GD32E103/GD32F103 各种AD采样程序分享
11429|30
xiaobai032|  楼主 | 2019-2-14 21:57 | 显示全部楼层 |阅读模式
本人使用GD32E103一段时间,在兆易创新技术的不断帮助下,终于攻克一个个难关。在此感谢兆易创新的技术支持们。分享AD采样程序如下。
斯坦科伦 2021-6-21 09:46 回复TA
谢谢
leo1288 2020-3-23 07:32 回复TA
请问楼主在\brief ADC1 resolution一例中,adc_resolution_config(ADC1, ADC_RESOLUTION_6B);函数是什么功能,方便把这个函数代码贴出来吗?谢谢
LED2013 2019-2-17 13:17 回复TA
就是需要更多的实例分享
xiaobai032|  楼主 | 2019-2-14 21:59 | 显示全部楼层
    \file  main.c
    \brief ADC0 ADC1 regular parallel
    \version 2017-12-26, V1.0.0, firmware for GD32E10x
    Copyright (c) 2017, GigaDevice Semiconductor Inc.
    All rights reserved.
    Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
    1. Redistributions of source code must retain the above copyright notice, this
       list of conditions and the following disclaimer.
    2. Redistributions in binary form must reproduce the above copyright notice,
       this list of conditions and the following disclaimer in the documentation
       and/or other materials provided with the distribution.
    3. Neither the name of the copyright holder nor the names of its contributors
       may be used to endorse or promote products derived from this software without
       specific prior written permission.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
OF SUCH DAMAGE.
#include "gd32e10x.h"
#include "systick.h"
#include <stdio.h>
#include "main.h"
#include "gd32e10x_eval.h"
uint32_t adc_value[2];
void rcu_config(void);
void gpio_config(void);
void dma_config(void);
void timer_config(void);
void adc_config(void);
void usart_config(void);
    \brief      main function
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    /* system clocks configuration */
    rcu_config();
    /* systick configuration */
    systick_config();
    /* GPIO configuration */
    gpio_config();
    /* TIMER configuration */
    timer_config();
    /* DMA configuration */
    dma_config();
    /* ADC configuration */
    adc_config();
    /* USART configuration */
    gd_eval_com_init(EVAL_COM0);
    /* enable TIMER1 */
    timer_enable(TIMER1);
    while(1){
        delay_1ms(100);
        printf("\n adc_value[0] = %08X \n",adc_value[0]);
        printf("\n adc_value[1] = %08X \n",adc_value[1]);
        printf("\n ******************* \n");
    \brief      configure the different system clocks
    \param[in]  none
    \param[out] none
    \retval     none
    /* enable GPIOA clock */
    rcu_periph_clock_enable(RCU_GPIOA);
    /* enable GPIOC clock */
    rcu_periph_clock_enable(RCU_GPIOC);
    /* enable ADC0 clock */
    rcu_periph_clock_enable(RCU_ADC0);
    /* enable ADC1 clock */
    rcu_periph_clock_enable(RCU_ADC1);
    /* enable DMA0 clock */
    rcu_periph_clock_enable(RCU_DMA0);
    /* enable timer1 clock */
    rcu_periph_clock_enable(RCU_TIMER1);
    /* config ADC clock */
    rcu_adc_clock_config(RCU_CKADC_CKAPB2_DIV4);
    \brief      configure the GPIO peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    /* config the GPIO as analog mode */
    gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_MAX, GPIO_PIN_4);
    gpio_init(GPIOC, GPIO_MODE_AIN, GPIO_OSPEED_MAX, GPIO_PIN_3);
    \brief      configure the DMA peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    /* ADC_DMA_channel configuration */
    dma_parameter_struct dma_data_parameter;
    /* ADC DMA_channel configuration */
    dma_deinit(DMA0, DMA_CH0);
    /* initialize DMA data mode */
    dma_data_parameter.periph_addr = (uint32_t)(&ADC_RDATA(ADC0));
    dma_data_parameter.periph_inc = DMA_PERIPH_INCREASE_DISABLE;
    dma_data_parameter.memory_addr = (uint32_t)(&adc_value);
    dma_data_parameter.memory_inc = DMA_MEMORY_INCREASE_ENABLE;
