51时钟程序 按键不好用
833|0
 楼主| 三年级小学生 发表于 2018-11-21 20:01 | 显示全部楼层 |阅读模式
#include<reg52.h>
#include"24c02.h"
#define        uchar        unsigned        char
#define        uint        unsigned        int
sbit        lcdrs=P3^5;
sbit        lcden=P3^4;
sbit        s1=P3^4;
sbit        s2=P3^5;
sbit        s3=P3^6;
sbit        rd=P3^7;
sbit        beep=P2^7;
uchar        count,s1num;
uchar        miao,shi,fen;
uchar        code        table[]=" 2018-6-14 MON";
void        delay(uint        z)
                        uint        x,y;
                                for(x=z;x>0;x--)
                                        for(y=110;y>0;y--);
        void        fmq()
                        beep=0;
                        delay(500);
                        beep=1;
                void        write_com(uchar        com)
                                        lcdrs=0;
                                        lcden=0;
                                        P0=com;
                                        delay(5);
                                        lcden=1;
                                        delay(5);
                                        lcden=0;
                void        write_date(uchar        date)
                                lcdrs=1;
                                lcden=0;
                                P0=date;
                                delay(5);
                                lcden=1;
                                delay(5);
                                lcden=0;
                void        write_sfm(uchar        add,uchar        date)                        //ʱ·ÖÃë
                                        uchar        shi,ge;
                                        shi=date/10;        //·Ö½âʮλ¸öλ
                                        ge=date%10;
                                        write_com(0x80+0x40+add);                                                        //ÏÔʾλÖÃ
                                        write_date(0x30+shi);
                                        write_date(0x30+ge);
                void        init()                        //³õʼ»¯º¯Êý
                        uchar        num;
                        rd=0;
                        lcden=0;
                        fen=0;
                        miao=0;
                        shi=0;
                        count=0;
                        s1num=0;
                        init_24c02();
                        write_com(0x38);                                //³õʼ»¯Òº¾§
                        write_com(0x0c);
                        write_com(0x06);
                        write_com(0x80);
                        for(num=0;num<15;num++)                        //ÄêÔÂÈÕÐÇÆÚ
                                                write_date(table[num]);
                                                delay(5);
                                        write_com(0x80+0x40+6);                        //ðºÅ
                                        write_date(':');
                                        delay(5);
                                        miao=read_add(1);                                        //Ê×´ÎÉϵç´Ó24c02¶ÁÈ¡Êý¾Ý
                                        fen=read_add(2);
                                        shi=read_add(3);
                                        write_sfm(10,miao);                                //ËÍÒº¾§ÏÔʾ
                                        write_sfm(7,fen);
                                        write_sfm(4,shi);
                                        TMOD=0x01;        //¶¨Ê±Æ÷0¹¤×÷ģʽ1
                                        TH0=(65536-50000)/256;
                                        TL0=(65536-50000)%256;
                                        EA=1;
                                        ET0=1;
                                        TR0=1;
                void        keyscan()                                        //°´¼üɨÃè
                                if(s1==0)
                                                delay(5);
                                                        if(s1==0)                                        //°´ÏÂ
        s1num++;                                //¼Ç¼´ÎÊý
        while(!s1);                        //ÊÍ·Å
        fmq();
        if(s1num==1)                //µÚÒ»´Î±»°´ÏÂ
        TR0=0;                                        //¹Ø±Õ¶¨Ê±Æ÷
        write_com(0x80+0x40+10);                        //¹â±êÔÚÃë
        write_com(0x0f);                                                        //¹â±êÉÁ˸
        if(s1num==2)        //µÚ¶þ´Î°´ÏÂ
        write_com(0x80+0x40+7);
        if(s1num==3)        //µÚÈý´Î°´ÏÂ
        write_com(0x80+0x40+4);
        if(s1num==4)
        s1num=0;
        write_com(0x0c);
        TR0=1;
                                if(s1num!=0)        //¹¦Äܼü°´Ï£¬Ôö¼õÓÐЧ
                                                if(s2==0)
        delay(5);
        if(s2==0)
        while(!s2);
        fmq();
        if(s1num==1)
        miao++;
        if(miao==60)        miao=0;
        write_sfm(10,miao);
        write_add(1,miao);
        if(s1num==2)
        fen++;
        if(fen==60)        fen=0;
        write_sfm(7,fen);
        write_add(2,fen);
        if(s1num==3)
        shi++;
        if(shi==24)        shi=0;
        write_sfm(4,shi);
        write_add(3,shi);
                                                if(s3==0)
        delay(5);
        if(s3==0)
        while(!s3);
        fmq();
        if(s1num==1)
        miao--;
        if(miao==-1)        miao=59;
        write_sfm(10,miao);
        write_add(1,miao);
        if(s1num==2)
        fen--;
        if(fen==-1)        fen=59;
        write_sfm(7,fen);
        write_add(2,fen);
        if(s1num==3)
        shi--;
        if(shi==-1)        shi=23;
        write_sfm(4,shi);
        write_add(3,shi);
                void        main()
                                init();
                                while(1)
                                        keyscan();
                void        timer0()        interrupt        1
                                        count++;                                                        //ÀÛ¼Ó
                                if(count==20)                                                        //20´Îºó1Ãë
                                                count=0;                                                //Çå0
                                                miao++;
                                                if(miao==60)
        miao=0;
        fen++;
        if(fen==60)
        fen=0;
        shi++;
        if(shi==24)                shi=0;
        write_sfm(4,shi);
        write_add(3,shi);
        write_sfm(7,fen);
        write_add(2,fen);
                                                write_sfm(10,miao);
                                                write_add(1,miao);
