[技术问答]
M451系列,ADC如何设置50HZ一次多通道采集一次?
1396|7
libinskk|  楼主 | 2019-1-21 20:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
xixi2017| | 2019-1-21 21:16 | 只看该作者
定时器触发。
xixi2017| | 2019-1-21 21:18 | 只看该作者
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 5 $
* $Date: 15/09/02 10:04a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Show how to trigger ADC by timer.
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
#include "stdio.h"
#include "M451Series.h"
#define PLLCTL_SETTING      CLK_PLLCTL_72MHz_HXT
#define PLL_CLOCK           72000000
/* Define global variables and constants        */
volatile uint32_t g_u32AdcIntFlag, g_u32COVNUMFlag = 0;
/* Define functions prototype        */
int32_t main(void);
void EADC_FunctionTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK source divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Set PLL to Power-down mode and PLLSTB bit in CLK_STATUS register will be cleared by hardware.*/
    CLK_DisablePLL();
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Enable EADC module clock */
    CLK_EnableModuleClock(EADC_MODULE);
    /* EADC clock source is 72MHz, set divider to 8, ADC clock is 72/8 MHz */
    CLK_SetModuleClock(EADC_MODULE, 0, CLK_CLKDIV0_EADC(8));
    /* Enable Timer 0 module clock */
    CLK_EnableModuleClock(TMR0_MODULE);
    /* Select timer 0 module clock source as HXT */
    CLK_SetModuleClock(TMR0_MODULE, CLK_CLKSEL1_TMR0SEL_HXT, 0);
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Configure the GPB0 - GPB3 ADC analog input pins.  */
    SYS->GPB_MFPL &= ~(SYS_GPB_MFPL_PB0MFP_Msk | SYS_GPB_MFPL_PB1MFP_Msk |
                       SYS_GPB_MFPL_PB2MFP_Msk | SYS_GPB_MFPL_PB3MFP_Msk);
    SYS->GPB_MFPL |= (SYS_GPB_MFPL_PB0MFP_EADC_CH0 | SYS_GPB_MFPL_PB1MFP_EADC_CH1 |
                      SYS_GPB_MFPL_PB2MFP_EADC_CH2 | SYS_GPB_MFPL_PB3MFP_EADC_CH3);
    /* Disable the GPB0 - GPB3 digital input path to avoid the leakage current. */
    GPIO_DISABLE_DIGITAL_PATH(PB, 0xF);
void UART0_Init()
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
void TIMER0_Init()
    /* Init TIMER0        */
    /* Set timer0 periodic time-out period is 3us if timer clock is 12 MHz */
    TIMER_SET_CMP_VALUE(TIMER0, 36);//TIMER0->CMP = 36;
    /* Start timer counter in periodic mode and enable timer interrupt trigger EADC */
    TIMER0->CTL = TIMER_PERIODIC_MODE | TIMER_CTL_TRGEADC_Msk;
/* EADC function test        */
void EADC_FunctionTest()
    uint8_t  u8Option;
    int32_t  i32ConversionData[6] = {0};
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                      Timer trigger mode test                         |\n");
    printf("\nIn this test, software will get 6 conversion result from the specified channel.\n");
    while(1)
        printf("Select input mode:\n");
        printf("  [1] Single end input (channel 2 only)\n");
        printf("  [2] Differential input (channel pair 1 only)\n");
        printf("  Other keys: exit single mode test\n");
        u8Option = getchar();
        if(u8Option == '1')
            /* Set the ADC internal sampling time, input mode as single-end and enable the A/D converter */
            EADC_Open(EADC, EADC_CTL_DIFFEN_SINGLE_END);
            EADC_SetInternalSampleTime(EADC, 6);
            /* Configure the sample module 0 for analog input channel 2 and enable Timer0 trigger source */
            EADC_ConfigSampleModule(EADC, 0, EADC_TIMER0_TRIGGER, 2);
            /* Clear the A/D ADINT0 interrupt flag for safe */
            EADC_CLR_INT_FLAG(EADC, 0x1);
            /* Enable the sample module 0 interrupt.  */
            EADC_ENABLE_INT(EADC, 0x1);//Enable sample module A/D ADINT0 interrupt.
            EADC_ENABLE_SAMPLE_MODULE_INT(EADC, 0, 0x1);//Enable sample module 0 interrupt.
            NVIC_EnableIRQ(ADC00_IRQn);
            printf("Conversion result of channel 2:\n");
            /* Reset the ADC indicator and enable Timer0 counter */
            g_u32AdcIntFlag = 0;
            TIMER_Start(TIMER0);
            while(1)
                /* Wait ADC interrupt (g_u32AdcIntFlag will be set at IRQ_Handler function) */
                while(g_u32AdcIntFlag == 0);
                /* Reset the EADC interrupt indicator */
                /* Get the conversion result of the sample module 0 */
                i32ConversionData[g_u32COVNUMFlag - 1] = EADC_GET_CONV_DATA(EADC, 0);
                if(g_u32COVNUMFlag > 6)
                    break;
            /* Disable Timer0 counter */
            TIMER_Stop(TIMER0);
            /* Disable the ADINT0 interrupt */
            EADC_DISABLE_INT(EADC, 0x1);
            for(g_u32COVNUMFlag = 0; (g_u32COVNUMFlag) < 6; g_u32COVNUMFlag++)
                printf("                                0x%X (%d)\n", i32ConversionData[g_u32COVNUMFlag], i32ConversionData[g_u32COVNUMFlag]);
        else if(u8Option == '2')
            /* Set the ADC internal sampling time, input mode as differential and enable the A/D converter */
            EADC_Open(EADC, EADC_CTL_DIFFEN_DIFFERENTIAL);
            printf("Conversion result of channel pair 1:\n");
            /* Reset the EADC indicator and enable Timer0 counter */
            while(1)
                /* Reset the ADC interrupt indicator */
                    break;
            TIMER_Stop(TIMER0);
        else
            return ;
/* EADC interrupt handler        */
void ADC00_IRQHandler(void)
    g_u32AdcIntFlag = 1;
    g_u32COVNUMFlag++;
    EADC_CLR_INT_FLAG(EADC, 0x1);/* Clear the A/D ADINT0 interrupt flag */
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Init TIMER0 for EADC */
    TIMER0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    EADC_FunctionTest();
    /* Reset Timer0 module */
    SYS_ResetModule(TMR0_RST);
    /* Reset EADC module */
    SYS_ResetModule(EADC_RST);
    /* Disable Timer0 IP clock */
    CLK_DisableModuleClock(TMR0_MODULE);
    /* Disable EADC IP clock */
    CLK_DisableModuleClock(EADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC00_IRQn);
    printf("Exit EADC sample code\n");
    while(1);
dongnanxibei| | 2019-1-21 23:51 | 只看该作者
定时器中断里触发采集。
libinskk|  楼主 | 2019-1-22 10:53 | 只看该作者
如何比较高效的读呢?比如50Hz一次,我触发6个通道,等它们转换完成了,我在哪里读比较好?我不想等待。
yiyigirl2014| | 2019-1-22 14:07 | 只看该作者
在主函数读就行了。只要主函数的循环周期大于50Hz
mintspring| | 2019-1-23 00:04 | 只看该作者
定时器50Hz,触发一次就行了。
heisexingqisi| | 2019-1-23 17:30 | 只看该作者
先学会定时器中断啊。
