525|0
xiaoxianwen|  楼主 | 2019-3-15 14:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
High-performance Low RDSON nFET & pFET MOSFETs
• From as low as 4 mΩ • Internal Protection Features:
• Built-in Supply Undervoltage Lockout Protection
• Fixed and Capacitor/Resistor-adjustable Inrush Current Control
• Fixed and Resistor-adjustable Current Limit Protection
• Built-in Short-circuit Current Protection
• Built-in Thermal Shutdown Protection with Auto Restart
• Reverse-current Blocking using Bulk Switch or Back-to-Back FETs
• Reverse-voltage Detection (selected part numbers)
• Fast VOUT Discharge (VOUT Discharge delete options available)
• Active HIGH ON-OFF Control (Active-LOW ON-OFF control available)
• Open-drain  Signaling (selected part numbers)
• Open-drain Power Good Signaling (selected part numbers)
• Wafer-level Chip-scale Packaging (selected part numbers)
• UL2367 Certified (selected part numbers)
dialog_greenfet3_part_selector_guide_q2_2018.pdf
687.92 KB
dialog_hfet1_part_selector_guide_q2_2018.pdf
404.86 KB
