[DemoCode下载] M051使用ADC测内部温度
993|11
 楼主| 玛尼玛尼哄 发表于 2018-12-23 00:36 | 显示全部楼层 |阅读模式
[M051][ADC]Measure_Internal_Temperature_Sensor.zip (496.55 KB, 下载次数: 19)
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
  4. * $Revision: 5 $
  5. * $Date: 14/01/28 11:44a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series ADC Interface Controller Driver Sample Code
  7. *
  8. * @note
  9. * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
  10. *
  11. ******************************************************************************/
  12. #include <stdio.h>
  13. #include "M051Series.h"
  14. #define PLL_CLOCK       50000000
  15. #define VBG                                                        1.20
  16. #define Offset                                        724
  17. #define Gain                                                -1.75
  18. /*---------------------------------------------------------------------------------------------------------*/
  19. /* Define Function Prototypes        */
  20. /*---------------------------------------------------------------------------------------------------------*/
  21. void SYS_Init(void);
  22. void UART0_Init(void);
  23. void AdcContScanModeTest(void);
  24. void SYS_Init(void)
  25. {
  26.     /*---------------------------------------------------------------------------------------------------------*/
  27.     /* Init System Clock        */
  28.     /*---------------------------------------------------------------------------------------------------------*/
  29.     /* Enable Internal RC 22.1184MHz clock */
  30.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  31.     /* Waiting for Internal RC clock ready */
  32.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  33.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  34.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  35.     /* Enable external XTAL 12MHz clock */
  36.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  37.     /* Waiting for external XTAL clock ready */
  38.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  39.     /* Set core clock as PLL_CLOCK from PLL */
  40.     CLK_SetCoreClock(PLL_CLOCK);
  41.     /* Enable UART module clock */
  42.     CLK_EnableModuleClock(UART0_MODULE);
  43.     /* Enable ADC module clock */
  44.     CLK_EnableModuleClock(ADC_MODULE);
  45.     /* Select UART module clock source */
  46.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  47.     /* ADC clock source is 22.1184MHz, set divider to 100, ADC clock is 22.1184/100 MHz */
  48.     CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(100));
  49.     /*---------------------------------------------------------------------------------------------------------*/
  50.     /* Init I/O Multi-function        */
  51.     /*---------------------------------------------------------------------------------------------------------*/
  52. }
  53. /*---------------------------------------------------------------------------------------------------------*/
  54. /* Init UART        */
  55. /*---------------------------------------------------------------------------------------------------------*/
  56. void UART0_Init()
  57. {
  58.     /* Reset IP */
  59.     SYS_ResetModule(UART0_RST);
  60.     /* Configure UART0 and set UART0 Baudrate */
  61.     UART_Open(UART0, 115200);
  62. }
  63. /*---------------------------------------------------------------------------------------------------------*/
  64. /* Function: AdcContScanModeTest        */
  65. /*        */
  66. /* Parameters:        */
  67. /*   None.        */
  68. /*        */
  69. /* Returns:        */
  70. /*   None.        */
  71. /*        */
  72. /* Description:        */
  73. /*   ADC continuous scan mode test.        */
  74. /*---------------------------------------------------------------------------------------------------------*/
  75. void AdcContScanModeTest()
  76. {
  77.     int32_t  i32ConversionData;
  78.                 double Vref;
  79.                 double TempData;
  80.     printf("+----------------------------------------------------------------------+\n");
  81.     printf("|                 ADC for temperature sensor sample code                 |\n");
  82.     printf("+----------------------------------------------------------------------+\n");
  83.     printf("\nIn this test, software will get value from temperature sensor.\n");
  84.                 /* Enable Tempreture Sensor function */
  85.                 SYS->TEMPCR = SYS_TEMPCR_VTEMP_EN_Msk;
  86.
  87.                 /* Set the ADC operation mode as continuous scan, input mode as single-end and
  88.                                  enable the analog input channel 7 */
  89.                 ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_CONTINUOUS, 0x80);
  90.                 /* Configure the analog input source of channel 7 */
  91.                 ADC_CONFIG_CH7(ADC, ADC_ADCHER_PRESEL_INT_BANDGAP);
  92.                 /* Power on ADC module */
  93.                 ADC_POWER_ON(ADC);
  94.                 /* clear the A/D interrupt flag for safe */
  95.                 ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  96.                 /* start A/D conversion */
  97.                 ADC_START_CONV(ADC);
  98.     while(1)
  99.     {
  100.                                         /* Wait conversion done */
  101.                                         while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
  102.
  103.                                         /* Stop A/D conversion */
  104.                                         ADC_STOP_CONV(ADC);
  105.
