[S3C2440]
mini2440下载linux到yaffs2-image失败
643|2
IoTCatcher|  楼主 | 2019-2-27 20:17 | 显示全部楼层 |阅读模式
     各位好, 我使用Minitools下载linux文件到mini2440时, 烧写日志如下:
我尝试了低格flash, 但是还是会报Skip block 0x1db,Skip block 0x298,
然后提示"Installing yaffs2-image failed", 请问是什么原因?
Superboot-2440 V1.1(20130529) by FriendlyARM
Try to find SD card...... not found.
Hello USB Loop
USB Mode: Connected
NAND Low-level formating...
NAND Low-level formatted.
Installing bootloader...
Installing bootloader  succeed
Installing kernel...
Installing kernel succeed
Updating Linux Command Line...
Linux Command Line Saved
Installing yaffs2-image...
Skip block 0x1db
Skip block 0x298
Warning: Last Data not read out
这个是我的minitools的配置
IoTCatcher|  楼主 | 2019-2-27 20:27 | 显示全部楼层
linux_启动日志.rar (5.42 KB)
maplelove| | 2019-3-8 14:50 | 显示全部楼层
可以交流一下么,,加我VX  10290046
