用于 C2000 实时控制开发套件的 F28379D controlCARD TMDSCNCD28379D
1253|23
dirtwillfly|  楼主 | 2018-9-20 22:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
描述
The Delfino F28379D controlCARD from Texas Instruments is Position Manager-ready and an ideal product for initial software development and short run builds for system prototypes, test stands, and many other projects that require easy access to high-performance controllers.  All C2000 controlCARDs are complete board-level modules that utilize a HSEC180 or DIMM100 form factor to provide a low-profile single-board controller solution. The host system needs to provide only a single 5V power rail to the controlCARD for it to be fully functional.
特性
  • Supports the new DesignDRIVE Position Manager Technology - EnDat22, BiSS-C, SIN/COS, Resolver and incremental encoders when used with the IDDK
包含项目
  • Delfino F28379D controlCARD
dirtwillfly|  楼主 | 2018-9-20 22:22 | 只看该作者
C2000 Position Manager PTO Library.pdf (295.63 KB)
dirtwillfly|  楼主 | 2018-9-20 22:33 | 只看该作者
TMS320F2837xD Dual-Core Delfino Microcontrollers Technical Reference Manual.pdf (13.44 MB)
C2000 Position Manager T-Format Library Module User's Guide.pdf (328.21 KB)
Using Position Manager T-Format Library on IDDK HW and SW User's Guide.pdf (2.11 MB)
dirtwillfly|  楼主 | 2018-9-20 22:34 | 只看该作者
Delfino TMS320F28379D controlCARD R1.3.pdf (563.22 KB)
DesignDRIVE Development Kit IDDK v2.2.1 - User’s Guide.pdf (2.1 MB)
DesignDRIVE Development Kit IDDK v2.2.1 - Hardware Reference Guide.pdf (22.87 MB)
dirtwillfly|  楼主 | 2018-9-20 22:35 | 只看该作者
C2000 Position Manager BISS-C LibraryUser's Guide.pdf (329.8 KB)
Using Position Manager BiSS-C Library on IDDK2.2 User's Guide.pdf (1.17 MB)
C2000 Position Manager EnDat22 Library Module User's Guide.pdf (1.08 MB)
Using Position Manager EnDat22 Library on IDDK2.2 HW & SW User's Guide.pdf (3.89 MB)
dirtwillfly|  楼主 | 2018-9-20 22:37 | 只看该作者
设计下一代工业驱动和控制系统.pdf (864.59 KB)
Charging stations Toward an EV support infrastructure.pdf (1.35 MB)
Designing the Next Generation of Industrial Drive and Control Systems.pdf (1.96 MB)
dirtwillfly|  楼主 | 2018-9-20 22:39 | 只看该作者
17
kkzz| | 2018-9-26 20:30 | 只看该作者
TMS320F28335很好用。
pixhw| | 2018-9-26 20:30 | 只看该作者
这个板子价格怎么样?
dirtwillfly 2018-9-26 21:59 回复TA
官网的标价是159美元
19
pixhw| | 2018-9-26 20:31 | 只看该作者
C2000 就不如C5000的效率高一些了。
dirtwillfly 2018-9-26 22:00 回复TA
是的,但c2000比c5000价格更便宜
20
kkzz| | 2018-9-26 20:32 | 只看该作者
主要是执行的效率怎么样的
dirtwillfly 2018-9-26 22:01 回复TA
做实时控制足够了
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1179
