AXI Direct Memory Access
1403|8
IntroductionGetting started with direct memory access on Xilinx boards may be initially overwhelming. First of all Xilinx distinguishes AXI DMA and AXI VDMA in programmable fabric. AXI DMA refers to traditional FPGA direct memory access which roughly corresponds to transferring arbitrary streams of bytes from FPGA to a slice of DDR memory and vice versa. VDMA refers to video DMA which adds mechanisms to handle frame synchronization using ring buffer in DDR, on-the-fly video resolution changes, cropping and zooming. Video DMA is covered in next article. In addition to AXI DMA and AXI VDMA there is a DMA engine built into the ARM core which is also out of the scope of this article. Both AXI DMA and AXI VDMA have optional scatter-gather support which means that instead of writing memory addresses or framebuffer addresses to control registers the DMA controller grabs them from linked list in DDR memory. Scatter-gather features are out of scope of this article.
InternalsAXI DMA distinguishes two channels: MM2S (memory-mapped to stream) transports data from DDR memory to FPGA and S2MM (stream to memory-mapped) transports arbitrary data stream to DDR memory.
AXI DMA internals
Minimal working hardwareThe simplest way to instantiate AXI DMA on Zynq-7000 based boards is to take board vendor's base design, strip unnecessary components, add AXI Direct Memory Access IP-core and connect the output stream port to it's input stream port. This essentially implements memcpy functionality which can be triggered from ARM core but offloaded to programmable fabric.
C code running on ARM coresVHDL code running on programmable fabricUserspacetest applicationAXI4 DirectMemory AccessDDR memory/dev/mem
AXI Direct Memory Access stream output is looped back to stream input
To be more precise, following is the corresponding high level block design. High speed clock line is highlighted in yellow as it runs on higher frequency of 150MHz while the general purpose port runs at 100MHz. Clock domain errors can usually be tracked back to conflicting clock lines. This is further explained in the end of this article.
High level block design corresponding to abstract design presented earlier
In the AXI Direct Memory Access IP-core customization dialog read channel and write channel correspond respectively to MM2S and S2MM portions of the DMA block. Memory map data width of 32 bits means that 4 bytes will be transferred during one bus cycle. This means the tdata port of the stream interface will be 32 bits wide.
Both read/write channels are enabled and scatter-gather engine is disabled
AXI Direct Memory Access component's control register, status register and transfer address registers are accessible via the AXI Lite slave port which is memory mapped to address range of 0x40400000 - 0x4040FFFF. The whole memory range of 0x00000000-0x1FFFFFFF is accessible via both stream to memory-mapped and memory-mapped to stream channel. AXI DMA 1 documentation has the offsets of the registers accessible via AXI Lite port. In this case MM2S control register of 32-bits is accessible at 0x40400000, MM2S status register of 32-bits at 0x40400004 and so forth.
Important
Note that customizing the AXI Direct Memory Access IP-core parameters causes memory ranges to be reset under Address Editor!
Minimal working softwareWhen it comes to writing C code I see alarming tendency of defaulting to vendor provided components: stand-alone binary compilers, Linux distributions, board support packages, wrappers while avoiding learning what actually happens in the hardware/software.
As described in my earlier article physical memory can be accessed in Linux via /dev/mem block device. This makes it possible to access AXI Lite registers simply by reading/writing to a memory mapped range from /dev/mem. To use DMA component minimally four steps have to be taken:
  • Start the DMA channel (MM2S, S2MM or both) by writing 1 to control register
  • Write start/destination addresses to corresponding registers
  • To initiate the transfer(s) write transfer length(s) to corresponding register(s).
  • Monitor status register for IOC_Irq flag.
