28335主程序错误
967|3
lzx18570633112|  楼主 | 2019-3-30 18:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "DSP2833x_Device.h"
#include "DSP2833x_Examples.h"
#include "DSP2833x_GlobalConst.h"
#include "DSP2833x_Globalpara.h"
#include ".\source\app\AdcProcess.c"
#include ".\source\app\Timer.c"
#include ".\source\app\MotorCtrl.c"
#include "485.c"
#include "ECana.c"
#include "dmctype.h"
#include "rmp_cntl.h"
//#include "AD.h"
//#include "DA.h"
#include "Resolver.h"
CLARKE clarkeu=CLARKE_DEFAULTS;
CLARKE clarkei=CLARKE_DEFAULTS;
PARK parku=PARK_DEFAULTS;
PARK parki=PARK_DEFAULTS;
PIDREG3 pid1_PLL =PIDREG3_DEFAULTS;
PIDREG3 pid1_Speed =PIDREG3_DEFAULTS;
PIDREG3 pid1_idloop=PIDREG3_DEFAULTS;
PIDREG3 pid1_iqloop=PIDREG3_DEFAULTS;
IPARK iparku=IPARK_DEFAULTS;
PIDREG3 pid1_vdc =PIDREG3_DEFAULTS;
SPEED_ESTIMATION speed1=SPEED_ESTIMATION_DEFAULTS;
RMPCNTL rc1=RMPCNTL_DEFAULTS;
//AD Adv=AD_DEFAULTS;
//DA DAv=DA_DEFAULTS;
RESOLVER resolver=RESOLVER_DEFAULTS;
interrupt void MainIsr();
interrupt void adc_isr();
//interrupt void CpuTimer0Isr(void);
//interrupt void CpuTimer1Isr(void);
//interrupt void ISRExint(void);
//interrupt void ECanaISR(void);
//void InitMboxa(void);
//void ClrStatup(void);
float32 Ualpha1=0,Ubeta1=0,Ref_theta=0;
float Freq1=0;
int kk;
float32 minus=0,oldElecTheta=0;
Uint16 ledcont=0;
Uint16 INT3Count=0;
float32 Cosine1,Sine1;
float theta1=0,vdc1flt=0;
Uint32 iqcount=0;
Uint32 ao1=0;
int key=0,key1count=0,key2count=0;
//int kji=0,kreset=0,nreset=0;
/**************************************************************采样中断*********************************************************************/
Uint16 LoopCount;
Uint16 ConversionCount;
Uint16 Current1[20]={0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
Uint16 CURRENT1 = 0;
Uint16 iLo = 0;
Uint16 ILO_REF = 41800;
Uint16 ILo = 0;
Uint16 ILo_ref = 0;
Uint16 ILo_error = 0;
Uint16 ILo_Inter = 0;
Uint16 ILo_out = 0;
Uint16 Uzaibo = 0;
Uint16 Uzaibo_out = 0;
Uint16 ILo_P = 0;
Uint16 ILo_I = 0;
/***************************************************************主函数*********************************************************************/
#pragma CODE_SECTION(main,"ramfuncs")
void main(void)
    DSP28x_usDelay(5000);
// Initialize System Control registers, PLL, WatchDog, Clocks to default state
// This function is found in the DSP280x_SysCtrl.c file
    InitSysCtrl();
        InitGpio();
        InitSci();
        DINT;
        IER = 0x0000;
        IFR = 0x0000;
        InitPieCtrl();
    InitPieVectTable();
        InitCpuTimers();
           InitAdc();
//    EALLOW;
//    SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
//    EDIS;
        InitEPwm();
//    EALLOW;
//    SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;
//    EDIS;
#if (CPU_FRQ_150MHZ)     // Default - 150 MHz SYSCLKOUT
  #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3)   = 25.0 MHz
#endif
#if (CPU_FRQ_100MHZ)
  #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2)   = 25.0 MHz
#endif
EDIS;
EALLOW;
SysCtrlRegs.HISPCP.all = ADC_MODCLK;        // HSPCLK = SYSCLKOUT/ADC_MODCLK
EDIS;
InitPieCtrl();
// Disable CPU interrupts and clear all CPU interrupt flags:
IER = 0x0000;
IFR = 0x0000;
InitPieVectTable();
EALLOW;  // This is needed to write to EALLOW protected register
PieVectTable.ADCINT = &adc_isr;
PieVectTable.EPWM1_INT = &MainIsr;
EDIS;    // This is needed to disable write to EALLOW protected registers
EALLOW;
EDIS;
InitAdc();  // For this example, init the ADC
InitEPwm();
EALLOW;
EDIS;
PieCtrlRegs.PIECTRL.bit.ENPIE = 1;
PieCtrlRegs.PIEIER1.bit.INTx6 = 1;
IER |=M_INT1;  //开放CPUTimer0/AD/ePWM
EINT;          // Enable Global interrupt INTM
ERTM;          // Enable Global realtime interrupt DBGM
PieCtrlRegs.PIEIER3.bit.INTx1 = 1;
IER |=M_INT3;  //开放CPUTimer0/AD/ePWM
EALLOW;
