[DemoCode下载]
NuTinySDKM451自带的例子
261|3
yiyigirl2014|  楼主 | 2019-4-30 21:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V1.00
* $Date: 15/09/02 10:03a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Toggle PC.9 to turn on / off the board LED
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#define HCLK_CLOCK       72000000
void SYS_Init(void)
    /* Init System Clock        */
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock (Internal RC 22.1184MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Wait for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Select HCLK clock source as HIRC and and HCLK clock divider as 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set core clock as HCLK_CLOCK */
    CLK_SetCoreClock(HCLK_CLOCK);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set GPD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD6MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD6MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Lock protected registers */
    SYS_LockReg();
/* MAIN function        */
int main(void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Select SysTick clock source as HXT */
    CLK_SetSysTickClockSrc(CLK_CLKSEL0_STCLKSEL_HXT);
    /* Configure PC.9 as Output mode */
    GPIO_SetMode(PC, BIT9, GPIO_MODE_OUTPUT);
    while(1)
        /* Configure PC.9 to low */
        PC9 = 0;
        /* Delay 200 ms */
        CLK_SysTickDelay(200000);
        /* Configure PC.9 to high */
        PC9 = 1;
        /* Delay 200 ms */
开发板出厂自带的一个LED闪烁的例子,非常容易。
包含了基本的时钟配置
延时函数
以及IO的输出操作。
zhuomuniao110| | 2019-4-30 21:37 | 只看该作者
闪灯操作。
