[DemoCode下载]
M451跑FreeRTOS
617|2
yiyigirl2014|  楼主 | 2019-4-30 21:33 | 显示全部楼层 |阅读模式
#include <stdio.h>
/* Kernel includes. */
#include "FreeRTOS.h"
#include "task.h"
#include "timers.h"
#include "semphr.h"
/* Demo application includes. */
#include "partest.h"
#include "flash.h"
#include "flop.h"
#include "integer.h"
#include "PollQ.h"
#include "semtest.h"
#include "dynamic.h"
#include "BlockQ.h"
#include "blocktim.h"
#include "countsem.h"
#include "GenQTest.h"
#include "QueueSet.h"
#include "recmutex.h"
#include "death.h"
/* Hardware and starter kit includes. */
#include "M451Series.h"
#define PLL_CLOCK           72000000
/* Priorities for the demo application tasks. */
#define mainFLASH_TASK_PRIORITY             ( tskIDLE_PRIORITY + 1UL )
#define mainQUEUE_POLL_PRIORITY             ( tskIDLE_PRIORITY + 2UL )
#define mainSEM_TEST_PRIORITY               ( tskIDLE_PRIORITY + 1UL )
#define mainBLOCK_Q_PRIORITY                ( tskIDLE_PRIORITY + 2UL )
#define mainCREATOR_TASK_PRIORITY           ( tskIDLE_PRIORITY + 3UL )
#define mainFLOP_TASK_PRIORITY              ( tskIDLE_PRIORITY )
#define mainCHECK_TASK_PRIORITY             ( tskIDLE_PRIORITY + 3UL )
#define mainCHECK_TASK_STACK_SIZE           ( configMINIMAL_STACK_SIZE )
/* The time between cycles of the 'check' task. */
#define mainCHECK_DELAY                     ( ( portTickType ) 5000 / portTICK_RATE_MS )
/* The LED used by the check timer. */
#define mainCHECK_LED                       ( 3UL )
/* A block time of zero simply means "don't block". */
#define mainDONT_BLOCK                      ( 0UL )
/* The period after which the check timer will expire, in ms, provided no errors
have been reported by any of the standard demo tasks.  ms are converted to the
equivalent in ticks using the portTICK_RATE_MS constant. */
#define mainCHECK_TIMER_PERIOD_MS           ( 3000UL / portTICK_RATE_MS )
/* The period at which the check timer will expire, in ms, if an error has been
reported in one of the standard demo tasks.  ms are converted to the equivalent
#define mainERROR_CHECK_TIMER_PERIOD_MS     ( 200UL / portTICK_RATE_MS )
/* Set mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY to 1 to create a simple demo.
Set mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY to 0 to create a much more
comprehensive test application.  See the comments at the top of this file, and
the documentation page on the http://www.FreeRTOS.org web site for more
information. */
#define mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY     0
#define CHECK_TEST
* Set up the hardware ready to run this demo.
static void prvSetupHardware(void);
#ifdef CHECK_TEST
static void vCheckTask(void *pvParameters);
#endif
int main(void)
    /* Configure the hardware ready to run the test. */
    prvSetupHardware();
#ifdef CHECK_TEST
    xTaskCreate(vCheckTask, (signed portCHAR *) "Check", mainCHECK_TASK_STACK_SIZE, NULL, mainCHECK_TASK_PRIORITY, NULL);
#endif
    /* Start standard demo/test application flash tasks.  See the comments at
    the top of this file.  The LED flash tasks are always created.  The other
    tasks are only created if mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY is set to
    0 (at the top of this file).  See the comments at the top of this file for
    more information. */
    vStartLEDFlashTasks(mainFLASH_TASK_PRIORITY);
    vStartPolledQueueTasks(mainQUEUE_POLL_PRIORITY);
    /* The following function will only create more tasks and timers if
    mainCREATE_SIMPLE_LED_FLASHER_DEMO_ONLY is set to 0 (at the top of this
    file).  See the comments at the top of this file for more information. */
    //prvOptionallyCreateComprehensveTestApplication();
    printf("FreeRTOS is starting ...\n");
    /* Start the scheduler. */
    vTaskStartScheduler();
    /* If all is well, the scheduler will now be running, and the following line
    will never be reached.  If the following line does execute, then there was
    insufficient FreeRTOS heap memory available for the idle and/or timer tasks
    to be created.  See the memory management section on the FreeRTOS web site
    for more details. */
    for(;;);
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Enable HIRC clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for HIRC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable HXT clock (external XTAL 12MHz) */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Wait for HXT clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Configure PLL */
    CLK_EnablePLL(CLK_PLLCTL_PLLSRC_HXT, PLL_CLOCK);
    /* Switch HCLK clock source to PLL */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(1));
    /* Select UART module clock source as HXT and UART module clock divider as 1 */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    /* Enable peripheral clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(TMR0_MODULE);
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set PD multi-function pins for UART0 RXD and TXD */
    SYS->GPD_MFPL &= ~(SYS_GPD_MFPL_PD0MFP_Msk | SYS_GPD_MFPL_PD1MFP_Msk);
    SYS->GPD_MFPL |= (SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD);
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART to 115200-8n1 for print message */
    UART_Open(UART0, 115200);
void vApplicationMallocFailedHook(void)
    /* vApplicationMallocFailedHook() will only be called if
    configUSE_MALLOC_FAILED_HOOK is set to 1 in FreeRTOSConfig.h.  It is a hook
    function that will get called if a call to pvPortMalloc() fails.
