                        CAPCON1&=0x0F;CAPCON1|=0x10;CAPCON4&=0xF0;CAPCON4|=0x08;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
////-----BOTH  edge ----
//#define IC0_P12_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC1_P11_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x01;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC2_P10_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x02;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC3_P00_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x03;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC3_P04_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x04;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC4_P01_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x05;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC5_P03_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x06;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC6_P05_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x07;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define        IC7_P15_CAP0_BothEdge_Capture                                CAPCON1&=0xFC;CAPCON1|=0x02;CAPCON3&=0xF0;CAPCON3|=0x08;CAPCON0|=SET_BIT4;CAPCON2|=SET_BIT4
//#define IC0_P12_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5
//#define        IC1_P11_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x10;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC2_P10_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x20;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC3_P00_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x30;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC3_P04_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x40;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC4_P01_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x50;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC5_P03_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x60;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC6_P05_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x70;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define        IC7_P15_CAP1_BothEdge_Capture                                CAPCON1&=0xF3;CAPCON1|=0x08;CAPCON3&=0x0F;CAPCON3|=0x80;CAPCON0|=SET_BIT5;CAPCON2|=SET_BIT5;
//#define IC0_P12_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC1_P11_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x01;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC2_P10_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x02;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC3_P00_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x03;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC3_P04_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x04;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC4_P01_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x05;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC5_P03_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x06;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC6_P05_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x07;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define        IC7_P15_CAP3_BothEdge_Capture                                CAPCON1&=0x0F;CAPCON1|=0x20;CAPCON4&=0xF0;CAPCON4|=0x08;CAPCON0|=SET_BIT6;CAPCON2|=SET_BIT6;
//#define TIMER2_IC2_DISABLE        CAPCON0&=~SET_BIT6
//#define TIMER2_IC1_DISABLE        CAPCON0&=~SET_BIT5
//#define TIMER2_IC0_DISABLE        CAPCON0&=~SET_BIT4
//*    Timer2 mode define
//#define         TIMER2_CAP0_Capture_Mode                        T2CON&=~SET_BIT0;T2MOD=0x89
//#define         TIMER2_CAP1_Capture_Mode                        T2CON&=~SET_BIT0;T2MOD=0x8A
//#define         TIMER2_CAP2_Capture_Mode                        T2CON&=~SET_BIT0;T2MOD=0x8B
//*   Timer devider define
//#define TIMER2_DIV_4                        T2MOD|=0x10;T2MOD&=0x9F
//#define TIMER2_DIV_16                        T2MOD|=0x20;T2MOD&=0xAF
//#define TIMER2_DIV_32                        T2MOD|=0x30;T2MOD&=0xBF
//#define TIMER2_DIV_64                        T2MOD|=0x40;T2MOD&=0xCF
//#define TIMER2_DIV_128                T2MOD|=0x50;T2MOD&=0xDF
//#define TIMER2_DIV_256                T2MOD|=0x60;T2MOD&=0xEF
//#define TIMER2_DIV_512                T2MOD|=0x70
#endif
*    Timer2 Capture interrupt subroutine
void Capture_ISR (void) interrupt 12
        clr_CAPF0;                          // clear capture0 interrupt flag
        P1 = C0L;        // For capture mode CxL/CxH with data capture from I/O pin
        P2 = C0H;
        P12 = ~P12;        //toggle GPIO1 to show int
                                printf("\n TM2 CAP 0x%bX",C0H);
                                clr_TF2;
*    Main function
void main (void)
    Set_All_GPIO_Quasi_Mode;
                InitialUART0_Timer3(115200);
                P00_Input_Mode;
                P00 = 1;
                TIMER2_CAP0_Capture_Mode;
                IC3_P00_CAP0_BothEdge_Capture;
                set_ECAP;                                   //Enable Capture interrupt
                set_TR2;                                    //Triger Timer2
                set_EA;
    while(1);
试试上面这个官方的例子
heisexingqisi| | 2018-9-17 23:35 | 显示全部楼层
如果这个例子没问题,那就是你配置不对
heisexingqisi| | 2018-9-17 23:51 | 显示全部楼层
P05要输入模式。
另外捕获中断也要读取数据啊。
jasontu| | 2018-9-18 09:04 | 显示全部楼层
要看你灌迈去的波形,看起来不是固定的波形
c475301174|  楼主 | 2018-9-18 14:33 | 显示全部楼层
已经解决了  谢谢各位解答
739705ba09c23a2606.png 顺序反一下
