[DemoCode下载]
M451多通道连续中断触发
644|8
wanduzi|  楼主 | 2019-1-19 22:38 | 显示全部楼层 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 6 $
* $Date: 15/09/02 10:04a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Use ADINT interrupt to do the ADC continuous scan conversion.
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
#include "stdio.h"
#include "M451Series.h"
#define PLLCTL_SETTING      CLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK           72000000
/* Define global variables and constants        */
volatile uint32_t g_u32AdcIntFlag, g_u32COVNUMFlag = 0;
/* Define functions prototype        */
int32_t main(void);
void EADC_FunctionTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set PLL to Power-down mode and PLLSTB bit in CLK_STATUS register will be cleared by hardware.*/
    CLK_DisablePLL();
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Enable EADC module clock */
    CLK_EnableModuleClock(EADC_MODULE);
    /* EADC clock source is 72MHz, set divider to 8, ADC clock is 72/8 MHz */
    CLK_SetModuleClock(EADC_MODULE, 0, CLK_CLKDIV0_EADC(8));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Configure the GPB0 - GPB3 ADC analog input pins.  */
    SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB0MFP_Msk | SYS_GPB_MFPL_PB1MFP_Msk |
                       SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk);
    SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB0MFP_EADC_CH0 | SYS_GPB_MFPL_PB1MFP_EADC_CH1 |
                      SYS_GPB_MFPL_PB2MFP_EADC_CH2 | SYS_GPB_MFPL_PB3MFP_EADC_CH3);
    /* Disable the GPB0 - GPB3 digital input path to avoid the leakage current. */
    GPIO_DISABLE_DIGITAL_PATH(PB, 0xF);
void UART0_Init()
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
/* EADC function test        */
void EADC_FunctionTest()
    uint8_t  u8Option, u32SAMPLECount = 0;
    int32_t  i32ConversionData[8] = {0};
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                      ADINT trigger mode test                         |\n");
    printf("\nIn this test, software will get 2 cycles of conversion result from the specified channels.\n");
    while(1)
        printf("\n\nSelect input mode:\n");
        printf("  [1] Single end input (channel 0, 1, 2 and 3)\n");
        printf("  [2] Differential input (input channel pair 0 and 1)\n");
        printf("  Other keys: exit continuous scan mode test\n");
        u8Option = getchar();
        if(u8Option == '1')
            /* Set the ADC internal sampling time, input mode as single-end and enable the A/D converter */
            EADC_Open(EADC, EADC_CTL_DIFFEN_SINGLE_END);
            EADC_SetInternalSampleTime(EADC, 6);
            /* Configure the sample 4 module for analog input channel 0 and enable ADINT0 trigger source */
            EADC_ConfigSampleModule(EADC, 4, EADC_ADINT0_TRIGGER, 0);
            /* Configure the sample 5 module for analog input channel 1 and enable ADINT0 trigger source */
            EADC_ConfigSampleModule(EADC, 5, EADC_ADINT0_TRIGGER, 1);
            /* Configure the sample 6 module for analog input channel 2 and enable ADINT0 trigger source */
            EADC_ConfigSampleModule(EADC, 6, EADC_ADINT0_TRIGGER, 2);
            /* Configure the sample 7 module for analog input channel 3 and enable ADINT0 trigger source */
            EADC_ConfigSampleModule(EADC, 7, EADC_ADINT0_TRIGGER, 3);
            /* Clear the A/D ADINT0 interrupt flag for safe */
            EADC_CLR_INT_FLAG(EADC, 0x1);
            /* Enable the sample module 7 interrupt */
            EADC_ENABLE_INT(EADC, 0x1);//Enable sample module  A/D ADINT0 interrupt.
            EADC_ENABLE_SAMPLE_MODULE_INT(EADC, 0, (0x1 << 7));//Enable sample module 7 interrupt.