In this case we're copying 32 bytes from physical address of 0x0E000000 to physical addres of 0x0F000000. Note that kernel may allocate memory for other processes in that range and that is the primary reason to write a kernel module which would request_mem_region so no other processes would overlap with the memory range. Besides reserving memory ranges the kernel module provides a sanitized way of accessing the hardware from userspace applications via /dev/blah block devices.
zhangmangui|  楼主 | 2019-5-13 23:30 | 只看该作者
/** * Proof of concept offloaded memcopy using AXI Direct Memory Access v7.1 */
#include <stdio.h>#include <unistd.h>#include <fcntl.h>#include <termios.h>#include <sys/mman.h>
#define MM2S_CONTROL_REGISTER 0x00#define MM2S_STATUS_REGISTER 0x04#define MM2S_START_ADDRESS 0x18#define MM2S_LENGTH 0x28
#define S2MM_CONTROL_REGISTER 0x30#define S2MM_STATUS_REGISTER 0x34#define S2MM_DESTINATION_ADDRESS 0x48#define S2MM_LENGTH 0x58
unsigned int dma_set(unsigned int* dma_virtual_address, int offset, unsigned int value) {
    dma_virtual_address[offset>>2] = value;
unsigned int dma_get(unsigned int* dma_virtual_address, int offset) {
    return dma_virtual_address[offset>>2];
int dma_mm2s_sync(unsigned int* dma_virtual_address) {
    unsigned int mm2s_status =  dma_get(dma_virtual_address, MM2S_STATUS_REGISTER);
    while(!(mm2s_status & 1<<12) || !(mm2s_status & 1<<1) ){
        dma_s2mm_status(dma_virtual_address);
        dma_mm2s_status(dma_virtual_address);
int dma_s2mm_sync(unsigned int* dma_virtual_address) {
    unsigned int s2mm_status = dma_get(dma_virtual_address, S2MM_STATUS_REGISTER);
    while(!(s2mm_status & 1<<12) || !(s2mm_status & 1<<1)){
void dma_s2mm_status(unsigned int* dma_virtual_address) {
    unsigned int status = dma_get(dma_virtual_address, S2MM_STATUS_REGISTER);
    printf("Stream to memory-mapped status (0x%08x@0x%02x):", status, S2MM_STATUS_REGISTER);
    if (status & 0x00000001) printf(" halted"); else printf(" running");
    if (status & 0x00000002) printf(" idle");
    if (status & 0x00000008) printf(" SGIncld");
    if (status & 0x00000010) printf(" DMAIntErr");
    if (status & 0x00000020) printf(" DMASlvErr");
    if (status & 0x00000040) printf(" DMADecErr");
    if (status & 0x00000100) printf(" SGIntErr");
    if (status & 0x00000200) printf(" SGSlvErr");
    if (status & 0x00000400) printf(" SGDecErr");
    if (status & 0x00001000) printf(" IOC_Irq");
    if (status & 0x00002000) printf(" Dly_Irq");
    if (status & 0x00004000) printf(" Err_Irq");
    printf("\n");
void dma_mm2s_status(unsigned int* dma_virtual_address) {
    unsigned int status = dma_get(dma_virtual_address, MM2S_STATUS_REGISTER);
    printf("Memory-mapped to stream status (0x%08x@0x%02x):", status, MM2S_STATUS_REGISTER);
    printf("\n");
void memdump(void* virtual_address, int byte_count) {
    char *p = virtual_address;
    int offset;
    for (offset = 0; offset < byte_count; offset++) {
        printf("%02x", p[offset]);
        if (offset % 4 == 3) { printf(" "); }
    printf("\n");
int main() {
    int dh = open("/dev/mem", O_RDWR | O_SYNC); // Open /dev/mem which represents the whole physical memory    unsigned int* virtual_address = mmap(NULL, 65535, PROT_READ | PROT_WRITE, MAP_SHARED, dh, 0x40400000); // Memory map AXI Lite register block    unsigned int* virtual_source_address  = mmap(NULL, 65535, PROT_READ | PROT_WRITE, MAP_SHARED, dh, 0x0e000000); // Memory map source address    unsigned int* virtual_destination_address = mmap(NULL, 65535, PROT_READ | PROT_WRITE, MAP_SHARED, dh, 0x0f000000); // Memory map destination address
