发新帖我要提问
返回列表
GD32 驱动 液晶屏幕
楼主: junpeng324
junpeng324|  楼主 | 2018-11-30 23:43 | 显示全部楼层
// lcd 驱动
void lcd19264_gpio_conf(void)
          GPIO_InitPara GPIO_InitStructure;
    RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_GPIOA,ENABLE);
    GPIO_InitStructure.GPIO_Pin   = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11|GPIO_PIN_12;
    GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ;
    GPIO_InitStructure.GPIO_Mode  = GPIO_MODE_OUT_PP;
    GPIO_Init(GPIOA,&GPIO_InitStructure);
void LCD_Set_Pos(unsigned char x, unsigned char y)
          LCD19264_WriteCmd(0xb0+y);
          LCD19264_WriteCmd(((x&0xf0)>>4)|0x10);
          LCD19264_WriteCmd(x&0x0f);
junpeng324|  楼主 | 2018-11-30 23:44 | 显示全部楼层
void LCD_P8x16Str(unsigned char x,unsigned char y,char ch[])
    char c=0,i=0,j=0;
    while (ch[j]!='\0')
       c =ch[j]-32;
       if(x>184){x=0;y+=2;}
       LCD_Set_Pos(x,y);
       for(i=0;i<8;i++)
             LCD19264_WriteData(F8X16[c*16+i]);
       LCD_Set_Pos(x,y+1);
             for(i=0;i<8;i++)
             LCD19264_WriteData(F8X16[c*16+i+8]);
             x+=8;
             j++;
void LCD19264_WriteCmd(uchar cmd)
        uchar i;
        CS_L;
        RS_L;
        for (i=0; i<8; i++)
                 SCL_L;
                if(cmd&0x80)
                        SDA_H;
                else
                        SDA_L;
                SCL_H;
                cmd =cmd<< 1;
            CS_H;
junpeng324|  楼主 | 2018-11-30 23:45 | 显示全部楼层
void LCD19264_WriteData(uchar dat)
        uchar i;
        CS_L;
        RS_H;
        for (i=0; i<8; i++)
                SCL_L;
                if(dat&0x80)
                        SDA_H;
                else
                        SDA_L;
                SCL_H;
                dat =dat<< 1;
        CS_H;
void lcd_address(uchar page,uchar column)
   //column=column+31;
         page=page-1;
         LCD19264_WriteCmd(0xb0+page);
         LCD19264_WriteCmd(((column>>4)&0x0f)+0x10);
         LCD19264_WriteCmd(column&0x0f);
junpeng324|  楼主 | 2018-11-30 23:48 | 显示全部楼层
void LCD19264_ClearScreen(void)
        uchar i, j;
        for(i=0; i<8; i++)
                lcd_address(1+i,1);
                for(j=0; j<192; j++)
                        LCD19264_WriteData(0x00);
junpeng324|  楼主 | 2018-11-30 23:51 | 显示全部楼层
void display_string_5x8(uint page,uint column,uchar reverse,uchar *text)
                uchar i=0,j,k,data1;
                while(text[i]>0x00)
                           if(column>186)
             column =0;
                                           page+=1;
                                if((text[i]>=0x20)&&(text[i]<=0x7e))
                                                j=text[i]-0x20;
                                                lcd_address(page,column);
                                                for(k=0;k<5;k++)
        if(reverse==1) data1=~ascii_table_5x8[j][k];
        else data1=ascii_table_5x8[j][k];
        LCD19264_WriteData(data1);
                                                if(reverse==1)
                                                           LCD19264_WriteData(0xff);
                                                else
                                                i++;
                                                column+=6;
                                else
                                    i++;
junpeng324|  楼主 | 2018-11-30 23:52 | 显示全部楼层
void OLED_Print(unsigned char x, unsigned char y, char ch[])
        char ch2[3];
        unsigned char ii=0;
        while(ch[ii] != '\0')
                        ch2[0] = ch[ii];
                        ch2[1] = '\0';
                        LCD_P8x16Str(x,y,ch2);
                        x += 8;
                        ii+= 1;
junpeng324|  楼主 | 2018-11-30 23:53 | 显示全部楼层
void OLED_Printf(unsigned char x,unsigned char y,const char *fmt,...)
        static unsigned char last_len[4]={0,0,0,0};
        static char LCD_BUF[128]={0};
        unsigned char len;
        unsigned char i;
        __va_list ap;
        va_start(ap,fmt);
        vsprintf((char *)LCD_BUF,fmt,ap);
        va_end(ap);
        len=strlen((char *)LCD_BUF)+2*y;
        for(i=len;i<last_len[x];i++)
                LCD_BUF[i-2*y]=' ';
        LCD_BUF[i-2*y]=0;
        OLED_Print(x,y,LCD_BUF);
        last_len[x]=len;
junpeng324|  楼主 | 2018-11-30 23:54 | 显示全部楼层
void LCD19264_Init(void)
                        RST_L;
                        delay_ms(10);
                        RST_H;
                        delay_ms(10);
                        LCD19264_WriteCmd(0xe2);
                        delay_ms(5);
                        LCD19264_WriteCmd(0x81);
                        LCD19264_WriteCmd(0xb2);
                        LCD19264_WriteCmd(0xc2);
                        LCD19264_WriteCmd(0xaf);
nickqu| | 2018-12-18 09:35 | 显示全部楼层
楼主辛苦!
