[DemoCode下载]
读取芯片的PDID
1347|10
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 9 $
* $Date: 15/07/02 11:18a $
* @brief
*           Demonstrate how to change system clock to different PLL frequency and output system clock from CLKO pin.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC123.h"
#define HCLK_CLOCK       72000000
#define SIGNATURE       0x125ab234
#define FLAG_ADDR       0x20000FFC
/* Define functions prototype        */
int32_t main(void);
/*  Brown Out Detector IRQ Handler        */
void BOD_IRQHandler(void)
    /* Clear BOD Interrupt Flag */
    SYS_CLEAR_BOD_INT_FLAG();
    printf("Brown Out is Detected\n");
/*  Simple calculation test function        */
#define PI_NUM  256
int32_t f[PI_NUM + 1];
uint32_t piTbl[19] =
    3141,
    5926,
    5358,
    9793,
    2384,
    6264,
    3383,
    2795,
    288,
    4197,
    1693,
    9937,
    5105,
    8209,
    7494,
    4592,
    3078,
    1640,
    6284
int32_t piResult[19];
int32_t pi(void)
    int32_t i, i32Err;
    int32_t a = 10000, b = 0, c = PI_NUM, d = 0, e = 0, g = 0;
    for(; b - c;)
        f[b++] = a / 5;
    i = 0;
    for(; d = 0, g = c * 2; c -= 14,/*printf("%.4d\n",e+d/a),*/ piResult[i++] = e + d / a, e = d % a)
        if(i == 19)
            break;
        for(b = c; d += f[b] * a, f[b] = d % --g, d /= g--, --b; d *= b);
    i32Err = 0;
    for(i = 0; i < 19; i++)
        if(piTbl[i] != piResult[i])
            i32Err = -1;
    return i32Err;
void Delay(uint32_t x)
    int32_t i;
    for(i = 0; i < x; i++)
        __NOP();
        __NOP();
uint32_t g_au32PllSetting[] =
    CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(25) | CLK_PLLCON_NO_4,  /* PLL = 25MHz */
    CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(29) | CLK_PLLCON_NO_4,  /* PLL = 29MHz */
    CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(33) | CLK_PLLCON_NO_4,  /* PLL = 33MHz */
    CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(37) | CLK_PLLCON_NO_4,  /* PLL = 37MHz */
    CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(41) | CLK_PLLCON_NO_4,  /* PLL = 41MHz */
    CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(45) | CLK_PLLCON_NO_4,  /* PLL = 45MHz */
    CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(49) | CLK_PLLCON_NO_4   /* PLL = 49MHz */
void SYS_PLL_Test(void)
    int32_t  i;
    /* PLL clock configuration test        */
    printf("\n-------------------------[ Test PLL ]-----------------------------\n");
    for(i = 0; i < sizeof(g_au32PllSetting) / sizeof(g_au32PllSetting[0]) ; i++)
        /* Switch HCLK clock source to HXT and HCLK source divide 1 */
        CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
        /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware. */
        CLK_DisablePLL();
        /* Set PLL frequency */
        CLK->PLLCON = g_au32PllSetting[i];
        /* Waiting for PLL clock ready */
        CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk);
        /* Switch HCLK clock source to PLL */
        CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(1));
        printf("  Change system clock to %d Hz ...................... ", SystemCoreClock);
        /* Output selected clock to CKO, CKO Clock = HCLK / 2^(1 + 1) */
        CLK_EnableCKO(CLK_CLKSEL2_FRQDIV_S_HCLK, 1, 0);
        /* The delay loop is used to check if the CPU speed is increasing */
        Delay(0x400000);
        if(pi())
            printf("[FAIL]\n");
        else
            printf("[OK]\n");
        /* Disable CKO clock */
        CLK_DisableCKO();