    virtual_source_address[0]= 0x11223344; // Write random stuff to source block    memset(virtual_destination_address, 0, 32); // Clear destination block
    printf("Source memory block:      "); memdump(virtual_source_address, 32);
    printf("Destination memory block: "); memdump(virtual_destination_address, 32);
    printf("Resetting DMA\n");
    dma_set(virtual_address, S2MM_CONTROL_REGISTER, 4);
    dma_set(virtual_address, MM2S_CONTROL_REGISTER, 4);
    dma_s2mm_status(virtual_address);
    dma_mm2s_status(virtual_address);
    printf("Halting DMA\n");
    dma_set(virtual_address, S2MM_CONTROL_REGISTER, 0);
    dma_set(virtual_address, MM2S_CONTROL_REGISTER, 0);
    printf("Writing destination address\n");
    dma_set(virtual_address, S2MM_DESTINATION_ADDRESS, 0x0f000000); // Write destination address    dma_s2mm_status(virtual_address);
    printf("Writing source address...\n");
    dma_set(virtual_address, MM2S_START_ADDRESS, 0x0e000000); // Write source address    dma_mm2s_status(virtual_address);
    printf("Starting S2MM channel with all interrupts masked...\n");
    dma_set(virtual_address, S2MM_CONTROL_REGISTER, 0xf001);
    printf("Starting MM2S channel with all interrupts masked...\n");
    dma_set(virtual_address, MM2S_CONTROL_REGISTER, 0xf001);
    printf("Writing S2MM transfer length...\n");
    dma_set(virtual_address, S2MM_LENGTH, 32);
    printf("Writing MM2S transfer length...\n");
    dma_set(virtual_address, MM2S_LENGTH, 32);
    printf("Waiting for MM2S synchronization...\n");
    dma_mm2s_sync(virtual_address);
    printf("Waiting for S2MM sychronization...\n");
    dma_s2mm_sync(virtual_address); // If this locks up make sure all memory ranges are assigned under Address Editor!
zhangmangui|  楼主 | 2019-5-13 23:31 | 只看该作者
Successful run should look something like this:
Source memory block:      44332211 7dcddfdf 5a7fefa4 36aa3c9b ca2eea6a 5bf64f81 ebf7ffbb b7f710d2
Destination memory block: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Resetting DMA
Stream to memory-mapped status (0x00000001@0x34): halted
Memory-mapped to stream status (0x00000001@0x04): halted
Halting DMA
Stream to memory-mapped status (0x00000000@0x34): running
Memory-mapped to stream status (0x00000000@0x04): running
Stream to memory-mapped status (0x00001002@0x34): running idle IOC_Irq
Memory-mapped to stream status (0x00001002@0x04): running idle IOC_Irq
Destination memory block: 44332211 7dcddfdf 5a7fefa4 36aa3c9b ca2eea6a 5bf64f81 ebf7ffbb b7f710d2
Note that IOC_Irq signifies that transfer completion interrupt was triggered.
Clocks
Processing system may generate up to 4 clocks
High-speed slave ports (S_AXI_HP0 .. S_AXI_HP1) and associated ports (M00_AXI, S00_AXI, S01_AXI, M_AXI_MM2S, M_AXI_S2MM) run at 150MHz dictated by FCLK_CLK1. Master in this case means that the bus transfers are initiated by the master which in this case is the AXI Direct Memory Access component. AXI Interconnect in this case is acting merely as a switch in an ethernet network multiplexing multiple AXI ports (S00_AXI, S01_AXI) to single M00_AXI.
General-purpose port (M_AXI_GP0) including all AXI Lite slaves (run at 100MHz. In this case Zynq7 Processing System is the transfer initiator. AXI Protocol Converter similarily to AXI Interconnect allows access to multiple AXI Lite slaves (S_AXI_LITE in this case) via single AXI Lite master port (M_AXI_GP0) on the Zynq7 Processing System.
zhangmangui|  楼主 | 2019-5-13 23:32 | 只看该作者
wangzw1230| | 2019-5-14 16:33 | 只看该作者
你好,你有FPGA H264编解码 IP 源码卖吗?
wangzw1230| | 2019-5-14 17:28 | 只看该作者
QQ 359608344
zhangmangui|  楼主 | 2019-5-14 22:12 | 只看该作者
已申请加了   身边有朋友专门干这个的
jacobi1110| | 2020-2-22 19:44 | 只看该作者
哦~~~明白了............
发新帖
个人签名:欢迎进入【TI DSP 论坛】 & 【DSP 技术】           TI忠诚粉丝!
934
