[资料分享]
AWR1443 单芯片 76GHz 至 81GHz 汽车雷达传感器评估模块
555|4
dirtwillfly|  楼主 | 2019-4-23 22:37 | 显示全部楼层 |阅读模式
描述
The AWR1443 BoosterPack™ plug-in module is an easy-to-use evaluation board for the single-chip AWR1443 mmWave sensing device, with direct connectivity to the TI MCU LaunchPad™ development-kit ecosystem.
AWR1443BOOST contains everything required to start developing on a low-power Arm® Cortex™-R4F processor. The evaluation board includes onboard emulation for programming and debugging, onboard buttons, and LEDs for quick integration of a simple-user interface.
The standard 20-pin BoosterPack headers make the evaluation board compatible with a wide variety of MCU LaunchPad development kits and enable easy prototyping.
特性
Onboard antenna enables field testing
XDS110-based JTAG with serial-port interface for flash programming
UART-to-USB interface for control, configuration, and data visualization
TI LaunchPad development-kit interface to seamlessly connect to TI MCUs
CAN connector enables direct interface to car units
包含项目
Micro USB cable (#3025010-03)
Mounting brackets with Bumpon™ (#36-625-ND, SJ61A1)
M3-size screws (#9027A146)
M3-size nuts (#90631A007 )
Jumpers (#SPC02SYAN)
dirtwillfly|  楼主 | 2019-4-23 22:38 | 显示全部楼层
AWR1443BOOST, AWR1243 Evaluation Module mmWave Sensing Solution.pdf (5.93 MB)
dirtwillfly|  楼主 | 2019-4-23 22:54 | 显示全部楼层
IR14x BoosterPack and DevPack Board Assembly Files.zip (1.36 MB)
operating| | 2019-4-24 15:14 | 显示全部楼层
感谢分享!下载学习下
programmable| | 2019-4-26 14:44 | 显示全部楼层
有没有中文的资料看啊
