[DemoCode下载]
M451的DSP库操作PID控制
950|1
xinpian101|  楼主 | 2018-9-25 22:53 | 显示全部楼层 |阅读模式
EC_M451_DSP_PID_Controller_V1.0.zip (4.35 MB)
xinpian101|  楼主 | 2018-9-25 22:54 | 显示全部楼层
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.0
* $Date: 15/09/02 10:04a $
* @brief
*         Display how to use M4 DSP PID Controller
*                      and compare with calcultion without DSP
* @note
* Copyright (C) 2016 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#include "arm_math.h"
#define USE_DSP
int i,j,CalTime;
arm_pid_instance_f32 PIDS;
float32_t output[100],ee;
float A0,A1,A2,state[3],Kp=0.4,Ki=0.4,Kd=0,target,ival;
float PID(float in)
    float out;
                A0=Kp+Ki;
                A1 = -Kp-(2* Kd);
                A2 = Kd;
    /* y[n] = y[n-1] + A0 * x[n] + A1 * x[n-1] + A2 * x[n-2]  */
    out = (A0 * in) + (A1 * state[0]) + (A2 * state[1]) + (state[2]);
    /* Update state */
    state[1] = state[0];
    state[0] = in;
    state[2] = out;
    /* return to application */
    return (out);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL and SysTick source to HCLK/2*/
    CLK_SetCoreClock(72000000);
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HCLK_DIV2);
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(TMR0_MODULE);
    /* Peripheral clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, CLK_CLKDIV0_UART(1));
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, 0);
void UART_Init(void)
    /* Set PD multi-function pins for UART0 RXD, TXD */
    SYS->GPD_MFPL = SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD;
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
          uint32_t i;
                PIDS.Kp=0.4;
                PIDS.Ki=0.4;
                PIDS.Kd=0;
                /* Target value*/
                target=500;
                /* Inital value */
                ival=0;
                /* Initial value and target value error */
                ee=target-ival;
                /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART for printf */
    UART_Init();
                TIMER_Open(TIMER0, TIMER_CONTINUOUS_MODE, 1);
                TIMER_Start(TIMER0);
#ifdef USE_DSP
                /* Initial DSP PID controller function*/
                arm_pid_init_f32(&PIDS,0);
                /* Calculate PID controller function 100 times*/
                for(i=1;i<100;i++)
                        output[i]=arm_pid_f32(&PIDS,ee);
                        //printf("%0.2f\n",output[i]);
                        /* Update error */
                        ee=target-output[i-1];
#else
                for(i=1;i<100;i++)
                        output[i]=PID(ee);
#endif
          TIMER_Close(TIMER0);
                CalTime=TIMER_GetCounter(TIMER0);
                printf("time is %d \n",CalTime);
    while(1);                             /* main function does not return */
