[范例教程]
【M0】 MG32F02A 学习笔记⑲ UART0 SPI模式
1296|1
noctor|  楼主 | 2018-11-16 16:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
     上回我们说到了MG32F02A的TM36 输入捕获DMA的使用。帖子详情:https://bbs.21ic.com/icview-2585798-1-1.html
      这次用一下UART0作SPI试试。
      这次我是模拟UART0作为SPI主机模式,此处要注意的是,UART的数据格式要设置的和SPI从机格式一致。
#include "MG32x02z_DRV.H"
#include <stdio.h>
#define URTX URT0
typedef uint8_t u8;
typedef uint16_t u16;
typedef uint32_t u32;
typedef uint64_t u64;
void CSC_Init (void)
        CSC_PLL_TyprDef CSC_PLL_CFG;
    UnProtectModuleReg(MEMprotect);             // Setting flash wait state
    MEM_SetFlashWaitState(MEM_FWAIT_ONE);        // 50MHz> Sysclk >=25MHz
    UnProtectModuleReg(CSCprotect);
        CSC_CK_APB_Divider_Select(APB_DIV_1);        // Modify CK_APB divider        APB=CK_MAIN/1
        CSC_CK_AHB_Divider_Select(AHB_DIV_1);        // Modify CK_AHB divider        AHB=APB/1
        /* CK_HS selection */
        CSC_IHRCO_Select(IHRCO_11M0592Hz);                        // IHRCO Sel 11.0592MHz
        CSC_IHRCO_Cmd(ENABLE);
        while(CSC_GetSingleFlagStatus(CSC_IHRCOF) == DRV_Normal);
        CSC_ClearFlag(CSC_IHRCOF);
        CSC_CK_HS_Select(HS_CK_IHRCO);                        // CK_HS select IHRCO
        /* PLL */
        CSC_PLL_CFG.InputDivider=PLLI_DIV_2;        // 12M/2=6M
        CSC_PLL_CFG.Multiplication=PLLIx16;                // 6M*16=96M
        CSC_PLL_CFG.OutputDivider=PLLO_DIV_2;        // PLLO=96M/2=48M
        CSC_PLL_Config(&CSC_PLL_CFG);
        CSC_PLL_Cmd(ENABLE);
        while(CSC_GetSingleFlagStatus(CSC_PLLF) == DRV_Normal);
        CSC_ClearFlag(CSC_PLLF);
        /* CK_MAIN */
        CSC_CK_MAIN_Select(MAIN_CK_HS);
        /* Configure ICKO function */
        /* Configure peripheral clock */
        CSC_PeriphProcessClockSource_Config(CSC_UART0_CKS, CK_APB);
        CSC_PeriphOnModeClock_Config(CSC_ON_UART0,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_PortB,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_PortC,ENABLE);
        CSC_PeriphOnModeClock_Config(CSC_ON_PortE,ENABLE);
void URT0_SPIMode_Init(void)
    URT_BRG_TypeDef  URT_BRG;
    URT_Data_TypeDef DataDef;
    PIN_InitTypeDef PINX_InitStruct;
    //==Set CSC init
    //MG32x02z_CSC_Init.h(Configuration Wizard)
    //Select CK_HS source = CK_IHRCO
    //Select IHRCO = 11.0592M
    //Select CK_MAIN Source = CK_HS
    //Configure PLL->Select APB Prescaler = CK_MAIN/1
    //Configure Peripheral On Mode Clock->Port B/URT0 = Enable
    //Configure Peripheral On Mode Clock->URT0->Select URT0_PR Source = CK_APB(11.0592)
    //==Set GPIO init
    //1. MOSI Pin
    //    (1).MG32x02z_GPIO_Init.h(Configuration Wizard)->Use GPIOB->Pin8
    //    (2).GPIO port initial is 0xFFFF
    //    (3).Pin8 mode is PPO (Push pull output)
    //    (4).Pin8 pull-up resister Enable
    //    (5).Pin8 function URT0_TX
    //2. MISO Pin
    //    (1).MG32x02z_GPIO_Init.h(Configuration Wizard)->Use GPIOB->Pin9
    //    (3).Pin8 mode is ODO (Open drain)
    //    (5).Pin9 function URT0_RX
    //3. SPICLK Pin
    //    (1).MG32x02z_GPIO_Init.h(Configuration Wizard)->Use GPIOC->Pin3
    //    (5).Pin3 function URT0_CLK
    //4. NSS Pin
    //    (1).MG32x02z_GPIO_Init.h(Configuration Wizard)->Use GPIOB->Pin10
    //    (5).Pin3 function URT0_NSS
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_PushPull_O;                  // Pin select Push Pull mode
        PINX_InitStruct.PINX_PUResistant                 = PINX_PUResistant_Enable;          // Enable pull up resistor
        PINX_InitStruct.PINX_Speed                                   = PINX_Speed_Low;
        PINX_InitStruct.PINX_OUTDrive                         = PINX_OUTDrive_Level0;                 // Pin output driver full strength.
