[51单片机]
用按键和定时器中断来控制,程序编译错误,帮我看一看
824|2
经历|  楼主 | 2018-10-19 20:19 | 显示全部楼层 |阅读模式
程序如下:
#include<at89x52.h>
#define uchar unsigned char
#define uint unsigned uint
sbit k1=P3^2;
uchar code tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
void delay10ms(uchar a)
    uchar b,c;
    for(c=1;c>0;c--)
        for(b=38;b>0;b--)
            for(a=130;a>0;a--);
void keyscan()
uint flag=0;
if(k2==0X00)
  delay10ms(1);
  if(k2==0X00)
     P2=0xFF;
     flag=!flag;
void main()
  TMOD=0x02;
  TH0=0xf6;
  TL0=0xf6;
  ET0=1;EA=1;
  TR0=1;
  while(1);
void time() interrupt 1 using 0
  uint flag=0;
  uchar temp;
  uchar i;
  if(flag==1)
    temp=0x80;
    for(i=0;i<4;i++)
     P0=tab[i+1];
     P2=~temp;
     temp=temp>>1;
     P2=0xff;
编译结果:
Build target 'Target 1'
assembling STARTUP.A51...
compiling 外部中断和定时器中断显示数码管(1234).c...
外部中断和定时器中断显示事牍埽?234).C(17): error C141: syntax error near 'flag'
外部中断和定时器中断显示事牍埽?234).C(39): error C141: syntax error near 'flag'
Target not created
mohanwei| | 2018-10-19 20:45 | 显示全部楼层
问题出在第3行:#define uint unsigned uint
要改为#define uint unsigned int
经历|  楼主 | 2018-10-19 21:09 | 显示全部楼层
哦谢谢,thank you