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable XT1_OUT(PF0) and XT1_IN(PF1) */
    SYS->GPF_MFP |= SYS_GPF_MFP_PF0_XT1_OUT | SYS_GPF_MFP_PF1_XT1_IN;
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as HCLK_CLOCK */
    CLK_SetCoreClock(HCLK_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set GPB multi-function pins for UART0 RXD(PB.0) and TXD(PB.1) */
    SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk);
    SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD);
    /* Set GPC multi-function pin for Clock Output(PC.13) */
    SYS->GPC_MFP &= ~SYS_GPC_MFP_PC13_Msk;
    SYS->ALT_MFP &= ~SYS_ALT_MFP_PC13_Msk;
    SYS->GPC_MFP |= SYS_GPC_MFP_PC13_CLKO;
    SYS->ALT_MFP |= SYS_ALT_MFP_PC13_CLKO;
void UART0_Init()
    /* Init UART        */
    /* Reset UART0 module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* MAIN function        */
int32_t main(void)
    uint32_t u32data;
    /* In end of main function, program issued CPU reset and write-protection will be disabled. */
    if(SYS_IsRegLocked() == 0)
        SYS_LockReg();
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
        This sample code will show some function about system manager controller and clock controller:
        1. Read PDID
        2. Get and clear reset source
        3. Setting about BOD
        4. Change system clock depended on different PLL settings
        5. Output system clock from CKO pin, and the output frequency = system clock / 4
    printf("+----------------------------------------+\n");
    printf("|    NUC123 System Driver Sample Code    |\n");
    if(M32(FLAG_ADDR) == SIGNATURE)
        printf("  CPU Reset success!\n");
        M32(FLAG_ADDR) = 0;
        printf("  Press any key to continue ...\n");
        getchar();
    /* Misc system function test        */
    /* Read Part Device ID */
    printf("Product ID 0x%x\n", SYS_ReadPDID());
    /* Get reset source from last operation */
    u32data = SYS_GetResetSrc();
    printf("Reset Source 0x%x\n", u32data);
    /* Clear reset source */
    SYS_ClearResetSrc(u32data);
    /* Unlock protected registers for Brown-Out Detector settings */
    SYS_UnlockReg();
    /* Check if the write-protected registers are unlocked before BOD setting and CPU Reset */
        printf("Protected Address is Unlocked\n");
    /* Enable Brown-Out Detector, and set Brown-Out Detector voltage 2.7V */
    SYS_EnableBOD(SYS_BODCR_BOD_INTERRUPT_EN, SYS_BODCR_BOD_VL_2_7V);
    /* Enable BOD IRQ */
    NVIC_EnableIRQ(BOD_IRQn);
    /* Enable Low Voltage Reset function */
    SYS_ENABLE_LVR();
    /* Run PLL Test */
    SYS_PLL_Test();
    /* Write a signature work to SRAM to check if it is reset by software */
    M32(FLAG_ADDR) = SIGNATURE;
    printf("\n\n  >>> Reset CPU <<<\n");
    /* Waiting for message send out */
    UART_WAIT_TX_EMPTY(UART0);
    /* Switch HCLK clock source to Internal RC 22.1184MHz clock and HCLK source divide 1 */
    /* Set PLL to Power down mode and HW will also clear PLL_STB bit in CLKSTATUS register */
    CLK_DisablePLL();
    /* Reset CPU */
    SYS_ResetCPU();
gejigeji521|  楼主 | 2019-2-26 21:16 | 只看该作者
gejigeji521|  楼主 | 2019-2-26 21:17 | 只看该作者
第一个图是123的,下面这个是122的,我们发现PDID是不同的,这就可以帮我们分辨是哪个芯片了。
zhuotuzi| | 2019-2-26 23:32 | 只看该作者
好像是这个方法
huangcunxiake| | 2019-2-27 10:10 | 只看该作者
下次试试看,是每个芯片一个号,还是每个型号一个号。
yiy| | 2019-2-27 13:32 | 只看该作者
产品编码,区分芯片版本的。
识别你这个器件
dongliushui| | 2019-2-27 19:36 | 只看该作者
我记得有好几个ID呢。分别代表不同的东西,如果需要唯一性识别肯定要都了解了解。
zhuotuzi| | 2019-2-28 19:18 | 只看该作者
这些识别码用处很大
xuanhuanzi| | 2019-3-2 18:44 | 只看该作者
sys.h里实现了很多硬件相关的系统操作,方便用户使用。
