[STM8]
stm8 开发例程 一些基础外设-------------PWM
1060|13
chenqiang10|  楼主 | 2019-2-28 20:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* 函数名:PWM_Init
* 描述  :PWM初始化
* 输入  :无
* 输出  :无
* 返回  :无
* 调用  :外部调用
void PWM_Init(void)
    TIM2_PSCR =0x04;
    /* Set the Autoreload value */
    TIM2_ARRH = (uint8_t)(ARR >> 8);
    TIM2_ARRL = (uint8_t)(ARR);
    /*TIM2 Frequency=16M/16/(499+1)=2K*/
    /* PWM1 Mode configuration: Channel1
    TIM2 Channel1 duty cycle = [TIM2_CCR1/(TIM2_ARR + 1)] * 100 = 50%*/
  #if TIM2_Channel==TIM2_Channel1
    /*TIM2 Frequency = TIM2 counter clock/(ARR + 1) */
    TIM2_OC1Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,250, TIM2_OCPOLARITY_HIGH);
  #elif TIM2_Channel==TIM2_Channel2
    TIM2_OC2Init(TIM2_OCMODE_PWM2, TIM2_OUTPUTSTATE_ENABLE,500, TIM2_OCPOLARITY_HIGH);
  #elif TIM2_Channel==TIM2_Channel3
    TIM2_OC3Init(TIM2_OCMODE_PWM1, TIM2_OUTPUTSTATE_ENABLE,250, TIM2_OCPOLARITY_HIGH);
  #endif
  TIM2_CR1 |= (uint8_t)MASK_TIM2_CR1_CEN;
chenqiang10|  楼主 | 2019-2-28 20:36 | 只看该作者
* 函数名:TIM2_OC1Init
* 描述  :TIM2 第一通道PWM初始化
* 输入  :TIM2_OCMode   常用参数TIM2_OCMODE_PWM1:0x60 ,TIM2_OCMODE_PWM2:0x70
           TIM2_OutputState  TIM2_OUTPUTSTATE_ENABLE:0x11
           TIM2_Pulse     占空比
           TIM2_OCPolarity  TIM2_OCPOLARITY_HIGH:0x00 ,TIM2_OCPOLARITY_LOW:0x22
* 输出  :无
* 返回  :无
* 调用  :外部调用
void TIM2_OC1Init(uint8_t TIM2_OCMode,uint8_t TIM2_OutputState,uint16_t TIM2_Pulse,uint8_t TIM2_OCPolarity )
      /* Disable the Channel 1: Reset the CCE Bit, Set the Output State , the Output Polarity */
    TIM2_CCER1 &= (uint8_t)(~( MASK_TIM2_CCER1_CC1E | MASK_TIM2_CCER1_CC1P));
    /* Set the Output State &  Set the Output Polarity  */
    TIM2_CCER1 |= (uint8_t)((uint8_t)(TIM2_OutputState & MASK_TIM2_CCER1_CC1E ) |
                             (uint8_t)(TIM2_OCPolarity & MASK_TIM2_CCER1_CC1P));
    /* Reset the Output Compare Bits  & Set the Ouput Compare Mode */
    TIM2_CCMR1 = (uint8_t)((uint8_t)(TIM2_CCMR1 & (uint8_t)(~(uint8_t)MASK_TIM2_CCMR1_OC1M)) |
                            (uint8_t)TIM2_OCMode);
    /* Set the Pulse value */
    TIM2_CCR1H = (uint8_t)(TIM2_Pulse >> 8);
    TIM2_CCR1L = (uint8_t)(TIM2_Pulse);