    dma_data_parameter.periph_width = DMA_PERIPHERAL_WIDTH_32BIT;
    dma_data_parameter.memory_width = DMA_MEMORY_WIDTH_32BIT;
    dma_data_parameter.direction = DMA_PERIPHERAL_TO_MEMORY;
    dma_data_parameter.number = 2;
    dma_data_parameter.priority = DMA_PRIORITY_HIGH;
    dma_init(DMA0, DMA_CH0, &dma_data_parameter);
    dma_circulation_enable(DMA0, DMA_CH0);
    /* enable DMA channel */
    dma_channel_enable(DMA0, DMA_CH0);
    \brief      configure the TIMER peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    timer_oc_parameter_struct timer_ocintpara;
    timer_parameter_struct timer_initpara;
    /* deinit a timer */
    timer_deinit(TIMER1);
    /* initialize TIMER init parameter struct */
    timer_struct_para_init(&timer_initpara);
    /* TIMER1 configuration */
    timer_initpara.prescaler         = 8399;
    timer_initpara.alignedmode       = TIMER_COUNTER_EDGE;
    timer_initpara.counterdirection  = TIMER_COUNTER_UP;
    timer_initpara.period            = 9999;
    timer_initpara.clockdivision     = TIMER_CKDIV_DIV1;
    timer_initpara.repetitioncounter = 0;
    timer_init(TIMER1,&timer_initpara);
    /* CH0 configuration in PWM mode1 */
    timer_ocintpara.ocpolarity  = TIMER_OC_POLARITY_HIGH;
    timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
    timer_channel_output_config(TIMER1, TIMER_CH_1, &timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER1, TIMER_CH_1, 3999);
    timer_channel_output_mode_config(TIMER1, TIMER_CH_1, TIMER_OC_MODE_PWM1);
    timer_channel_output_shadow_config(TIMER1, TIMER_CH_1, TIMER_OC_SHADOW_DISABLE);
    \brief      configure the ADC peripheral
    \param[in]  none
    \param[out] none
    \retval     none
   /* reset ADC */
    adc_deinit(ADC0);
    adc_deinit(ADC1);
    /* ADC mode config */
    adc_mode_config(ADC_DAUL_REGULAL_PARALLEL);
    /* ADC continous function enable */
    adc_special_function_config(ADC0, ADC_SCAN_MODE, ENABLE);
    adc_special_function_config(ADC1, ADC_SCAN_MODE, ENABLE);
    /* ADC data alignment config */
    adc_data_alignment_config(ADC0, ADC_DATAALIGN_RIGHT);
    adc_data_alignment_config(ADC1, ADC_DATAALIGN_RIGHT);
    /* ADC channel length config */
    adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 2);
    adc_channel_length_config(ADC1, ADC_REGULAR_CHANNEL, 2);
    /* ADC regular channel config */
    adc_regular_channel_config(ADC0, 0, ADC_CHANNEL_13, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_4, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC1, 0, ADC_CHANNEL_4, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC1, 1, ADC_CHANNEL_13, ADC_SAMPLETIME_55POINT5);
    /* ADC trigger config */
    adc_external_trigger_source_config(ADC0, ADC_REGULAR_CHANNEL, ADC0_1_EXTTRIG_REGULAR_T1_CH1);
    adc_external_trigger_source_config(ADC1, ADC_REGULAR_CHANNEL, ADC0_1_EXTTRIG_REGULAR_NONE);
    /* ADC external trigger enable */
    adc_external_trigger_config(ADC0, ADC_REGULAR_CHANNEL, ENABLE);
    adc_external_trigger_config(ADC1, ADC_REGULAR_CHANNEL, ENABLE);
    /* enable ADC interface */
    adc_enable(ADC0);
    delay_1ms(1);
    /* ADC calibration and reset calibration */
    adc_calibration_enable(ADC0);
    adc_enable(ADC1);
    delay_1ms(1);
    adc_calibration_enable(ADC1);
    /* ADC DMA function enable */
    adc_dma_mode_enable(ADC0);
/* retarget the C library printf function to the USART */
int fputc(int ch, FILE *f)
    usart_data_transmit(USART0, (uint8_t)ch);
    while(RESET == usart_flag_get(USART0, USART_FLAG_TBE));
    return ch;
xiaobai032|  楼主 | 2019-2-14 22:01 | 显示全部楼层
    \file  main.c
    \brief ADC0 EXTI trigger regular and inserted channel
OF SUCH DAMAGE.