EPwm1Regs.ETSEL.bit.INTEN = 1;   // Enable EPWM1INT generation
EPwm1Regs.ETSEL.bit.INTSEL = 1;  // Enable interrupt CNT_zero event
EPwm1Regs.ETPS.bit.INTPRD = 1;   // Generate interrupt on the 1st event
EPwm1Regs.ETCLR.bit.INT = 1;     // Enable more interrupts
EDIS;
EALLOW;
// Configure ADC
AdcRegs.ADCTRL3.bit.SMODE_SEL= 0x0;         //同步采样模式
AdcRegs.ADCTRL1.bit.ACQ_PS   = 0xf;         //ADC采样时间选择
AdcRegs.ADCTRL3.bit.ADCCLKPS = OSCCLOCK;    //ADC内核分频
AdcRegs.ADCTRL1.bit.SEQ_CASC = 1;           //级联工作方式
AdcRegs.ADCMAXCONV.all = 0x0000;            // Setup 1 conv's on SEQ1
//AdcRegs.ADCTRL1.bit.CONT_RUN = 1;            //连续采样
AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x1;        //设置CONV0 为第一个通道
AdcRegs.ADCTRL2.bit.EPWM_SOCA_SEQ1 = 1;       //Enable SOCA from ePWM to start SEQ1
AdcRegs.ADCTRL2.bit.INT_ENA_SEQ1 = 1;         //Enable SEQ1 interrupt (every EOS)
//AdcRegs.ADCTRL1.bit.CONT_RUN = 1;           //连续运行模式
//AdcRegs.ADCTRL1.bit.SEQ_OVRD = 1;           //完成排序后,排序器指针回到最初状态
EDIS;
for(;;)
/**********************************************************EPWM中断程序*******************************************************************/
#pragma CODE_SECTION(MainIsr,"ramfuncs")
interrupt void MainIsr(void)
//        float32 vdcMaxPU;
//        float32 iMaxPU;
//        float   Kiu,Kiv;
    ILo = iLo;
    ILo_ref = ILO_REF;
    ILo_error = ILo_ref-ILo;
    ILo_Inter += ILo_error*ILo_I;
    if(ILo_Inter > 400)
     ILo_Inter = 400;
    else if(ILo_Inter < -400)
     ILo_Inter = -400;
    ILo_out = ILo_Inter+ILo_P*ILo_error;
    if(ILo_out > 500)
     ILo_out = 500;
    else if(ILo_out < -500)
     ILo_out = -500;
    Uzaibo = ILo_out/500.0;
//     Uzaibo_out = -Uzaibo*30000/2+30000/2;
    EPwm2Regs.TBPHS.half.TBPHS = 0.0*30000;//1.06*30000;
    EPwm3Regs.TBPHS.half.TBPHS = 1.0*30000;//1.1538*30000;
    EPwm4Regs.TBPHS.half.TBPHS = (1.1+0.5*Uzaibo)*30000;//0.1438*30000;
    EPwm5Regs.TBPHS.half.TBPHS = (0.1+0.5*Uzaibo)*30000;//0.1438*30000;
    EPwm2Regs.CMPA.half.CMPA = (0.4+Uzaibo)*30000;
    EPwm3Regs.CMPA.half.CMPA = (0.4+Uzaibo)*30000;
    EPwm4Regs.CMPA.half.CMPA = (0.4+Uzaibo)*30000;
    EPwm5Regs.CMPA.half.CMPA = (0.4+Uzaibo)*30000;
    //EPwm1Regs.CMPA.half.CMPA=30000/2;
    //EPwm2Regs.CMPA.half.CMPA=30000/2;
        EPwm1Regs.ETCLR.bit.INT =1;
        DINT;
        PieCtrlRegs.PIEACK.all = PIEACK_GROUP3; //响应本次接收中断;
    PieCtrlRegs.PIEIER1.bit.INTx7 = 1;        //开CPUTimer0中断
/********************************************************************采样中断*************************************************************/
#pragma CODE_SECTION(adc_isr,"ramfuncs")
interrupt void  adc_isr(void)
  Current1[ConversionCount] = AdcRegs.ADCRESULT0 >>4;
  CURRENT1 +=Current1[ConversionCount];
  // If 40 conversions have been logged, start over
  if(ConversionCount == 19)
         iLo = CURRENT1;
     ConversionCount = 0;
     CURRENT1= 0;
  else
          ConversionCount++;
  // Reinitialize for next ADC sequence
  AdcRegs.ADCTRL2.bit.RST_SEQ1 = 1;         // Reset SEQ1
  AdcRegs.ADCST.bit.INT_SEQ1_CLR = 1;       // Clear INT SEQ1 bit
  PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;   // Acknowledge interrupt to PIE
  return;
        Freq1=0;
        pid1_vdc.Out=0;
        pid1_vdc.Ref=0;
        pid1_vdc.Fdb=0;
        pid1_vdc.Ui=0;
        pid1_iqloop.Out=0;
        pid1_iqloop.Fdb=0;
        pid1_iqloop.Ref=0;
        pid1_iqloop.Ui=0;
        pid1_idloop.Out=0;
        pid1_idloop.Ref=0;
        pid1_idloop.Fdb=0;
        pid1_idloop.Ui=0;
        iparku.Ds=0;
        iparku.Qs=0;
请问:这个程序的两个中断都能进去,但是最终没有波形输出,这是为什么,错误在哪里?
零三翟邢止胃| | 2019-4-1 09:12 | 只看该作者
找大佬帮你看一下啊!!!!!
山大电气硕士| | 2019-4-2 10:00 | 只看该作者
PWM的寄存器设置有问题
airwill| | 2019-4-7 15:43 | 只看该作者
这样的问问题哪, 也不说你想干什么, 也没有硬件的基本介绍, 就上代码, 让人家帮你改代码吗?
你自己有工作板, 有仿真器. 比别人看代码容易找问题多了
