[DemoCode下载] 分享一个M451简单的点灯程序
1173|10
 楼主| dongnanxibei 发表于 2018-9-28 12:08 | 显示全部楼层 |阅读模式
ck, TE, se, rc
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
  4. * $Date: 15/09/02 10:03a $
  5. * [url=home.php?mod=space&uid=247401]@brief[/url]    Toggle PC.9 to turn on / off the board LED
  6. *
  7. * @note
  8. * Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
  9. *
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "M451Series.h"
  13. #define HCLK_CLOCK       72000000
  14. void SYS_Init(void)
  15. {
  16.     /*---------------------------------------------------------------------------------------------------------*/
  17.     /* Init System Clock        */
  18.     /*---------------------------------------------------------------------------------------------------------*/
  19.     /* Unlock protected registers */
  20.     SYS_UnlockReg();
  21.     /* Enable HIRC clock (Internal RC 22.1184MHz) */
  22.     CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
  23.     /* Wait for HIRC clock ready */
  24.     CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
  25.     /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
  26.     CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
  27.     /* Enable HXT clock (external XTAL 12MHz) */
  28.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  29.     /* Wait for HXT clock ready */
  30.     CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
  31.     /* Set core clock as HCLK_CLOCK */
  32.     CLK_SetCoreClock(HCLK_CLOCK);
  33.     /* Update System Core Clock */
  34.     /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
  35.     SystemCoreClockUpdate();
  36.     /*---------------------------------------------------------------------------------------------------------*/
  37.     /* Init I/O Multi-function        */
  38.     /*---------------------------------------------------------------------------------------------------------*/
  39.     /* Set GPD multi-function pins for UART0 RXD and TXD */
  40.     SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
  41.     SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
  42.     /* Lock protected registers */
  43.     SYS_LockReg();
  44. }
  45. /*---------------------------------------------------------------------------------------------------------*/
  46. /* MAIN function        */
  47. /*---------------------------------------------------------------------------------------------------------*/
  48. int main(void)
  49. {
  50.     /* Init System, IP clock and multi-function I/O
  51.        In the end of SYS_Init() will issue SYS_LockReg()
  52.        to lock protected register. If user want to write
  53.        protected register, please issue SYS_UnlockReg()
  54.        to unlock protected register if necessary */
  55.     SYS_Init();
  56.     /* Select SysTick clock source as HXT */
  57.     CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HXT);
  58.     /* Configure PC.9 as Output mode */
  59.     GPIO_SetMode(PC, BIT9, GPIO_MODE_OUTPUT);
  60.     while(1)
  61.     {
  62.         /* Configure PC.9 to low */
  63.         PC9 = 0;
  64.         /* Delay 200 ms */
  65.         CLK_SysTickDelay(200000);
  66.         /* Configure PC.9 to high */
  67.         PC9 = 1;
  68.         /* Delay 200 ms */
  69.         CLK_SysTickDelay(200000);
  70.     }
  71. }
那么如何用PWM改成呼吸灯呢?
wahahaheihei 发表于 2018-9-28 19:42 | 显示全部楼层
看着简单,实际上可以看出这个时钟配置的方式。
643757107 发表于 2018-9-28 21:41 | 显示全部楼层
时钟的配置看着结构图很容易,新唐的结构图做的比ST好。
天灵灵地灵灵 发表于 2018-9-29 15:06 | 显示全部楼层
看来用这个定时器比较好。
晓伍 发表于 2018-9-30 09:50 | 显示全部楼层
看似简单 要做的细致比较费劲
丢丢手绢666 发表于 2018-10-9 15:01 来自手机 | 显示全部楼层
用这个定时器确实不错
fsss007 发表于 2018-11-3 21:43 | 显示全部楼层
学习了,用这个定时器确实不错。
wanduzi 发表于 2018-11-7 14:22 | 显示全部楼层
定时器延时比较给力。
观海 发表于 2018-11-8 12:49 | 显示全部楼层
看着简单 做细致了也不容易
heisexingqisi 发表于 2018-11-11 21:28 | 显示全部楼层
是的,看着简单,时钟玩的转都要下功夫。