#include <stdio.h>
#include "main.h"
uint16_t adc_value[4];
uint16_t inserted_data[4];
void nvic_config(void);
void exti_config(void);
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_config();
    gpio_config();
    /* configure the EXTI peripheral */
    exti_config();
    systick_config();
    /* NVIC configuration */
    nvic_config();
    /* configure COM port */
    gd_eval_com_init(EVAL_COM1);
    dma_config();
    adc_config();
    while(1){
        delay_1ms(1000);
        printf("\r\n ADC0 regular channel 0 data = %d \r\n",adc_value[0]);
        printf("\r\n ADC0 regular channel 1 data = %d \r\n",adc_value[1]);
        printf("\r\n ADC0 regular channel 2 data = %d \r\n",adc_value[2]);
        printf("\r\n ADC0 regular channel 3 data = %d \r\n",adc_value[3]);
        printf("\r\n ADC0 inserted channel 0 data = %d \r\n",inserted_data[0]);
        printf("\r\n ADC0 inserted channel 1 data = %d \r\n",inserted_data[1]);
        printf("\r\n ADC0 inserted channel 2 data = %d \r\n",inserted_data[2]);
        printf("\r\n ADC0 inserted channel 3 data = %d \r\n",inserted_data[3]);
        printf("\r\n ***********************************\r\n");
    \param[in]  none
    \param[out] none
    \retval     none
    /* enable GPIOB clock */
    rcu_periph_clock_enable(RCU_GPIOB);
    /* enable alternate function clock */
    rcu_periph_clock_enable(RCU_AF);
    \param[in]  none
    \param[out] none
    \retval     none
    /* config the GPIO as analog mode, for ADC */
    gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_MAX, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3);
    gpio_init(GPIOA, GPIO_MODE_AIN, GPIO_OSPEED_MAX, GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7);
    /* config the GPIO as floating input mode, for EXTI */
    gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_11);
    gpio_init(GPIOB, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_15);
    \brief      configure the nested vectored interrupt controller
    \param[in]  none
    \param[out] none
    \retval     none
    nvic_priority_group_set(NVIC_PRIGROUP_PRE1_SUB3);
    nvic_irq_enable(ADC0_1_IRQn, 1, 1);
    \param[in]  none
    \param[out] none
    \retval     none
    /* initialize DMA single data mode */
    dma_data_parameter.periph_width = DMA_PERIPHERAL_WIDTH_16BIT;
    dma_data_parameter.memory_width = DMA_MEMORY_WIDTH_16BIT;
    dma_data_parameter.number = 4;
    /* enable DMA circulation mode */
    \param[in]  none
    \param[out] none
    \retval     none
    /* reset ADC */
    adc_deinit(ADC0);
    adc_mode_config(ADC_MODE_FREE);
    adc_channel_length_config(ADC0, ADC_INSERTED_CHANNEL, 4);
    /* ADC inserted channel config */
    adc_inserted_channel_config(ADC0, 0, ADC_CHANNEL_0, ADC_SAMPLETIME_55POINT5);
    adc_inserted_channel_config(ADC0, 1, ADC_CHANNEL_1, ADC_SAMPLETIME_55POINT5);
    adc_inserted_channel_config(ADC0, 2, ADC_CHANNEL_2, ADC_SAMPLETIME_55POINT5);
    adc_inserted_channel_config(ADC0, 3, ADC_CHANNEL_3, ADC_SAMPLETIME_55POINT5);
    adc_external_trigger_source_config(ADC0, ADC_INSERTED_CHANNEL, ADC0_1_EXTTRIG_INSERTED_EXTI_15);
    adc_external_trigger_config(ADC0, ADC_INSERTED_CHANNEL, ENABLE);
    /* clear the ADC flag */
    adc_interrupt_flag_clear(ADC0, ADC_INT_FLAG_EOC);
