[大数据]
hadoop编程:词频排序
656|3
heimaojingzhang|  楼主 | 2018-10-11 13:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
本文博客链接:http://blog.csdn.net/jdh99,作者:jdh,转载请注明.
环境:
主机:Ubuntu10.04
hadoop版本:1.2.1
开发工具:gedit
说明:
在词频排序的例子上增加
教程中词频排序不能识别,;等符号,造成“soft”和“soft,”被识别为两个词,所以进行修改。
heimaojingzhang|  楼主 | 2018-10-11 13:49 | 只看该作者
源代码:
TokenizerMapper.java:
package com.bazhangkeji.hadoop;
import java.io.IOException;
import java.util.StringTokenizer;
import org.apache.hadoop.io.IntWritable;
import org.apache.hadoop.io.Text;
import org.apache.hadoop.mapreduce.Mapper;
public class TokenizerMapper extends Mapper<Object, Text, Text, IntWritable>
        IntWritable one = new IntWritable(1);
          Text word = new Text();
          public void map(Object key, Text value, Context context) throws IOException, InterruptedException
                    StringTokenizer itr = new StringTokenizer(value.toString());
                StringBuffer str_temp = new StringBuffer();
                StringBuffer str_out = new StringBuffer();
                int i = 0;
                    while (itr.hasMoreTokens())
                        str_temp.setLength(0);
                        str_out.setLength(0);
                        str_temp.append(itr.nextToken());
                        for (i = 0;i < str_temp.length();i++)
                                if ((str_temp.charAt(i) >= 'a' && str_temp.charAt(i) <= 'z') ||
                                    (str_temp.charAt(i) >= 'A' && str_temp.charAt(i) <= 'Z') ||
                                       (str_temp.charAt(i) >= '0' && str_temp.charAt(i) <= '9'))
                                        str_out.append(str_temp.charAt(i));
                              word.set(str_out.toString());
                              context.write(word, one);
IntSumReducer.java:
import org.apache.hadoop.mapreduce.Reducer;
public class IntSumReducer extends Reducer<Text,IntWritable,Text,IntWritable>
          IntWritable result = new IntWritable();
          public void reduce(Text key, Iterable<IntWritable> values, Context context) throws IOException, InterruptedException
                    int sum = 0;
                    for (IntWritable val : values)
                              sum += val.get();
                    result.set(sum);
                    context.write(key, result);
heimaojingzhang|  楼主 | 2018-10-11 13:50 | 只看该作者
WordCount.java:
import org.apache.hadoop.conf.Configuration;
import org.apache.hadoop.fs.Path;
import org.apache.hadoop.mapreduce.Job;
import org.apache.hadoop.mapreduce.lib.input.FileInputFormat;
import org.apache.hadoop.mapreduce.lib.output.FileOutputFormat;
import org.apache.hadoop.util.GenericOptionsParser;
public class WordCount
          public static void main(String[] args) throws Exception
                    Configuration conf = new Configuration();
                    String[] otherArgs = new GenericOptionsParser(conf, args).getRemainingArgs();
                    if (otherArgs.length != 2)
                              System.err.println("Usage: wordcount <in> <out>");
                              System.exit(2);
                Job job = new Job(conf, "wordcount");
                job.setJarByClass(WordCount.class);
                job.setMapperClass(TokenizerMapper.class);
                job.setReducerClass(IntSumReducer.class);
                job.setOutputKeyClass(Text.class);
                job.setOutputValueClass(IntWritable.class);
                FileInputFormat.addInputPath(job, new Path(otherArgs[0]));
                FileOutputFormat.setOutputPath(job, new Path(otherArgs[1]));
                System.exit(job.waitForCompletion(true) ? 0 : 1);
