[资料分享] WIFI模块手册
241|0
 楼主 | 2018-11-13 09:19 | 显示全部楼层 |阅读模式
MY-8188EUS Linux-4.1.15 User Guide
运行环境
使用的开发板
开发板型号:MY-IMX6-EK140P-6Y
内核版本:Linux-4.1.15
文件系统:fsl-image-linux-myimx6a7.tar.bz2
使用的模块型号
模块型号:RTL8188EUS
其它可支持的设备
MY-IMX6-A9系列:MY-IMX6-EK200、MY-IMX6-EK314、MY-IMX6-EK336
MY-IMX6-A7系列:MY-IMX6-EK140P
使用前的准备
下载模块和内核
文件在网盘中的位置:MYZR-IMX6 > 5_MY-Demo
文件名:my-demo-8188eus-l4115-<date>.tar.xz
把下载的文件复制到开发板上
这个步骤自己采取U盘、SD卡或自己熟悉的其它方式完成。
解压驱动模块和内核
# tar xf my-demo-8188eus-l4115-<date>.tar.xz -C ~
为系统运行准备
MY-IMX6-EK140P 上替换内核
mount /dev/mmcblk1p1 /mnt/
# cp ~/my-demo/zImage-myimx6a7-l4115-svn236 /mnt/zImage-myimx6a7
MY-IMX6-EK200 上替换内核
# mount /dev/mmcblk3p1 /mnt/
# cp ~/my-demo/zImage-myimx6a9-l4115-svn236 /mnt/zImage-myimx6a9
写入存储并重启设备
# sync && reboot
MY-IMX6-EK140P 使用步骤
检查系统是否已经识别到模块
# lsusb
Bus 001 Device 003: ID 0bda:8179
Insert a module into the Linux Kernel
# insmod ./my-demo/MY_8188EUS_V4324_L4115_IMX6A7.ko
bFWReady == _FALSE call reset 8051...
usbcore: registered new interface driver rtl8188eu
Configuration
Generate a WPA PSK from an ASCII passphrase for a SSID
usage: wpa_passphrase <ssid> [passphrase]
# wpa_passphrase MYZR-OPEN Myzr2012 > /etc/wpa_supplicant.conf
# pkill wpa_supplicant
Connection
# wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant.conf
Successfully initialized wpa_supplicant
rfkill: Cannot open RFKILL control device
==> rtl8188e_iol_efuse_patch
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Get IP address
# udhcpc -i wlan0
udhcpc (v1.24.1) started
Sending discover...
Sending select for 192.168.124.113...
Lease of 192.168.124.113 obtained, lease time 7200
/etc/udhcpc.d/50default: Adding DNS 114.114.114.114
/etc/udhcpc.d/50default: Adding DNS 114.114.115.115
Network test
# ping -I wlan0 www.baidu.com -c 2 -w 4
PING www.baidu.com (14.215.177.38): 56 data bytes
64 bytes from 14.215.177.38: seq=0 ttl=49 time=15.753 ms
64 bytes from 14.215.177.38: seq=1 ttl=49 time=11.835 ms
--- www.baidu.com ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max = 11.835/13.794/15.753 ms
Remove a module from the Linux Kernel
# rmmod 8188eu
usbcore: deregistering interface driver rtl8188eu
usb 1-1.1: reset high-speed USB device number 3 using ci_hdrc
扫描二维码,随时随地手机跟帖
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
我要创建版块 申请成为版主
论坛热帖
热门推荐上一条 /3 下一条
快速回复 返回顶部 返回列表
