/-----------------my_IR.c------------------------------------------------------------
#include "my_IR.h"
NEC协议红外遥控解码
计数使用资源:Timer0
由于设定Timer0定时值,计算出来的值不正确,
超时在Timer3中断里处理
#define REMOTE_ID 0x0
sbit IR_IO=P0^0;
bit bIR_scan=0;
bit bIR=0;
UINT8 IR_cont=0;
UINT8 IR_code=0; //遥控按键值
UINT16 Dval; //计数器的值
unsigned long RmtRec=0; //接收到的数据
uint16_t TIM0_GetCounter(void)
uint16_t tmpcntr = 0;
tmpcntr = ((uint16_t)TH0 << 8);
tmpcntr = tmpcntr| (uint16_t)(TL0);
return ((uint16_t)tmpcntr*0.75);
UINT8 IR_SCAN(void)
UINT8 i=0;
UINT8 t1,t2;
if(bIR_scan==0) return 0;
bIR_scan=0;
RmtRec=0;
if(IR_IO==0)
clr_TR0;
clr_TF0;
TL0 =0;
TH0 =0;
set_TR0; //Start Timer0
bIR=0;IR_cont=0;
while ((IR_IO==0)&&(bIR != 1)); //Check Timer0 Time-Out Flag
clr_TR0; //Stop Timer0
clr_TF0;
Dval=TIM0_GetCounter();
if(Dval>8600&&Dval<9300) //9ms
TL0 =0;
TH0 =0;
bIR=0;IR_cont=0;
while ((IR_IO==1)&&(bIR != 1)); //Check Timer0 Time-Out Flag
clr_TF0;
if(Dval>4200&&Dval<4700) //4.5ms
do{
TL0 =0;
TH0 =0;
bIR=0;IR_cont=0;
clr_TF0;
if(Dval<300&&Dval>800) //560us
return 0;
TL0 =0;
TH0 =0;
bIR=0;IR_cont=0;
clr_TF0;
if(Dval>300&&Dval<800) //560为标准值,560us
RmtRec<<=1;
RmtRec|=0; //接收到0
i++;
}else if(Dval>1400&&Dval<1800) //1680为标准值,1680us
RmtRec<<=1;
RmtRec|=1; //接收到1
i++;
else if(Dval>2200&&Dval<2600) //得到按键键值增加的信息 2500为标准值2.5ms
}while(i<32);
t1=RmtRec>>24; //得到地址码
t2=(RmtRec>>16)&0xff; //得到地址反码
if((t1==(UINT8)~t2)&&t1==REMOTE_ID)//检验遥控识别码(ID)及地址
t1=RmtRec>>8;
t2=RmtRec;
IR_code=t1;
if(t1==(UINT8)~t2)return 1;//键值正确
return 0;
void my_IR_Init(void)
P00_Input_Mode;
clr_T0M; //T0M=0, Timer0 Clock = Fsys/12
TMOD |= 0x01; //Timer0 is 16-bit mode
TL0 =LOBYTE(TIMER_DIV12_VALUE_40ms); //Find define in "Function_define.h" "TIMER VALUE"
TH0 =HIBYTE(TIMER_DIV12_VALUE_40ms);
//clr_TR0; //Stop Timer0
//-----------------my_IR.c------------------------------------------------------------
#ifndef __MY_IR_H
#define __MY_IR_H
#include "n76e003.h"
extern bit bIR_scan;
extern bit bIR;
extern UINT8 IR_cont;
extern UINT8 IR_code;
void my_IR_Init(void);
UINT8 IR_SCAN(void);
#endif /*__MY_IR_H*/