    adc_interrupt_flag_clear(ADC0, ADC_INT_FLAG_EOIC);
    /* enable ADC interrupt */
    adc_interrupt_enable(ADC0, ADC_INT_EOIC);
    adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 4);
    adc_regular_channel_config(ADC0, 0, ADC_CHANNEL_4, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_5, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 2, ADC_CHANNEL_6, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 3, ADC_CHANNEL_7, ADC_SAMPLETIME_55POINT5);
    adc_external_trigger_source_config(ADC0, ADC_REGULAR_CHANNEL, ADC0_1_EXTTRIG_REGULAR_EXTI_11);
    adc_enable(ADC0);
    delay_1ms(1);
    \brief      configure the EXTI peripheral
    \param[in]  none
    \param[out] none
    \retval     none
    /* connect EXTI line to GPIO pin for inserted group */
    gpio_exti_source_select(GPIO_PORT_SOURCE_GPIOB, GPIO_PIN_SOURCE_15);
    /* configure EXTI line for inserted group */
    exti_init(EXTI_15, EXTI_EVENT, EXTI_TRIG_RISING);
    gpio_exti_source_select(GPIO_PORT_SOURCE_GPIOA, GPIO_PIN_SOURCE_11);
    exti_init(EXTI_11, EXTI_EVENT, EXTI_TRIG_RISING);
    usart_data_transmit(EVAL_COM1, (uint8_t)ch);
    while(RESET == usart_flag_get(EVAL_COM1, USART_FLAG_TBE));
    return ch;
xiaobai032|  楼主 | 2019-2-14 22:04 | 显示全部楼层
    \file  main.c
    \brief ADC0 regular channel discontinuous mode
OF SUCH DAMAGE.
#include <stdio.h>
#include "main.h"
uint16_t adc_value[8];
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_config();
    systick_config();
    gpio_config();
    exti_config();
    dma_config();
    adc_config();
    while(1){
        /* delay 1s */
        delay_1ms(1000);
        printf("\r\n ADC0 regular channel discontinuous mode 1st data: \r\n");
        printf("\r\n ADC0 regular channel discontinuous mode 2st data: \r\n");
        printf("\r\n ADC0 regular channel 4 data = %d \r\n",adc_value[4]);
        printf("\r\n ADC0 regular channel 5 data = %d \r\n",adc_value[5]);
        printf("\r\n ADC0 regular channel discontinuous mode 3st data: \r\n");
        printf("\r\n ADC0 regular channel 6 data = %d \r\n",adc_value[6]);
        printf("\r\n ADC0 regular channel 7 data = %d \r\n",adc_value[7]);
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    dma_data_parameter.number = 8;
    \param[in]  none
    \param[out] none
    \retval     none
    /* reset ADC */
    adc_deinit(ADC0);
    adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 8);
    adc_regular_channel_config(ADC0, 0, ADC_CHANNEL_0, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 1, ADC_CHANNEL_1, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 2, ADC_CHANNEL_2, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 3, ADC_CHANNEL_3, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 4, ADC_CHANNEL_4, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 5, ADC_CHANNEL_5, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 6, ADC_CHANNEL_6, ADC_SAMPLETIME_55POINT5);
    adc_regular_channel_config(ADC0, 7, ADC_CHANNEL_7, ADC_SAMPLETIME_55POINT5);
    /* ADC discontinuous mode */
    adc_discontinuous_mode_config(ADC0, ADC_REGULAR_CHANNEL, 3);
    adc_enable(ADC0);
    delay_1ms(1);
    \param[in]  none
    \param[out] none
    \retval     none
    return ch;
    \file  main.c
    \brief ADC0 regular channel with DMA
OF SUCH DAMAGE.
