[STM32]
请教独立看门狗定时器校准
489|0
chwf491701687|  楼主 | 2018-12-19 15:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
void TIM5_IRQHandler(void)
  if (TIM_GetITStatus(TIM5, TIM_IT_CC4) != RESET)
    if(CaptureNumber == 0)
      /* Get the Input Capture value */
      IC1ReadValue1 = TIM_GetCapture4(TIM5);
    else if(CaptureNumber == 1)
      IC1ReadValue2 = TIM_GetCapture4(TIM5);
      /* Capture computation */
      if (IC1ReadValue2 > IC1ReadValue1)
        Capture = (IC1ReadValue2 - IC1ReadValue1);
      else
        Capture = ((0xFFFF - IC1ReadValue1) + IC1ReadValue2);
      /* Frequency computation */
      LsiFreq = (uint32_t) SystemCoreClock / Capture;
      LsiFreq *= 8;
    CaptureNumber++;
    /* Clear TIM5 Capture compare interrupt pending bit */
    TIM_ClearITPendingBit(TIM5, TIM_IT_CC4);
ST官方的例程,用于检测内部LSI时钟频率,为什么计算出来的频率要乘以8
LsiFreq *= 8;
