返回列表 发新帖
GD32 SD卡驱动
楼主: chenqiang10
 楼主 | 2018-9-30 19:51 | 显示全部楼层
static SD_Err Check_Err_R1(uint8_t cmd)
    SD_Err Status = SD_OK;
    uint32_t status;
    uint32_t response_r1;
    status = SDIO->STR;
    while (!(status & (SDIO_FLAG_CCRCFAIL | SDIO_FLAG_CMDREND | SDIO_FLAG_CMDTMOUT)))
        status = SDIO->STR;
    if (status & SDIO_FLAG_CMDTMOUT)
        Status = SD_CMD_RSP_TIMEOUT;
        SDIO_ClearBitState(SDIO_FLAG_CMDTMOUT);
        return(Status);
    else if (status & SDIO_FLAG_CCRCFAIL)
        Status = SD_CMD_CRC_FAIL;
        SDIO_ClearBitState(SDIO_FLAG_CCRCFAIL);
        return(Status);
    /* Check response received is of desired command */
    if (SDIO_GetCMDResponse() != cmd)
        Status = SD_ILLEGAL_CMD;
        return(Status);
    /* Clear all the static flags */
    SDIO_ClearBitState(SDIO_STATIC_FLAGS);
    /* We have received response, retrieve it for analysis  */
    response_r1 = SDIO_GetResponse(SDIO_RESP1);
    if ((response_r1 & SD_R1_ERRORBITS) == SD_ALLZERO)//no error
        return(Status);
    if (response_r1 & SD_R1_ADDR_OUT_OF_RANGE)
        return(SD_ADDR_OUT_OF_RANGE);
    if (response_r1 & SD_R1_ADDR_MISALIGNED)
        return(SD_ADDR_MISALIGNED);
    if (response_r1 & SD_R1_BLOCK_LEN_ERR)
        return(SD_BLOCK_LEN_ERR);
    if (response_r1 & SD_R1_ERASE_SEQ_ERR)
        return(SD_ERASE_SEQ_ERR);
    if (response_r1 & SD_R1_BAD_ERASE_PARAM)
        return(SD_BAD_ERASE_PARAM);
    if (response_r1 & SD_R1_WRITE_PROT_VIOLATION)
        return(SD_WRITE_PROT_VIOLATION);
    if (response_r1 & SD_R1_LOCK_UNLOCK_FAILED)
        return(SD_LOCK_UNLOCK_FAILED);
    if (response_r1 & SD_R1_COM_CRC_FAILED)
        return(SD_COM_CRC_FAILED);
    if (response_r1 & SD_R1_ILLEGAL_CMD)
        return(SD_ILLEGAL_CMD);
    if (response_r1 & SD_R1_CARD_ECC_FAILED)
        return(SD_CARD_ECC_FAILED);
    if (response_r1 & SD_R1_CC_ERROR)
        return(SD_CC_ERROR);
    if (response_r1 & SD_R1_GENERAL_UNKNOWN_ERROR)
    return(SD_GENERAL_UNKNOWN_ERROR);
    if (response_r1 & SD_R1_STREAM_READ_UNDERRUN)
        return(SD_STREAM_READ_UNDERRUN);
    if (response_r1 & SD_R1_STREAM_WRITE_OVERRUN)
    return(SD_STREAM_WRITE_OVERRUN);
    if (response_r1 & SD_R1_CID_CSD_OVERWRIETE)
        return(SD_CID_CSD_OVERWRITE);
    if (response_r1 & SD_R1_WP_ERASE_SKIP)
        return(SD_WP_ERASE_SKIP);
    if (response_r1 & SD_R1_CARD_ECC_DISABLED)
        return(SD_CARD_ECC_DISABLED);
    if (response_r1 & SD_R1_ERASE_RESET)
        return(SD_ERASE_RESET);
    if (response_r1 & SD_R1_AKE_SEQ_ERROR)
        return(SD_AKE_SEQ_ERROR);
    return(Status);
 楼主 | 2018-9-30 19:52 | 显示全部楼层
static SD_Err Check_Err_R3(void)
    uint32_t status;
    status = SDIO->STR;
        status = SDIO->STR;
        return(Status);
    return(Status);
static SD_Err Check_Err_R2(void)
    uint32_t status;
    status = SDIO->STR;
        status = SDIO->STR;
        return(Status);
        return(Status);
    return(Status);
static SD_Err Check_Err_R6(uint8_t cmd, uint16_t *prca)
    uint32_t status;
    status = SDIO->STR;
        status = SDIO->STR;
        return(Status);
        return(Status);
        return(Status);
    /* We have received response, retrieve it.  */
    if (SD_ALLZERO == (response_r1 & (SD_R6_GENERAL_UNKNOWN_ERROR | SD_R6_ILLEGAL_CMD | SD_R6_COM_CRC_FAILED)))
        *prca = (uint16_t) (response_r1 >> 16);
        return(Status);
    if (response_r1 & SD_R6_GENERAL_UNKNOWN_ERROR)
