[DemoCode下载]
这个米你的例子怎么理解
487|12
jiekou001|  楼主 | 2018-10-26 23:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TE, se, ni, TI, UART
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 5 $
* $Date: 15/10/06 11:04a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show hard fault information when hard fault happened
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stdint.h>
#include "Mini51Series.h"
/* Global variables        */
/* Define functions prototype        */
int32_t main(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Set P5 multi-function pins for XTAL1 and XTAL2 */
    SYS->P5_MFP &= ~(SYS_MFP_P50_Msk | SYS_MFP_P51_Msk);
    SYS->P5_MFP |= (SYS_MFP_P50_XTAL1 | SYS_MFP_P51_XTAL2);
    /* Enable External XTAL (4~24 MHz) */
    CLK->PWRCON &= ~CLK_PWRCON_XTLCLK_EN_Msk;
    CLK->PWRCON |= (0x1 << CLK_PWRCON_XTLCLK_EN_Pos); // XTAL12M (HXT) Enabled
    /* Waiting for 12MHz clock ready */
    CLK_WaitClockReady( CLK_CLKSTATUS_XTL_STB_Msk);
    /* Switch HCLK clock source to XTAL */
    CLK->CLKSEL0 &= ~CLK_CLKSEL0_HCLK_S_Msk;
    CLK->CLKSEL0 |= CLK_CLKSEL0_HCLK_S_XTAL;
    /* Enable IP clock */
    CLK->APBCLK |= CLK_APBCLK_UART_EN_Msk; // UART Clock Enable
    /* Select IP clock source */
    CLK->CLKSEL1 &= ~CLK_CLKSEL1_UART_S_Msk;
    CLK->CLKSEL1 |= (0x0 << CLK_CLKSEL1_UART_S_Pos);// Clock source from external 12 MHz or 32 KHz crystal clock
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P1 multi-function pins for UART RXD and TXD  */
    SYS->P0_MFP &= ~(SYS_MFP_P00_Msk | SYS_MFP_P01_Msk);
    SYS->P0_MFP = SYS_MFP_P00_TXD | SYS_MFP_P01_RXD;
    /* Lock protected registers */
    SYS_LockReg();
void UART_Init()
    /* Init UART        */
    UART_Open(UART, 115200);
/* MAIN function        */
int main(void)
    char *tmp = 0;
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Init UART for printf */
    UART_Init();
    strcpy(tmp,"HardFaultTest");
    while(1);
jiekou001|  楼主 | 2018-10-26 23:55 | 只看该作者
有朋友能看懂怎么回事吗
643757107| | 2018-10-27 00:02 | 只看该作者
将字符串拷贝到指定的地址,不懂。s
mintspring| | 2018-10-27 00:07 | 只看该作者
字符串拷贝操作
huangcunxiake| | 2018-10-28 13:10 | 只看该作者
看头文件啊,C的标准库而已,拷贝字符串到指定地址。
huangcunxiake| | 2018-10-28 13:11 | 只看该作者
不过这个程序的主题,感觉跟这个对不上号,莫非是敲代码的不会,耍滑头了?
xinxianshi| | 2018-10-28 22:59 | 只看该作者
一个简单的操作。
jiekou001|  楼主 | 2018-11-15 10:35 | 只看该作者
还是不懂啊,一个拷贝的程序,怎么说是硬件错误测试
tuoxieshu| | 2018-11-19 21:57 | 只看该作者
strcpy 不检查拷贝前后的地址是否越界,这里定义了一个空指针没有为它申请内存,所以会导致未知错误。
huangcunxiake| | 2018-11-20 23:40 | 只看该作者
楼上高人啊,原来是指针为空,导致拷贝时候找不到真实地址,发生错误
huangcunxiake| | 2018-11-20 23:49 | 只看该作者
int add(int a , int b)
    return a + b;
int main(void)
    int num = 97;
    float score = 10.00F;
    int arr[3] = {1,2,3};
    int* p_num = &num;
    float* p_score = &score;
    int (*p_arr)[3] = &arr;
    int (*fp_add)(int ,int )  = add;  //p_add是指向函数add的函数指针
    return 0;
指针的正确操作,那个本来要给个地址的,结果给的是个0,所以就后面出错了。
huangcunxiake| | 2018-11-20 23:50 | 只看该作者
而地址0,肯定会已经填充了重要内容,如果这个时候破坏肯定就发生错误了
tuoxieshu| | 2018-11-21 17:38 | 只看该作者
对头☺️
