[技术问题解答]
MKE02使用bootloader Can't program block 0 at address 0x00001000
729|1
血洗无涯|  楼主 | 2019-4-10 11:18 | 显示全部楼层 |阅读模式
Waiting for HC(S)08 reset ACK (timeout: 10s)...rb returned 1 data:fc,
received 0xfc (good).
wb(fc,) returned 1
wb(49,) returned 1
rb returned 1 data:88,
rb returned 1 data:1,
rb returned 1 data:4a,
rb returned 4 data:0,0,0,1,
rb returned 4 data:0,0,10,0,
rb returned 4 data:0,0,80,0,
rb returned 4 data:0,0,0,0,
rb returned 4 data:0,0,2,0,
rb returned 4 data:0,0,0,40,
rb returned 1 data:4b,
rb returned 1 data:45,
rb returned 1 data:30,
rb returned 1 data:32,
rb returned 1 data:0,
Bootloader protocol version: 0x08 (Kinetis, read command supported)
CRC protocol NOT supported)
Bootloader version string: KE02
System device ID: 0x14A [Kinetis K60] rev. 0
Kinetis Package: 144-pin .
Number of memory blocks: 1
Memory block #1: 0x00001000-0x00008000
Erase block size: 512 bytes
Write block size:  64 bytes
Original vector table: 0x00000000-0x000003FF
New vector table: 0x00001000-0x000013FF
S19 Image Control.
Parsed S-record lines: 320  Bytes total: 5076
Source address range: 0x0400-0x2713
The S19 image also contains redirected vectors. The automatic redirection is skipped now.
WARNING! S19 image will not fit into available memory (at address 0x00000400)!
Memory programming block 0: W 0x00000400 0%
prg_blk: 0x00000400-0x0000040f
wb(57,) returned 1
wb(0,0,4,0,) returned 4
wb(10,) returned 1
wb(ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,fe,ff,) returned 16
rb returned 1 data:fc,Memory programming block 0: W 0x00001000 0%
prg_blk: 0x00001000-0x0000103f
wb(57,) returned 1
wb(0,0,10,0,) returned 4
wb(40,) returned 1
wb(f8,b,0,20,11,14,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,df,19,0,0,) returned 64
rb returned 1 data:3,
按照网友发的 先修改了bootloader里面跳转的地址  然后又设置app icf里面的地址  分别都能单独运行 ,可是升级出现这种问题 其他网友也出现这种情况  不过 帖子都没有给出解决方法
血洗无涯|  楼主 | 2019-4-10 11:44 | 显示全部楼层
可有偿解决,我找的最早出现的2015年的 但是帖子下面都没有明确的解决方法