    if (response_r1 & SD_R6_ILLEGAL_CMD)
    if (response_r1 & SD_R6_COM_CRC_FAILED)
    return(Status);
 楼主 | 2018-9-30 19:53 | 显示全部楼层
static SD_Err WideBus_Enable(TypeState NewState)
    /* Check whether the card is locked */
    if (SDIO_GetResponse(SDIO_RESP1) & SD_CARD_LOCKED)
        Status = SD_LOCK_UNLOCK_FAILED;
        return(Status);
    /* Get SCR Register */
    Status = Get_SCR(RCA, Scr);
    if (Status != SD_OK)
        return(Status);
    /* If wide bus operation to be enabled */
    if (NewState == ENABLE)
        /* If requested card supports wide bus operation */
        if ((Scr[1] & SD_WIDE_BUS_SUPPORT) != SD_ALLZERO)
            /* Send CMD55 APP_CMD with argument as card's RCA.*/
            SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t) RCA << 16;
            SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_APP_CMD;
            SDIO_CmdInitStructure.SDIO_ResponseType = SDIO_RESPONSETYPE_SHORT;
            SDIO_CmdInitStructure.SDIO_WaitINTState = SDIO_WAITINTSTATE_NO;
            SDIO_CmdInitStructure.SDIO_CSMState = SDIO_CSMSTATE_ENABLE;
            SDIO_SendCMD(&SDIO_CmdInitStructure);
            Status = Check_Err_R1(SDIO_APP_CMD);
                return(Status);
            /* Send ACMD6 APP_CMD with argument as 2 for wide bus mode */
            SDIO_CmdInitStructure.SDIO_CMDParameter = 0x2;
            SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_APP_SD_SET_BUSWIDTH;
            Status = Check_Err_R1(SDIO_APP_SD_SET_BUSWIDTH);
                return(Status);
            return(Status);
        else
            Status = SD_REQUEST_NOT_APPLICABLE;
            return(Status);
    }   /* If wide bus operation to be disabled */
    else
        /* If requested card supports 1 bit mode operation */
        if ((Scr[1] & SD_SINGLE_BUS_SUPPORT) != SD_ALLZERO)
            /* Check CMD errors */
                return(Status);
            SDIO_CmdInitStructure.SDIO_CMDParameter = 0x00;
                return(Status);
            return(Status);
        else
            return(Status);
static SD_Err IsCardProgramming(uint8_t *pstatus)
    __IO uint32_t respR1 = 0, status = 0;
    /* CMD13 to polling the state of the card */
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SEND_STATUS;
    status = SDIO->STR;
        status = SDIO->STR;
        return(Status);
        return(Status);
    status = (uint32_t)SDIO_GetCMDResponse();
    if (status != SDIO_SEND_STATUS)
        return(Status);
    respR1 = SDIO_GetResponse(SDIO_RESP1);
    /* Find out card status */
    *pstatus = (uint8_t) ((respR1 >> 9) & 0x0000000F);
    if ((respR1 & SD_R1_ERRORBITS) == SD_ALLZERO)
        return(Status);
    if (respR1 & SD_R1_ADDR_OUT_OF_RANGE)
    if (respR1 & SD_R1_ADDR_MISALIGNED)
    if (respR1 & SD_R1_BLOCK_LEN_ERR)
    if (respR1 & SD_R1_ERASE_SEQ_ERR)
    if (respR1 & SD_R1_BAD_ERASE_PARAM)
    if (respR1 & SD_R1_WRITE_PROT_VIOLATION)
    if (respR1 & SD_R1_LOCK_UNLOCK_FAILED)
    if (respR1 & SD_R1_COM_CRC_FAILED)
    if (respR1 & SD_R1_ILLEGAL_CMD)
    if (respR1 & SD_R1_CARD_ECC_FAILED)
    if (respR1 & SD_R1_CC_ERROR)
    if (respR1 & SD_R1_GENERAL_UNKNOWN_ERROR)
    if (respR1 & SD_R1_STREAM_READ_UNDERRUN)
    if (respR1 & SD_R1_STREAM_WRITE_OVERRUN)
    if (respR1 & SD_R1_CID_CSD_OVERWRIETE)
    if (respR1 & SD_R1_WP_ERASE_SKIP)
    if (respR1 & SD_R1_CARD_ECC_DISABLED)
    if (respR1 & SD_R1_ERASE_RESET)
    if (respR1 & SD_R1_AKE_SEQ_ERROR)
    return(Status);
