[DemoCode下载]
M051用IO模拟UART
511|7
598330983|  楼主 | 2019-4-30 20:20 | 显示全部楼层 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 4 $
* $Date: 14/01/28 11:45a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    M051 Series Timer Driver Sample Code
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M051Series.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
unsigned int data;
unsigned int count;
unsigned int p_flag;
* @brief       Timer0 IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The Timer0 default IRQ, declared in startup_M051Series.s.
void TMR0_IRQHandler(void)
    /* Clear Timer0 time-out interrupt flag */
     TIMER_ClearIntFlag(TIMER0);
           if(count!=0)
                        if(data&0x01==0x01)
             P27=1;
                         else
                         P27=0;
                  data=data>>1;
                        count--;
void UART_GPIO(unsigned char uart_data)
        data=0;
        data=(uart_data<<1)|(1<<9);
        count=10;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable IRC22M clock */
    CLK->PWRCON |= CLK_PWRCON_IRC22M_EN_Msk;
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_IRC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_HIRC;
    /* Set PLL to Power-down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
    CLK->PLLCON |= CLK_PLLCON_PD_Msk;
    /* Enable external 12 MHz XTAL, IRC10K */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk | CLK_PWRCON_OSC10K_EN_Msk;
    /* Enable PLL and Set PLL frequency */
    CLK->PLLCON = PLLCON_SETTING;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk | CLK_CLKSTATUS_IRC10K_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK->CLKSEL0 = CLK_CLKSEL0_STCLK_S_HCLK_DIV2 | CLK_CLKSEL0_HCLK_S_PLL;
    /* Enable peripheral clock */
    CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk |
                  CLK_APBCLK_TMR0_EN_Msk ;
    /* Peripheral clock source */
    CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL |CLK_CLKSEL1_TMR0_S_HIRC;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD, TXD */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
           int i;
    volatile uint32_t u32InitCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* Configure P1.5 as Output mode*/
    GPIO_SetMode(P2, BIT7, GPIO_PMD_OUTPUT);
    /* Open Timer0 frequency 38400 in periodic mode, and enable interrupt */
    TIMER0->TCMPR = (22118400/38400);
    TIMER0->TCSR = TIMER_TCSR_IE_Msk | TIMER_PERIODIC_MODE;
    TIMER_SET_PRESCALE_VALUE(TIMER0, 0);
    /* Enable Timer0 NVIC */
    NVIC_EnableIRQ(TMR0_IRQn);
    /* Start Timer0 counting */
    TIMER_Start(TIMER0);
    while(1){
                        if(count==0)
                        CLK_SysTickDelay(1000);
                        UART_GPIO(i);
                        i++;
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
598330983|  楼主 | 2019-4-30 20:21 | 显示全部楼层
这个技能必须的会,不然到时候硬件的通信接口不够就要这么搞了。
heisexingqisi| | 2019-4-30 20:49 | 显示全部楼层
学习一下,其他系列模拟的方法也会
xuanhuanzi| | 2019-4-30 21:19 | 显示全部楼层
操作的这么六六
yiyigirl2014| | 2019-8-18 00:58 | 显示全部楼层
好像这个真是的。
捉虫天师| | 2019-8-18 12:15 | 显示全部楼层
这个方法挺好。
捉虫天师| | 2019-8-18 12:16 | 显示全部楼层
           if(count!=0)
                        if(data&0x01==0x01)
             P27=1;
                         else
                         P27=0;
                  data=data>>1;
                        count--;
        data=0;
        count=10;
通过一个函数实现将数据装在格式化后的一个数里面,然后通过定时器中断发送出去。
