[DemoCode下载]
CRC的单片机应用
602|8
mintspring|  楼主 | 2018-10-27 00:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Revision: 2 $
* $Date: 15/04/13 10:05a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Implement CRC in CRC-8 mode and get the CRC checksum result.
* @note
* Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include <string.h>
#include "NUC100Series.h"
#define PLL_CLOCK           50000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Enable PDMA module clock for CRC operation */
    CLK_EnableModuleClock(PDMA_MODULE);
    /* Init I/O Multi-function        */
    /* Set PB multi-function pins for UART0 RXD, TXD */
    SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    const uint8_t acCRCSrcPattern[] = "123456789";
    uint32_t i, u32TargetChecksum = 0x58, u32CalChecksum = 0;
    uint8_t *p8SrcAddr;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
    printf("+---------------------------------+\n");
    printf("|    CRC CRC-8 Mode Sample Code   |\n");
    printf("+---------------------------------+\n\n");
    printf("# Calculate string \"123456789\" CRC-8 checksum value by CRC CPU mode.\n");
    printf("    - Seed value is 0x5A            \n");
    printf("    - CPU Write Length is 8-bit     \n");
    printf("    - Checksum Complement disable   \n");
    printf("    - Checksum Reverse disable      \n");
    printf("    - Write Data Complement disable \n");
    printf("    - Write Data Reverse disable    \n");
    printf("    - Checksum should be 0x%X       \n\n", u32TargetChecksum);
    /* Set CRC source buffer address for CRC-8 CPU mode */
    p8SrcAddr = (uint8_t *)acCRCSrcPattern;
    /* Configure CRC operation settings for CRC-8 CPU mode */
    CRC_Open(CRC_8, 0, 0x5A, CRC_CPU_WDATA_8);
    /* Start to execute CRC-8 CPU operation */
    for(i = 0; i < strlen((char *)acCRCSrcPattern); i++)
        CRC_WRITE_DATA((p8SrcAddr[i] & 0xFF));
    /* Get CRC-8 checksum value */
    u32CalChecksum = CRC_GetChecksum();
    printf("CRC checksum is 0x%X ... %s.\n", u32CalChecksum, (u32CalChecksum == u32TargetChecksum) ? "PASS" : "FAIL");
    /* Disable CRC function */
    CRC->CTL &= ~CRC_CTL_CRCCEN_Msk;
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
mintspring|  楼主 | 2018-10-27 00:11 | 只看该作者
这个是单片机上常用的一种。
mintspring|  楼主 | 2018-10-27 00:12 | 只看该作者
比较简单的。
你会用吗
huangcunxiake| | 2018-10-28 11:07 | 只看该作者
要求不高的可以不用这个。
hotpower| | 2018-12-30 00:01 | 只看该作者
http://www.hotpage.com.cn/hotcrc
xinpian101| | 2018-12-30 13:41 | 只看该作者
啥情况,头像都带个蛋
yiyigirl2014| | 2018-12-30 18:31 | 只看该作者
CRC加密用的很多。
hotpower| | 2019-1-1 20:23 | 只看该作者
hotcrc理论上100%**了任意CRC
hotpower| | 2019-1-1 20:24 | 只看该作者
