[DemoCode下载]
M480的断电模式使用定时器中断唤醒
1295|5
heisexingqisi|  楼主 | 2018-9-18 22:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* [url=home.php?mod=space&uid=247401]@brief[/url]    Use timer to wake up system from Power-down mode periodically.
* [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2017 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NuMicro.h"
void TMR0_IRQHandler(void)
    // Clear wake up flag
    TIMER_ClearWakeupFlag(TIMER0);
    // Clear interrupt flag
    TIMER_ClearIntFlag(TIMER0);
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
    PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
    /* Set X32_OUT(PF.4) and X32_IN(PF.5) to input mode */
    PF->MODE &= ~(GPIO_MODE_MODE4_Msk | GPIO_MODE_MODE5_Msk);
    /* Enable External XTAL (4~24 MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Enable LXT */
    CLK_EnableXtalRC(CLK_PWRCTL_LXTEN_Msk);
    /* Waiting for 12MHz clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Waiting for LIRC clock stable */
    CLK_WaitClockReady(CLK_STATUS_LXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(FREQ_192MHZ);
    /* Set both PCLK0 and PCLK1 as HCLK/2 */
    CLK->PCLKDIV = CLK_PCLKDIV_PCLK0DIV2 | CLK_PCLKDIV_PCLK1DIV2;
    /* Select Timer clock source from LIRC */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(TMR0_MODULE);
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_LXT, 0);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Set GPB multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
    SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
    /* Lock protected registers */
    SYS_LockReg();
int main(void)
    int i = 0;
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
    printf("Timer power down/wake up sample code\n");
    while(!UART_IS_TX_EMPTY(UART0));
    /* Initial Timer0 to periodic mode with 1Hz, since system is fast (192MHz)
       and timer is slow (32kHz), and following function calls all modified timer's
       CTL register, so add extra delay between each function call and make sure the
       setting take effect */
    TIMER_Open(TIMER0, TIMER_PERIODIC_MODE, 1);
    CLK_SysTickDelay(50);
    /* Enable timer wake up system */
    TIMER_EnableWakeup(TIMER0);
    /* Enable Timer0 interrupt */
    TIMER_EnableInt(TIMER0);
    NVIC_EnableIRQ(TMR0_IRQn);
    /* Start Timer0 counting */
    TIMER_Start(TIMER0);
    SYS_UnlockReg();
    while(1)
        CLK_PowerDown();
        printf("Wake %d\n", i++);
/*** (C) COPYRIGHT 2017 Nuvoton Technology Corp. ***/
heisexingqisi|  楼主 | 2018-9-18 22:38 | 只看该作者
看看,跟其他系列的方式是一样的。新唐不同系列的代码兼容做的很给力。
wanduzi| | 2018-9-18 23:25 | 只看该作者
一个指令就低功耗了,一个中断就触发唤醒了。
yiyigirl2014| | 2018-9-19 00:05 | 只看该作者
仔细阅读,掌握整个流程。对比手册说明的流程,就懂了。
zhuomuniao110| | 2018-9-19 16:38 | 只看该作者
好像只要能正常运行的中断都可以唤醒,比如IO。
IO中断也可以唤醒。
