技术达人
- 积分
- 8042
- 在线时间
- 325 小时
- 精华
- 0
- 注册时间
- 2015-9-6
- 最后登录
- 2019-2-22
- /* Copyright(c) 2017 Nuvoton Technology Corp. All rights reserved. */
- // Nuvoton Technoledge Corp.
- // Website: http://www.nuvoton.com
- // E-Mail : MicroC-8bit@nuvoton.com
- // Date : Apr/21/2017
- // File Function: N76E003 UART-1 Mode1 demo code
- #include "N76E003.h"
- #include "Common.h"
- #include "Delay.h"
- #include "SFR_Macro.h"
- #include "Function_define.h"
- #define BUFFER_SIZE 16
- UINT8 UART_BUFFER[BUFFER_SIZE],temp;
- UINT16 u16CNT=0,u16CNT1=0;
- bit riflag;
- * FUNCTION_PURPOSE: Serial port 1 interrupt, echo received data.
- * FUNCTION_INPUTS : P0.2(RXD) serial input
- * FUNCTION_OUTPUTS: P1.6(TXD) serial output
- * Following setting in Common.c
- #if 0
- //void InitialUART1_Timer3(UINT32 u32Baudrate) //use timer3 as Baudrate generator
- // P02_Quasi_Mode; //Setting UART pin as Quasi mode for transmit
- // P16_Quasi_Mode; //Setting UART pin as Quasi mode for transmit
- // SCON_1 = 0x50; //UART1 Mode1,REN_1=1,TI_1=1
- // T3CON = 0x08; //T3PS2=0,T3PS1=0,T3PS0=0(Prescale=1), UART1 in MODE 1
- // clr_BRCK;
- //#ifdef FOSC_160000
- // RH3 = HIBYTE(65536 - (1000000/u32Baudrate)-1); /*16 MHz */
- // RL3 = LOBYTE(65536 - (1000000/u32Baudrate)-1); /*16 MHz */
- //#endif
- //#ifdef FOSC_166000
- // RH3 = HIBYTE(65536 - (1037500/u32Baudrate)); /*16.6 MHz */
- // RL3 = LOBYTE(65536 - (1037500/u32Baudrate)); /*16.6 MHz */
- //#endif
- // set_TR3; //Trigger Timer3
- #endif
- void SerialPort1_ISR(void) interrupt 15
- if (RI_1==1)
- { /* if reception occur */
- clr_RI_1; /* clear reception flag for next reception */
- UART_BUFFER[u16CNT] = SBUF_1;
- u16CNT ++;
- riflag =1;
- if(TI_1==1)
- clr_TI_1; /* if emission occur */
- * FUNCTION_PURPOSE: Main function
- !!! N76E003 UART1 pin also occupied by debug pin,
- please remove Nu-link or not in debug mode to test UART1 function.
- External UART1 connect also disturb debug download
- void main (void)
- P12_PushPull_Mode; // For I/O toggle display
- #if 0
- //for Simple use UART1 transmit out
- InitialUART1_Timer3(115200);
- while(1)
- Send_Data_To_UART1(0x55);
- #else
- // For interrupt setting check receive
- set_ES_1; //For interrupt enable
- set_EA;
- while(1)
- if (riflag)
- P12 = ~ P12; //Receive each byte P12 toggle, never work under debug mode
- riflag = 0;
- #endif
复制代码 |