#include <stdio.h>
#include "main.h"
#define BOARD_ADC_CHANNEL ADC_CHANNEL_13
#define ADC_GPIO_PORT GPIOC
#define ADC_GPIO_PIN  GPIO_PIN_3
uint16_t adc_value;
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_config();
    systick_config();
    gpio_config();
    dma_config();
    adc_config();
    exti_config();
    while(1){
        delay_1ms(1000);
        printf("\r\n ADC0 regular channel data = %d \r\n",adc_value);
        printf("\r\n *********************************\r\n");
    \param[in]  none
    \param[out] none
    \retval     none
    /* enable ADC clock */
    \param[in]  none
    \param[out] none
    \retval     none
    gpio_init(ADC_GPIO_PORT, GPIO_MODE_AIN, GPIO_OSPEED_MAX, ADC_GPIO_PIN);
    \param[in]  none
    \param[out] none
    \retval     none
    dma_data_parameter.memory_inc = DMA_MEMORY_INCREASE_DISABLE;
    dma_data_parameter.number = 1;
    \param[in]  none
    \param[out] none
    \retval     none
    /* reset ADC */
    adc_deinit(ADC0);
    /* ADC contineous function enable */
    adc_special_function_config(ADC0, ADC_CONTINUOUS_MODE, ENABLE);
    /* ADC scan mode disable */
    adc_special_function_config(ADC0, ADC_SCAN_MODE, DISABLE);
    adc_channel_length_config(ADC0, ADC_REGULAR_CHANNEL, 1);
    adc_regular_channel_config(ADC0, 0, BOARD_ADC_CHANNEL, ADC_SAMPLETIME_55POINT5);
    adc_enable(ADC0);
    delay_1ms(1);
    /* ADC software trigger enable */
    adc_software_trigger_enable(ADC0, ADC_REGULAR_CHANNEL);
    \param[in]  none
    \param[out] none
    \retval     none
    return ch;
xiaobai032|  楼主 | 2019-2-14 22:05 | 显示全部楼层
    \file  main.c
    \brief ADC0 channel of temperature and Vref
OF SUCH DAMAGE.
#include <stdio.h>
#include "main.h"
float temperature;
float vref_value;
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    /* configure systick */
    systick_config();
    rcu_config();
    adc_config();
    while(1){
        adc_software_trigger_enable(ADC0, ADC_INSERTED_CHANNEL);
        /* delay a time in milliseconds */
        delay_1ms(2000);
        /* value convert */
        temperature = (1.43 - ADC_IDATA0(ADC0)*3.3/4096) * 1000 / 4.3 + 25;
        vref_value = (ADC_IDATA1(ADC0) * 3.3 / 4096);
        /* value print */
        printf(" the temperature data is %2.0f degrees Celsius\r\n", temperature);
        printf(" the reference voltage data is %5.3fV \r\n", vref_value);
        printf(" \r\n");
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    /* reset ADC */
    adc_deinit(ADC0);
    /* ADC scan function enable */
    /* ADC temperature and Vrefint enable */
    adc_tempsensor_vrefint_enable();
    adc_channel_length_config(ADC0, ADC_INSERTED_CHANNEL, 2);
    /* ADC temperature sensor channel config */
    adc_inserted_channel_config(ADC0, 0, ADC_CHANNEL_16, ADC_SAMPLETIME_239POINT5);
    /* ADC internal reference voltage channel config */
    adc_inserted_channel_config(ADC0, 1, ADC_CHANNEL_17, ADC_SAMPLETIME_239POINT5);
    adc_external_trigger_source_config(ADC0, ADC_INSERTED_CHANNEL, ADC0_1_EXTTRIG_INSERTED_NONE);
    adc_enable(ADC0);
    delay_1ms(1);
    usart_data_transmit(EVAL_COM1, (uint8_t) ch);
    while (RESET == usart_flag_get(EVAL_COM1,USART_FLAG_TBE));
    return ch;
    \file  main.c
    \brief TIMER1 trigger injected channel of ADC0
OF SUCH DAMAGE.