            NVIC_EnableIRQ(ADC00_IRQn);
            /* Reset the ADC indicator and trigger sample module 7 to start A/D conversion */
            g_u32AdcIntFlag = 0;
            EADC_START_CONV(EADC, (0x1 << 7));
            /* Wait EADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function) */
            while(g_u32AdcIntFlag == 0);
            /* Reset the EADC interrupt indicator */
            /* Disable the sample module 7 interrupt */
            EADC_DISABLE_SAMPLE_MODULE_INT(EADC, 0, (0x1 << 7));
            /* Get the conversion result of the sample module */
            for(u32SAMPLECount = 0; u32SAMPLECount < 4; u32SAMPLECount++)
                i32ConversionData[u32SAMPLECount] = EADC_GET_CONV_DATA(EADC, (u32SAMPLECount + 4));
            /* Wait conversion done */
            while(EADC_GET_DATA_VALID_FLAG(EADC, 0xF0) != 0xF0);
            for(u32SAMPLECount = 4; u32SAMPLECount < 8; u32SAMPLECount++)
                i32ConversionData[u32SAMPLECount] = EADC_GET_CONV_DATA(EADC, u32SAMPLECount);
            for(g_u32COVNUMFlag = 0; (g_u32COVNUMFlag) < 8; g_u32COVNUMFlag++)
                printf("Conversion result of channel %d: 0x%X (%d)\n", (g_u32COVNUMFlag % 4), i32ConversionData[g_u32COVNUMFlag], i32ConversionData[g_u32COVNUMFlag]);
        else if(u8Option == '2')
            /* Set the ADC internal sampling time, input mode as differential and enable the A/D converter */
            EADC_Open(EADC, EADC_CTL_DIFFEN_DIFFERENTIAL);
            /* Configure the sample module 4 for analog input channel 0 and enable ADINT0 trigger source */
            /* Configure the sample module 5 for analog input channel 1 and enable ADINT0 trigger source */
            /* Configure the sample module 6 for analog input channel 2 and enable ADINT0 trigger source */
            /* Configure the sample module 7 for analog input channel 3 and enable ADINT0 trigger source */
        else
            return ;
/* EADC interrupt handler        */
void ADC00_IRQHandler(void)
    g_u32AdcIntFlag = 1;
    EADC_CLR_INT_FLAG(EADC, 0x1);      /* Clear the A/D ADINT0 interrupt flag */
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    EADC_FunctionTest();
    /* Reset EADC module */
    SYS_ResetModule(EADC_RST);
    /* Disable EADC IP clock */
    CLK_DisableModuleClock(EADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC00_IRQn);
    printf("Exit EADC sample code\n");
    while(1);
wanduzi|  楼主 | 2019-1-19 23:07 | 显示全部楼层
该例子分2个部分测试:0,1,2,3一共4个通道,作为单输入时候的中断触发方式。
另外一个就是采用通道0和1作为一个一对的输入方式。
wanduzi|  楼主 | 2019-1-19 23:09 | 显示全部楼层
这里在等待中断函数里置位。
wanduzi|  楼主 | 2019-1-19 23:11 | 显示全部楼层
注意到这里重复搞了两次。莫非是程序员不小心复制粘贴了一回?值得思考。
那么重复一次是否有效呢?
不过可以看出这里重复一次,肯定是把第一次的数据给丢了。
wanduzi|  楼主 | 2019-1-19 23:12 | 显示全部楼层
ADC0的中断里,仅仅做了基本的操作。这里是我们学习的地方。不要搞太多。
wanduzi|  楼主 | 2019-1-19 23:18 | 显示全部楼层
这里的操作看着是重复的,实际上获取了两次数据。
存在了同一个数组里。
wanduzi|  楼主 | 2019-1-19 23:19 | 显示全部楼层
这个打印输出也是将两次的内容输出出来,但是作为统一的标号。
作者的深意在哪里?
wanduzi|  楼主 | 2019-1-19 23:21 | 显示全部楼层
只有你自己跑一跑,改一改,才好更好的理解。
dongnanxibei| | 2019-1-21 23:50 | 显示全部楼层
451的看着就比051的复杂多了,功能更强,更丰富了。