  106.                                         /* clear the A/D interrupt flag for safe */
  107.                                         ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  108.                                         /* Calculate Vref by using conversion result of VBG */
  109.                                         /* ConversionData = VBG * 4096 / Vref */
  110.                                         i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 7);
  111.                                         Vref = VBG * 4096 / (double)i32ConversionData;
  112.                                         /* Delay */
  113.                                         CLK_SysTickDelay(500000);
  114.
  115.                                         /* Configure the analog input source of channel 7 */
  116.                                         ADC_CONFIG_CH7(ADC, ADC_ADCHER_PRESEL_INT_TEMPERATURE_SENSOR);
  117.
  118.                                         /* start A/D conversion */
  119.                                         ADC_START_CONV(ADC);
  120.
  121.                                         /* Wait conversion done */
  122.                                         while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
  123.
  124.                                         /* Stop A/D conversion */
  125.                                         ADC_STOP_CONV(ADC);
  126.
  127.                                         /* clear the A/D interrupt flag for safe */
  128.                                         ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
  129.                                         /* Calculate value from temperature sensor */
  130.                                         /* ConversionData = Vtemp(V) * 4096 / Vref    */
  131.                                         /* Vtemp(mV) = Gain * Temperature + Offset */
  132.                                         i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, 7);
  133.                                         TempData = (((double)i32ConversionData * Vref / 4096) * 1000 - Offset) / Gain;
  134.                                         printf("Conversion result of channel %d: 0x%X (%.2f oC)\n", 7, i32ConversionData, TempData);
  135.                                         /* Delay */
  136.                                         CLK_SysTickDelay(500000);
  137.
  138.                                         /* Configure the analog input source of channel 7 */
  139.                                         ADC_CONFIG_CH7(ADC, ADC_ADCHER_PRESEL_INT_BANDGAP);
  140.
  141.                                         /* start A/D conversion */
  142.                                         ADC_START_CONV(ADC);
  143.      }
  144. }
  145. /*---------------------------------------------------------------------------------------------------------*/
  146. /* MAIN function        */
  147. /*---------------------------------------------------------------------------------------------------------*/
  148. int main(void)
  149. {
  150.     /* Unlock protected registers */
  151.     SYS_UnlockReg();
  152.     /* Init System, IP clock and multi-function I/O */
  153.     SYS_Init();
  154.     /* Lock protected registers */
  155.     SYS_LockReg();
  156.     /* Init UART0 for printf */
  157.     UART0_Init();
  158.     /*---------------------------------------------------------------------------------------------------------*/
  159.     /* SAMPLE CODE        */
  160.     /*---------------------------------------------------------------------------------------------------------*/
  161.     printf("\nSystem clock rate: %d Hz\n", SystemCoreClock);
  162.     /* Continuous scan mode test */
  163.     AdcContScanModeTest();
  164.     /* Disable ADC module */
  165.     ADC_Close(ADC);
  166.     /* Disable ADC IP clock */
  167.     CLK_DisableModuleClock(ADC_MODULE);
  168.     /* Disable External Interrupt */
  169.     NVIC_DisableIRQ(ADC_IRQn);
  170.     printf("\nExit ADC sample code\n");
  171.     while(1);
  172. }
 楼主| 玛尼玛尼哄 发表于 2018-12-23 00:37 | 显示全部楼层
好多人不知道怎么操作。官方其实提供了例子,我找到分享给各位。
huangcunxiake 发表于 2018-12-23 09:28 | 显示全部楼层
这一句是滚ADC不同的地方。
huangcunxiake 发表于 2018-12-23 09:29 | 显示全部楼层
有的传感器开关,打开,然后其他就是配置ADC通道了。
wahahaheihei 发表于 2018-12-23 10:23 | 显示全部楼层
这个我已经会了,之前做过几次。主要用于内部温度监控,不需要测太多次。
antusheng 发表于 2018-12-23 20:16 | 显示全部楼层
转换公式
xinxianshi 发表于 2018-12-23 23:01 | 显示全部楼层
不知道准不准啊。
598330983 发表于 2018-12-23 23:53 | 显示全部楼层
我的板子被人借走了,下次要回来再玩玩。
734774645 发表于 2018-12-23 23:55 | 显示全部楼层
ADC功能很强,还可以测内部
zhuomuniao110 发表于 2018-12-24 12:30 | 显示全部楼层
因为这个不常用,可以封装到一个函数里,直接调用。
paotangsan 发表于 2019-1-8 11:48 | 显示全部楼层
准确性如何?差多少大概