    TIM2_CCMR1 |= (uint8_t)MASK_TIM2_CCMR1_OC1PE;
chenqiang10|  楼主 | 2019-2-28 20:37 | 只看该作者
* 函数名:TIM2_OC2Init
* 描述  :TIM2 第二通道PWM初始化
           TIM2_Pulse     占空比
* 输出  :无
* 返回  :无
* 调用  :外部调用
void TIM2_OC2Init(uint8_t TIM2_OCMode,uint8_t TIM2_OutputState,uint16_t TIM2_Pulse,uint8_t TIM2_OCPolarity )
    TIM2_CCER1 &= (uint8_t)(~(MASK_TIM2_CCER1_CC2E | MASK_TIM2_CCER1_CC2P));
    TIM2_CCER1 |= (uint8_t)((uint8_t)(TIM2_OutputState & MASK_TIM2_CCER1_CC2E ) |
                             (uint8_t)(TIM2_OCPolarity & MASK_TIM2_CCER1_CC2P));
    TIM2_CCMR2 = (uint8_t)((uint8_t)(TIM2_CCMR1 & (uint8_t)(~(uint8_t)MASK_TIM2_CCMR2_OC2M )) |
    TIM2_CCR2H = (uint8_t)(TIM2_Pulse >> 8);
    TIM2_CCR2L = (uint8_t)(TIM2_Pulse);
    TIM2_CCMR2 |= (uint8_t)MASK_TIM2_CCMR2_OC2PE;
chenqiang10|  楼主 | 2019-2-28 22:10 | 只看该作者
* 函数名:TIM2_OC3Init
* 描述  :TIM2 第三通道PWM初始化
           TIM2_Pulse     占空比
* 输出  :无
* 返回  :无
* 调用  :外部调用
void TIM2_OC3Init(uint8_t TIM2_OCMode,uint8_t TIM2_OutputState,uint16_t TIM2_Pulse,uint8_t TIM2_OCPolarity )
    TIM2_CCER2 &= (uint8_t)(~( MASK_TIM2_CCER2_CC3E | MASK_TIM2_CCER2_CC3P));
    TIM2_CCER2 |= (uint8_t)((uint8_t)(TIM2_OutputState & MASK_TIM2_CCER2_CC3E ) |
                             (uint8_t)(TIM2_OCPolarity & MASK_TIM2_CCER2_CC3P));
    TIM2_CCMR3 = (uint8_t)((uint8_t)(TIM2_CCMR1 & (uint8_t)(~(uint8_t)MASK_TIM2_CCMR3_OC3M )) |
    TIM2_CCR3H = (uint8_t)(TIM2_Pulse >> 8);
    TIM2_CCR3L = (uint8_t)(TIM2_Pulse);
    TIM2_CCMR3 |= (uint8_t)MASK_TIM2_CCMR3_OC3PE;
void SetTIM2_PWM_Frequency(uint16_t TIM2_Period)
    TIM2_ARRH = (uint8_t)(TIM2_Period >> 8);
    TIM2_ARRL = (uint8_t)(TIM2_Period);
chenqiang10|  楼主 | 2019-2-28 22:13 | 只看该作者
void SetTIM2_PWM_DutyCycle( uint16_t TIM2_Pulse)
  #endif
guanjiaer| | 2019-3-11 13:11 | 只看该作者
控制电机的无上利器啊
heimaojingzhang| | 2019-3-11 13:41 | 只看该作者
非常感谢楼主分享
keaibukelian| | 2019-3-11 14:16 | 只看该作者
非常感谢楼主分享
chenqiang10|  楼主 | 2019-3-16 21:33 | 只看该作者
不客气,好东西大家分享啊
chenqiang10|  楼主 | 2019-3-16 21:34 | 只看该作者
一起学习,开发stm8s
guanjiaer 发表于 2019-3-11 13:11
控制电机的无上利器啊
是啊,电机转速还是不太好控制的。
guanjiaer| | 2019-4-1 11:45 | 只看该作者
chenqiang10 发表于 2019-3-16 21:34
是啊,电机转速还是不太好控制的。
不是不太好  是很不好啊
keaibukelian| | 2019-4-1 12:03 | 只看该作者
一起学习,开发stm8s
是呢 一起学习