#include <stdio.h>
#include "main.h"
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_config();
    systick_config();
    gpio_config();
    nvic_config();
    timer_config();
    adc_config();
    /* enable TIMER1 */
    while(1){
        delay_1ms(1000);
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    timer_channel_output_config(TIMER1, TIMER_CH_0, &timer_ocintpara);
    timer_channel_output_pulse_value_config(TIMER1, TIMER_CH_0, 3999);
    timer_channel_output_mode_config(TIMER1, TIMER_CH_0, TIMER_OC_MODE_PWM1);
    timer_channel_output_shadow_config(TIMER1, TIMER_CH_0, TIMER_OC_SHADOW_DISABLE);
    \param[in]  none
    \param[out] none
    \retval     none
    /* reset ADC */
    adc_deinit(ADC0);
    adc_external_trigger_source_config(ADC0, ADC_INSERTED_CHANNEL, ADC0_1_EXTTRIG_INSERTED_T1_CH0);
    adc_enable(ADC0);
    delay_1ms(1);
    \param[in]  none
    \param[out] none
    \retval     none
    return ch;
xiaobai032|  楼主 | 2019-2-14 22:06 | 显示全部楼层
    \file  main.c
    \brief ADC analog watchdog
OF SUCH DAMAGE.
#include <stdio.h>
#include "main.h"
uint16_t adc_value;
int data;
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_config();
    systick_config();
    gpio_config();
    nvic_config();
    adc_config();
    while(1){
        delay_1ms(1000);
        adc_value = adc_regular_data_read(ADC1);
        printf("\r\n ADC1 watchdog low threshold: 0x0400 \r\n");
        printf("\r\n ADC1 watchdog hgih threshold: 0x0A00 \r\n");
        printf("\r\n ADC1 regular channel data = %04X \r\n",adc_value);
        if(1 == data){
            /* turn off LED2 */
            data = 0;
            delay_1ms(3000);
            gd_eval_led_off(LED2);
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    /* configure led GPIO */
    gd_eval_led_init(LED2);
    \brief      configure interrupt priority
    \param[in]  none
    \param[out] none
    \retval     none
    nvic_priority_group_set(NVIC_PRIGROUP_PRE2_SUB2);
    nvic_irq_enable(ADC0_1_IRQn, 0, 0);
    \param[in]  none
    \param[out] none
    \retval     none
    /* reset ADC */
    adc_deinit(ADC1);
    adc_special_function_config(ADC1, ADC_CONTINUOUS_MODE, ENABLE);
    adc_channel_length_config(ADC1, ADC_REGULAR_CHANNEL, 1);
    adc_regular_channel_config(ADC1, 0, BOARD_ADC_CHANNEL, ADC_SAMPLETIME_55POINT5);
    /* ADC analog watchdog threshold config */
    adc_watchdog_threshold_config(ADC1, 0x0400, 0x0A00);
    /* ADC analog watchdog single channel config */
    adc_watchdog_single_channel_enable(ADC1, BOARD_ADC_CHANNEL);
    /* ADC interrupt config */
    adc_interrupt_enable(ADC1, ADC_INT_WDE);
    adc_enable(ADC1);
    delay_1ms(1);
    adc_software_trigger_enable(ADC1, ADC_REGULAR_CHANNEL);
    return ch;
xiaobai032|  楼主 | 2019-2-14 22:07 | 显示全部楼层
    \file  main.c
    \brief ADC1 oversample shift
OF SUCH DAMAGE.
