空标志还是0
237|3
pangb|  楼主 | 2019-2-15 13:28 | 显示全部楼层 |阅读模式
AUTOOUT=1下,PC发来数据到OUT端,为什么空标志还是0?
void TD_Init(void)             // Called once at startup
    // set the CPU clock to 48MHz
    CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1);  //48M
    IFCONFIG |= 0x0B;//异步,从FIFO模式.
    PORTACFG|=0X40;
    FIFOPINPOLAR = 0x00; // set all slave FIFO interface pins as active low PKTEND OR SLOE SLWR LOW AVTIVE
    SYNCDELAY;
    REVCTL = 0x03;    // enable the external master
   SYNCDELAY;
    //reset the fifos
   FIFORESET = 0x80;
   SYNCDELAY;
   FIFORESET = 0x02;
   SYNCDELAY;
   FIFORESET = 0x04;
   SYNCDELAY;
   FIFORESET = 0x06;
   SYNCDELAY;
   FIFORESET = 0x08;
   SYNCDELAY;
   FIFORESET = 0x00;
   SYNCDELAY;
   //fix the slave fifo flags, only flagb and flagc
   //PINFLAGSAB = 0x89;  //F,FLAGB IS THE FIFO2 EMPTY FLAG,LAGA IS THE FIFO4 EMPTY FLAG
   //SYNCDELAY;
   PINFLAGSAB = 0xE8;  //FLAGC IS THE FIFO6 FULL  FLAG
   SYNCDELAY;
   // config the endpoints direction
   EP1OUTCFG = 0xA0;//enable and bulk type
  EP1INCFG = 0xA0;
   SYNCDELAY;                    // see TRM section 15.14
   EP8CFG = 0x60;
   SYNCDELAY;
   EP4CFG = 0x20;
  SYNCDELAY;
   EP6CFG = 0xe2;//enable IN bulk 512 DOUBLE buffer
   SYNCDELAY;
EP2CFG = 0xA2;
   SYNCDELAY;
   INPKTEND = 0x06;
   SYNCDELAY;
   INPKTEND = 0x06;
   SYNCDELAY;
   OUTPKTEND = 0x82;
   SYNCDELAY;
   OUTPKTEND = 0x82;
   SYNCDELAY;
     EP2BCL = 0x80;                // arm EP2OUT by writing byte count w/skip.
   SYNCDELAY;
   EP2BCL = 0x80;
   SYNCDELAY;
   EP2FIFOCFG = 0x11;//EP2 IS AUTOOUT=1 AUTOIN =0 ZEROLEN=0 WORDIDE=1 配置EP6自动方式16位总
   SYNCDELAY;
   //config the endpoint6
   EP6FIFOCFG = 0x0D;//EP6 IS AUTOOUT=0 AUTOIN =1 ZEROLEN=1 WORDIDE=1 配置EP6自动方式16位总
   SYNCDELAY;
   EP6AUTOINLENH = 0x02;   //set the packet size 512
   SYNCDELAY;
   EP6AUTOINLENL = 0x00;
   SYNCDELAY;
// SYNCDELAY;
   // since the defaults are double buffered we must write dummy byte counts twice
   //SYNCDELAY;
  /*EP2BCL = 0x80;                // arm EP8OUT by writing byte count w/skip.
   SYNCDELAY;
   EP2BCL = 0x80;   */
   SYNCDELAY;
  Rwuen = TRUE;
chenjunt| | 2019-2-15 13:30 | 显示全部楼层
不懂,帮顶
ousj| | 2019-2-15 13:35 | 显示全部楼层
没看明白意思……
pangb|  楼主 | 2019-2-15 13:39 | 显示全部楼层
明天再说吧,唉