static SD_Err Get_SCR(uint16_t rca, uint32_t *pscr)
    uint32_t index = 0;
    uint32_t tempscr[2] = {0, 0};
    /* Set Block Size To 8 Bytes */
    /* Send CMD8 SDIO_SET_BLOCKLEN to set block size */
    SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t)8;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SET_BLOCKLEN;
    Status = Check_Err_R1(SDIO_SET_BLOCKLEN);
        return(Status);
    /* CMD55 APP_CMD the next command is Application Specific Command */
        return(Status);
    /* SDIO data transmisson config */
    SDIO_DataInitStructure.SDIO_DataTimeOut = SD_DATATIMEOUT;
    SDIO_DataInitStructure.SDIO_DataLength = 8;
    SDIO_DataInitStructure.SDIO_DataBlockSize = SDIO_DATABLOCKSIZE_8B;
    SDIO_DataInitStructure.SDIO_TransDirection = SDIO_TRANSDIRECTION_TOSDIO;
    SDIO_DataInitStructure.SDIO_TransMode = SDIO_TRANSMODE_BLOCK;
    SDIO_DataInitStructure.SDIO_DSMState = SDIO_DSMSTATE_ENABLE;
    SDIO_DataConfig(&SDIO_DataInitStructure);
    /* Send ACMD51 SD_APP_SEND_SCR with argument as 0 */
    SDIO_CmdInitStructure.SDIO_CMDParameter = 0x0;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_SD_APP_SEND_SCR;
    Status = Check_Err_R1(SDIO_SD_APP_SEND_SCR);
        return(Status);
    while (!(SDIO->STR & (SDIO_FLAG_RXORE | SDIO_FLAG_DTCRCFAIL | SDIO_FLAG_DTTMOUT | SDIO_FLAG_DTBLKEND | SDIO_FLAG_STBITE)))
        if (SDIO_GetBitState(SDIO_FLAG_RXDTVAL) != RESET)
            *(tempscr + index) = SDIO_ReadData();
            index++;
    if (SDIO_GetBitState(SDIO_FLAG_DTTMOUT) != RESET)
        SDIO_ClearBitState(SDIO_FLAG_DTTMOUT);
        Status = SD_DATA_TIMEOUT;
        return(Status);
    else if (SDIO_GetBitState(SDIO_FLAG_DTCRCFAIL) != RESET)
        SDIO_ClearBitState(SDIO_FLAG_DTCRCFAIL);
        Status = SD_DATA_CRC_FAIL;
        return(Status);
    else if (SDIO_GetBitState(SDIO_FLAG_RXORE) != RESET)
        SDIO_ClearBitState(SDIO_FLAG_RXORE);
        Status = SD_RX_OVERRUN;
        return(Status);
    else if (SDIO_GetBitState(SDIO_FLAG_STBITE) != RESET)
        SDIO_ClearBitState(SDIO_FLAG_STBITE);
        Status = SD_START_BIT_ERR;
        return(Status);
    *(pscr + 1) = ((tempscr[0] & SD_0TO7BITS) << 24) | ((tempscr[0] & SD_8TO15BITS) << 8) | ((tempscr[0] & SD_16TO23BITS) >> 8) | ((tempscr[0] & SD_24TO31BITS) >> 24);
    *(pscr) = ((tempscr[1] & SD_0TO7BITS) << 24) | ((tempscr[1] & SD_8TO15BITS) << 8) | ((tempscr[1] & SD_16TO23BITS) >> 8) | ((tempscr[1] & SD_24TO31BITS) >> 24);
    return(Status);
 楼主 | 2018-9-30 19:54 | 显示全部楼层
static uint8_t Bytes_To_PowerTwo(uint16_t NumberOfBytes)
    uint8_t count = 0;
    while (NumberOfBytes != 1)
        NumberOfBytes >>= 1;
        count++;
    return(count);
static void GPIO_Configuration(void)
    GPIO_InitPara  GPIO_InitStructure;
    /* Enable GPIOC and GPIOD clock */
    RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_GPIOC | RCC_APB2PERIPH_GPIOD, ENABLE);
    /* Configure relative ports(PC8, PC9, PC10, PC11, PC12: D0, D1, D2, D3, CLK pin) */
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_8 | GPIO_PIN_9 | GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12;
    GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ;
    GPIO_InitStructure.GPIO_Mode = GPIO_MODE_AF_PP;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    /* Configure PD2(CMD line) */
    GPIO_InitStructure.GPIO_Pin = GPIO_PIN_2;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
static void DMA_TxConfiguration(uint32_t *BufferSRC, uint32_t BufferSize)