#include <stdio.h>
#include "main.h"
uint16_t adc_value = 0;
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_config();
    systick_config();
    gpio_config();
    nvic_config();
    adc_config();
    /* configures COM port */
    while(1){
        /* wait end of group conversion */
        adc_flag_clear(ADC1, ADC_FLAG_EOC);
        while(SET != adc_flag_get(ADC1, ADC_FLAG_EOC)){
        /* printf the data of regular channel */
        adc_value = ADC_RDATA(ADC1);
        printf("16 times sample, 4 bits shift: 0x%x\r\n", adc_value);
        delay_1ms(500);
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    /* reset ADC */
    adc_deinit(ADC1);
    /* 16 times sample, 4 bits shift */
    adc_oversample_mode_config(ADC1, ADC_OVERSAMPLING_ALL_CONVERT, ADC_OVERSAMPLING_SHIFT_4B, ADC_OVERSAMPLING_RATIO_MUL16);
    adc_oversample_mode_enable(ADC1);
    adc_enable(ADC1);
    delay_1ms(1);
    return ch;
xiaobai032|  楼主 | 2019-2-14 22:08 | 显示全部楼层
    \file  main.c
OF SUCH DAMAGE.
#include <stdio.h>
#include "main.h"
uint16_t adc_value;
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_config();
    systick_config();
    gpio_config();
    nvic_config();
    adc_config();
    /* enable ADC regular channel group software trigger */
    while(1){
        printf("6B: 0x%x\r\n", adc_value);
        delay_1ms(500);
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    /* reset ADC */
    adc_deinit(ADC1);
    /* ADC resolusion 6B */
    adc_enable(ADC1);
    delay_1ms(1);
    return ch;
xiaobai032|  楼主 | 2019-2-14 22:10 | 显示全部楼层
几乎所有使用到的AD模式都包含了,再次感谢兆易创新的技术支持。希望兆易创新越来越强,国产芯片可以发扬光大。
lvben5d| | 2019-2-15 07:58 | 显示全部楼层
楼主笑死我了,你这个 中文的翻译哪弄的, 我的E103系列和之前V3.0.0版本都是英文啊。   为了刷分 "丧心病狂"  把例程的代码都贴上来了啊。 dma_interrupt_enable(DMA0, DMA_CH0, DMA_INT_FTF);   这个DMA中断要开启,才会进入DMA ADC0 连续转换模式结束中断。
YDCMAN| | 2019-2-16 20:26 | 显示全部楼层
lvben5d 发表于 2019-2-15 07:58
楼主笑死我了,你这个 中文的翻译哪弄的, 我的E103系列和之前V3.0.0版本都是英文啊。   为了刷分 "丧心病 ...
兆易的MCU怎么样?和ST的比有什么区别?
lvben5d| | 2019-2-16 20:34 | 显示全部楼层
反正我做了2个产品都在使用中。F103RCT6    F105RET6   没听说E20X系列 死机无法复位问题等。 只能说运行良好,没发现任何BUG。
xyz549040622| | 2019-2-17 19:39 | 显示全部楼层
支持下,谢谢分享!反正我没用过!
firstblood| | 2019-2-17 21:50 | 显示全部楼层
adc数据采样程序还是蛮有难度的,这个在一般的设计方案中也是必不可少的
firstblood| | 2019-2-17 21:51 | 显示全部楼层
这上面分享的非常详细的,程序设计的特别清楚的,感谢
comeon201208| | 2019-2-17 23:31 | 显示全部楼层
这个ad采样程序的设计分享非常全面的
tongbu2015| | 2019-2-27 23:43 | 显示全部楼层
这个分享的程序是非常不错的
zhangbo1985| | 2019-2-28 14:00 | 显示全部楼层
这程序分享的还不错的,,ad的数据采集的方式有两种的——中断与查询