    pvPortMalloc() is called internally by the kernel whenever a task, queue,
    timer or semaphore is created.  It is also called by various parts of the
    demo application.  If heap_1.c or heap_2.c are used, then the size of the
    heap available to pvPortMalloc() is defined by configTOTAL_HEAP_SIZE in
    FreeRTOSConfig.h, and the xPortGetFreeHeapSize() API function can be used
    to query the size of free heap space that remains (although it does not
    provide information on how the remaining heap might be fragmented). */
    taskDISABLE_INTERRUPTS();
    for(;;);
void vApplicationIdleHook(void)
    /* vApplicationIdleHook() will only be called if configUSE_IDLE_HOOK is set
    to 1 in FreeRTOSConfig.h.  It will be called on each iteration of the idle
    task.  It is essential that code added to this hook function never attempts
    to block in any way (for example, call xQueueReceive() with a block time
    specified, or call vTaskDelay()).  If the application makes use of the
    vTaskDelete() API function (as this demo application does) then it is also
    important that vApplicationIdleHook() is permitted to return to its calling
    function, because it is the responsibility of the idle task to clean up
    memory allocated by the kernel to any task that has since been deleted. */
void vApplicationStackOverflowHook(xTaskHandle pxTask, signed char *pcTaskName)
    (void) pcTaskName;
    (void) pxTask;
    /* Run time stack overflow checking is performed if
    configCHECK_FOR_STACK_OVERFLOW is defined to 1 or 2.  This hook
    function is called if a stack overflow is detected. */
    for(;;);
void vApplicationTickHook(void)
    /* This function will be called by each tick interrupt if
    configUSE_TICK_HOOK is set to 1 in FreeRTOSConfig.h.  User code can be
    added here, but the tick hook is called from an interrupt context, so
    code must not attempt to block, and only the interrupt safe FreeRTOS API
    functions can be used (those that end in FromISR()).  */
#if ( mainCREATE_SIMPLE_BLINKY_DEMO_ONLY == 0 )
        /* In this case the tick hook is used as part of the queue set test. */
        vQueueSetAccessQueueSetFromISR();
#endif /* mainCREATE_SIMPLE_BLINKY_DEMO_ONLY */
#ifdef CHECK_TEST
    portTickType xLastExecutionTime;
    xLastExecutionTime = xTaskGetTickCount();
    printf("M451 Check Task is running ...\n");
    printf("LED toggle at PA.13\n\n");
    for(;;)
        /* Perform this check every mainCHECK_DELAY milliseconds. */
        vTaskDelayUntil(&xLastExecutionTime, mainCHECK_DELAY);
        if(xArePollingQueuesStillRunning() != pdTRUE)
            printf("ERROR IN POLL Q\n");
#endif
yiyigirl2014|  楼主 | 2019-4-30 21:34 | 显示全部楼层
FreeRTOS.rar (20.68 KB)
zhuomuniao110| | 2019-4-30 21:37 | 显示全部楼层
可以,这个是不是可以很容易移植到其他的新唐系列?
