[DemoCode下载]
M451的SPI Flash操作
339|1
xuanhuanzi|  楼主 | 2019-4-30 21:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 4 $
* $Date: 15/09/02 10:03a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to set GPIO pin mode and use pin data input/output control.
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
#include "stdio.h"
#include "M451Series.h"
#include "NuEdu-Basic01.h"
#define PLL_CLOCK       72000000
#define TEST_NUMBER                 10 /* page numbers */
unsigned char   SrcArray[256];
unsigned char DestArray[256];
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD(PD.6) and TXD(PD.1) */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
void UART0_Init()
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main(void)
    unsigned int u32ByteCount;
    unsigned int u32PageNumber;
    unsigned int u32ProgramFlashAddress = 0;
    unsigned int u32VerifyFlashAddress = 0;
    unsigned int MidDid;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("Hello World.\n");
    printf("PLL Clock = %d Hz\n", CLK_GetPLLClockFreq());
    printf("Core Clock = %d Hz\n\n", CLK_GetHCLKFreq());
    printf("+-------------------------------------------------------+\n");
    printf("|       M451 Series SPI_Flash Sample Code         |\n");
    /* Open 7-Seg */
    Open_Seven_Segment();
    /* Open SPI for Serial Flash */
    Open_SPI_Flash();
    /* Read MID & DID */
    MidDid = SpiFlash_ReadMidDid();
    printf("\nMID and DID = %x", MidDid);
    /* Erase SPI Flash */
    SpiFlash_ChipErase();
    printf("\nFlash Erasing... ");
    /* Wait ready */
    SpiFlash_WaitReady();
    printf("Done!");
    /* Fill the Source Data and clear Destination Data Buffer */
    for(u32ByteCount = 0; u32ByteCount < 256; u32ByteCount++)
        SrcArray[u32ByteCount] = u32ByteCount;
        DestArray[u32ByteCount] = 0;
    for(u32PageNumber = 0; u32PageNumber < TEST_NUMBER; u32PageNumber++)
        printf("\n\nTest Page Number = %d", u32PageNumber);
        Show_Seven_Segment(u32PageNumber, 1);
        CLK_SysTickDelay(200000);
        /*=== Program SPI Flash ===*/
        printf("\n Flash Programming... ");
        /* Page Program */
        SpiFlash_PageProgram(SrcArray, u32ProgramFlashAddress, 256);
        u32ProgramFlashAddress += 0x100;
        printf("Done!");
        /*=== Read Back and Compare Data ===*/
        printf("\n Flash Verifying... ");
        /* Page Read */
        SpiFlash_ReadData(DestArray, u32VerifyFlashAddress, 256);
        u32VerifyFlashAddress += 0x100;
            if(DestArray[u32ByteCount] != u32ByteCount)
                /* Error */
                printf("SPI Flash R/W Fail!");
                while(1);
        /* Clear Destination Data Buffer */
        printf("Done!");
    printf("\n\nSPI Flash Test Ok!");
    printf("\n\n");
    while(1);
xuanhuanzi|  楼主 | 2019-4-30 21:23 | 只看该作者
外挂SPI接口的闪存芯片,很好用。