        PINX_InitStruct.PINX_FilterDivider                   = PINX_FilterDivider_Bypass;        // Pin input deglitch filter clock divider bypass
        PINX_InitStruct.PINX_Inverse                         = PINX_Inverse_Disable;                 // Pin input data not inverse
        PINX_InitStruct.PINX_Alternate_Function  = 3;                                // Pin AFS = URT0_TX
        GPIO_PinMode_Config(PINB(8),&PINX_InitStruct);                                                          // TXD(MOSI) at PB8
        GPIO_PinMode_Config(PINB(10),&PINX_InitStruct);                                                          // URT0_NSS(SPI_NSS) at PB10
        GPIO_PinMode_Config(PINC(3),&PINX_InitStruct);                                                          // URT0_CLK(SPI_CLK) at PC3
        GPIO_PinMode_Config(PINE(15),&PINX_InitStruct);                                                          // D6 at PE15
        PINX_InitStruct.PINX_Mode                                 = PINX_Mode_OpenDrain_O;                 // Pin select Open Drain mode
        PINX_InitStruct.PINX_Alternate_Function  = 3;                                // Pin AFS = URT0_RX
        GPIO_PinMode_Config(PINB(9),&PINX_InitStruct);                                                          // RXD(MISO) at PB9
    //=====Set Clock=====//
    //---Set BaudRate---//
    URT_BRG.URT_InteranlClockSource = URT_BDClock_PROC;
    URT_BRG.URT_BaudRateMode = URT_BDMode_Separated;
    URT_BRG.URT_PrescalerCounterReload = 3;                        //Set PSR
    URT_BRG.URT_BaudRateCounterReload = 5;                        //Set RLR
    URT_BaudRateGenerator_Config(URTX, &URT_BRG);                    //BR115200 = f(CK_URTx)/(PSR+1)/(RLR+1)/(OS_NUM+1)
    URT_BaudRateGenerator_Cmd(URTX, ENABLE);                    //Enable BaudRateGenerator
    //---TX/RX Clock---//
    URT_TXClockSource_Select(URTX, URT_TXClock_Internal);        //URT_TX use BaudRateGenerator
    URT_RXClockSource_Select(URTX, URT_RXClock_Internal);        //URT_RX use BaudRateGenerator
    URT_TXOverSamplingSampleNumber_Select(URTX, 3);                //Set TX OS_NUM
    URT_RXOverSamplingSampleNumber_Select(URTX, 3);                //Set RX OS_NUM
    URT_RXOverSamplingMode_Select(URTX, URT_RXSMP_3TIME);
    URT_TX_Cmd(URTX, ENABLE);                                    //Enable TX
    URT_RX_Cmd(URTX, ENABLE);                                    //Enable RX
    //=====Set Mode=====//
    //---Set Data character config---//
    DataDef.URT_TX_DataLength  = URT_DataLength_8;
    DataDef.URT_RX_DataLength  = URT_DataLength_8;
    DataDef.URT_TX_DataOrder   = URT_DataTyped_MSB;      //UART SPI Data Mode
    DataDef.URT_RX_DataOrder   = URT_DataTyped_MSB;      //UART SPI Data Mode
    DataDef.URT_TX_Parity      = URT_Parity_No;
    DataDef.URT_RX_Parity      = URT_Parity_No;
    DataDef.URT_TX_StopBits    = URT_StopBits_1_0;
    DataDef.URT_RX_StopBits    = URT_StopBits_1_0;
    DataDef.URT_TX_DataInverse = DISABLE;
    DataDef.URT_RX_DataInverse = DISABLE;
    URT_DataCharacter_Config(URTX, &DataDef);
    //---Set Mode Select---//
    URT_Mode_Select(URTX, URT_SYNC_mode);
    //---Set DataLine Select---//
    URT_DataLine_Select(URTX, URT_DataLine_2);
    //=====Set Error Control=====//
    // to do...
    //=====Set Bus Status Detect Control=====//
    // to do...
    //==Set SPI Mode(CPHA = 0 , CPOL = 0)====//
    URT_CPHAMode_Select( URTX , URT_CPHA0_LeadEdge);
    URT_CPOLMode_Select( URTX , URT_CPOL0_Low );
    //=====Set Data Control=====//
    URT_TXGaudTime_Select(URTX, 0);
    //=====Enable CLK(SYSCLK)====//
    URT_CLKSignal_Cmd(URTX,ENABLE);
    //=====Enable URT=====//
    URT_Cmd(URTX, ENABLE);
int main()
        int i;
        ctype            URT_RecData;
        CSC_Init();
        URT0_SPIMode_Init();
                while(1)
                    i++;
            if(i>=500000)
                                i=0;
    URT_SetTXData(URTX,1,0x30);
    while(URT_GetITSingleFlagStatus(URTX,URT_IT_TC)==DRV_UnHappened);
    URT_ClearITFlag(URTX,URT_IT_TC);
    URT_RecData.W = URT_GetRXData(URTX);      //Receive effective data byte is equal to send data byte.
                if(URT_RecData.W==0x30)PE15=~PE15;
344864311| | 2018-11-17 08:46 | 只看该作者
谢谢分享
