关于GD32F307 TIMER0 输出3路互补PWM代码
302|5
 楼主 | 2018-11-12 19:57 | 显示全部楼层 |阅读模式
代码使用到IO口有
PA8,PA9,PA10,PA13,PA14,PA15
库版本:V1.0.0, firmware for GD32F30x
实验现象:
void gpio_config(void)
    rcu_periph_clock_enable(RCU_GPIOA);
    rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_AF);
    /*configure PA8 PA9 PA10(TIMER0 CH0 CH1CH2) as alternate function*/
   gpio_init(GPIOA,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_8);
   gpio_init(GPIOA,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_9);
   gpio_init(GPIOA,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_10);
    /*configure PB13 PB14 PB15(TIMER0 CH0N CH1NCH2N) as alternate function*/
   gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_13);
   gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_14);
   gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_15);
voidtimer0_config(void)
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    timer_break_parameter_structtimer_breakpara;
    rcu_periph_clock_enable(RCU_TIMER0);
    timer_deinit(TIMER0);
    /* TIMER0 configuration */
    timer_initpara.prescaler         = 119;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 1000;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER0,&timer_initpara);
     /* CH0/CH0N,CH1/CH1N and CH2/CH2Nconfiguration in timing mode */
    timer_ocintpara.outputstate  = TIMER_CCX_ENABLE;
    timer_ocintpara.outputnstate =TIMER_CCXN_ENABLE;
    timer_ocintpara.ocpolarity   = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.ocnpolarity  = TIMER_OCN_POLARITY_HIGH;
    timer_ocintpara.ocidlestate  = TIMER_OC_IDLE_STATE_HIGH;
    timer_ocintpara.ocnidlestate =TIMER_OCN_IDLE_STATE_LOW;
   timer_channel_output_config(TIMER0,TIMER_CH_0,&timer_ocintpara);
   timer_channel_output_config(TIMER0,TIMER_CH_1,&timer_ocintpara);
   timer_channel_output_config(TIMER0,TIMER_CH_2,&timer_ocintpara);
   timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_0,299);
   timer_channel_output_mode_config(TIMER0,TIMER_CH_0,TIMER_OC_MODE_PWM0);
   timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_1,299);
   timer_channel_output_mode_config(TIMER0,TIMER_CH_1,TIMER_OC_MODE_PWM0);
   timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_2,299);
   timer_channel_output_mode_config(TIMER0,TIMER_CH_2,TIMER_OC_MODE_PWM0);
/* TIMER0 primaryoutput function enable */
   timer_primary_output_config(TIMER0,ENABLE);
    /* TIMER0 counter enable */
    timer_enable(TIMER0);
int main(void)
    gpio_config();
    timer0_config();
    while (1);
资料来源于微信公众号“life_and_family”,更多相关资料可以关注下该公众号
您需要 登录 才可以下载或查看,没有帐号?注册
x
| 2018-11-22 14:25 | 显示全部楼层
谢谢分享,,学习了
| 2018-11-25 10:42 | 显示全部楼层
这个对照示波器的开发的还是很方便的
| 2018-11-30 20:48 | 显示全部楼层
这个主要是定时器的输出的
| 2018-11-30 21:50 | 显示全部楼层
支持下,谢谢分享!
vibra2016 发表于 2018-11-25 10:42
这个对照示波器的开发的还是很方便的
那个是逻辑分析仪的波形,不是示波器的应该。
扫描二维码,随时随地手机跟帖
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
我要创建版块 申请成为版主
论坛热帖
快速回复 返回顶部 返回列表
