[STM32L4+]
stm32l432kc+sn65hvd230,接收不到东西,帮忙看看问题在哪?
833|5
230的rs端接100k电阻到地
发送端:
/* CAN1 init function */
static void MX_CAN1_Init(void)
        CAN_FilterConfTypeDef  sFilterConfig;
  static CanTxMsgTypeDef        TxMessage;
  static CanRxMsgTypeDef        RxMessage;
  hcan1.Instance = CAN1;
        hcan1.pTxMsg = &TxMessage;
  hcan1.pRxMsg = &RxMessage;
  hcan1.Init.Prescaler = 8;
  hcan1.Init.Mode = CAN_MODE_NORMAL;
  hcan1.Init.SJW = CAN_SJW_1TQ;
  hcan1.Init.BS1 = CAN_BS1_6TQ;
  hcan1.Init.BS2 = CAN_BS2_3TQ;
  hcan1.Init.TTCM = DISABLE;
  hcan1.Init.ABOM = DISABLE;
  hcan1.Init.AWUM = DISABLE;
  hcan1.Init.NART = DISABLE;
  hcan1.Init.RFLM = DISABLE;
  hcan1.Init.TXFP = DISABLE;
  if (HAL_CAN_Init(&hcan1) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
          /*##-2- Configure the CAN Filter ###########################################*/
  sFilterConfig.FilterNumber = 0;
  sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK;
  sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT;
  sFilterConfig.FilterIdHigh = 0x0000;
  sFilterConfig.FilterIdLow = 0x0000;
  sFilterConfig.FilterMaskIdHigh = 0x0000;
  sFilterConfig.FilterMaskIdLow = 0x0000;
  sFilterConfig.FilterFIFOAssignment = 0;
  sFilterConfig.FilterActivation = ENABLE;
  sFilterConfig.BankNumber = 14;
  if (HAL_CAN_ConfigFilter(&hcan1, &sFilterConfig) != HAL_OK)
    /* Filter configuration Error */
    Error_Handler();
  /*##-3- Configure Transmission process #####################################*/
  hcan1.pTxMsg->StdId = 0x321;
  hcan1.pTxMsg->ExtId = 0x01;
  hcan1.pTxMsg->RTR = CAN_RTR_DATA;
  hcan1.pTxMsg->IDE = CAN_ID_STD;
  hcan1.pTxMsg->DLC = 8;
在主函数的whil(1)里
        for(uint8_t ii = 0; ii < 8; ii++)
                hcan1.pTxMsg->Data[ii] = 0xAA;
        HAL_CAN_Transmit(&hcan1,10);
接收端
    Error_Handler();
主函数里
        __HAL_CAN_ENABLE_IT(&hcan1,CAN_IT_FF0);
        HAL_NVIC_EnableIRQ(CAN1_RX0_IRQn);
        if (HAL_CAN_Receive_IT(&hcan1, CAN_FIFO0) != HAL_OK)
    /* Reception Error */
    Error_Handler();
零三翟邢止胃| | 2019-3-19 10:44 | 只看该作者
大佬呢? 来一下啊!
pegion1001|  楼主 | 2019-3-20 10:20 | 只看该作者
调试了一天,感觉是230有问题,用示波器接在230的D,R上能看到信号,但在CANH和CANL上就没有信号了
pegion1001|  楼主 | 2019-3-20 10:29 | 只看该作者
230接法如图,漏了什么?
heimaojingzhang| | 2019-4-8 13:00 | 只看该作者
是不是不匹配 呀
keaibukelian| | 2019-4-8 13:04 | 只看该作者
能看到发送端发出数据了吗