    DMA_InitPara DMA_InitStructure;
    DMA_ClearBitState(DMA2_FLAG_TC4 | DMA2_FLAG_TE4 | DMA2_FLAG_HT4 | DMA2_FLAG_GL4);
    /* DMA2 Channel4 disable */
    DMA_Enable(DMA2_CHANNEL4, DISABLE);
    /* DMA2 Channel4 Config */
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SDIO_FIFO_ADDR;
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)BufferSRC;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PERIPHERALDST;
    DMA_InitStructure.DMA_BufferSize = BufferSize / 4;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PERIPHERALINC_DISABLE;
    DMA_InitStructure.DMA_MemoryInc = DMA_MEMORYINC_ENABLE;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PERIPHERALDATASIZE_WORD;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MEMORYDATASIZE_WORD;
    DMA_InitStructure.DMA_Mode = DMA_MODE_NORMAL;
    DMA_InitStructure.DMA_Priority = DMA_PRIORITY_HIGH;
    DMA_InitStructure.DMA_MTOM = DMA_MEMTOMEM_DISABLE;
    DMA_Init(DMA2_CHANNEL4, &DMA_InitStructure);
    /* DMA2 Channel4 enable */
    DMA_Enable(DMA2_CHANNEL4, ENABLE);
static void DMA_RxConfiguration(uint32_t *BufferDST, uint32_t BufferSize)
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)BufferDST;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PERIPHERALSRC;
 楼主 | 2018-9-30 19:55 | 显示全部楼层
SD_Err SD_Lock_Unlock(uint8_t lockstate)
    u8 cardstate = 0;
    u32 pwd1,pwd2,cardstatus,timeout;
    /* Check if the card command class supports Lock/Unlock command */
    if ((SD_CCC_LOCK_UNLOCK&SDIOInfo.SD_csd.CardComdClasses) == 0)
        return(Status);
    /* PWD pattern */
    pwd1 = (0x01020600|lockstate);
    pwd2 = 0x03040506;
    /* Clear all DSM configuration */
    SDIO_DataInitStructure.SDIO_DataTimeOut = 0;
    SDIO_DataInitStructure.SDIO_DataLength = 0;
    SDIO_DataInitStructure.SDIO_DataBlockSize = SDIO_DATABLOCKSIZE_1B;
    SDIO_DataInitStructure.SDIO_TransDirection = SDIO_TRANSDIRECTION_TOCARD;
    SDIO_DataInitStructure.SDIO_DSMState = SDIO_DSMSTATE_DISABLE;
    SDIO_DMA_Enable(DISABLE);
    /* CMD16 Set Block Size for Card */
    SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t) 8;
        return(Status);
    cardstatus = SDIO_GetResponse(SDIO_RESP1);
    /* Wait till card is ready for data writing */
    SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t) (RCA << 16);
    Status = Check_Err_R1(SDIO_SEND_STATUS);
        return(Status);
    timeout = 10000;
    while (((cardstatus & 0x00000100) == 0) && (timeout > 0))
        timeout--;
            return(Status);
    if (timeout == 0)
        return(SD_ERROR);
     /* CMD42 LOCK_UNLOCK */
    SDIO_CmdInitStructure.SDIO_CMDParameter = (uint32_t)0x00000000;
    SDIO_CmdInitStructure.SDIO_CMDIndex = SDIO_LOCK_UNLOCK;
    Status = Check_Err_R1(SDIO_LOCK_UNLOCK);
        return(Status);
    /* Write PWD pattern */
    SDIO_WriteData(pwd1);
    SDIO_WriteData(pwd2);
        return(Status);
        return(Status);
    else if (SDIO_GetBitState(SDIO_FLAG_TXURE) != RESET)
        SDIO_ClearBitState(SDIO_FLAG_TXURE);
        Status = SD_TX_UNDERRUN;
        return(Status);
        return(Status);
    /* Wait till the card is in programming state */
    Status = IsCardProgramming(&cardstate);
    while ((Status == SD_OK) && ((cardstate == SD_CARD_PROGRAMMING) || (cardstate == SD_CARD_RECEIVING)))
    return(Status);
扫描二维码,随时随地手机跟帖
我要发帖 投诉建议 创建版块 申请版主
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
论坛热帖
在线客服 快速回复 返回顶部 返回列表
