ST MCU Finder
安装免费手机应用,
寻找理想的ST MCU
[STM32F4] U盘IAP升级跳转APP异常
238|4
 楼主 | 2019-5-15 15:39 | 显示全部楼层 |阅读模式
最近使用STM32F429的USB_OTG_FS做了一个BOOTLOADER可通过USB(PA11,PA12)读取U盘中的文件或者UART二选一更新APP。UART升级一切正常,唯有USB升级有个小问题:升级过程都一切顺利,但是到了要跳转到APP时芯片先是背光驱动IO无输出或输出低电平(其它IO状态未知,怀疑和背光驱动IO相似)等了几秒后芯片复位,复位后也能正常进入APP。但就是复位之前那段时间要等好几秒不明白是什么原因。如果是HardFault异常中断,我的看门狗没有使能,芯片没理由复位啊?这个问题还无法仿真,因为一旦芯片复位仿真器就与芯片失去同步了。我通过将代码一段一段注释排除发现:如将"USBH_Process(&USB_OTG_Core, &USB_Host);"函数及所在的循环注释就不会发生复位问题跳转APP正常,求高人解惑。
U盘升级函数:
*        Function Name : Programing_From_Flie
*        Function Detail : Programing The Chip From a Flie
*        Paramater : None
*        Return Value : None
void Programing_From_Flie(void)
        static uint8_t page_buffer[4096];
        #if defined BK180H
        const char object_path[]="0:BK180H.bin";
        #elif defined BK300H
        const char object_path[]="0:BK300H.bin";
        #elif defined U180
        const char object_path[]="0:U180.bin";
        #endif
        PrintMessage("Udisk Connected!");
        SysTick_Init();
        do
        while (count_ms<8000 && (USB_Host.gState!=HOST_CLASS || USBH_MSC_BOTXferParam.MSCState!=0x05));
        SysTick->CTRL=0x00; //Stop Counter
        char string_buf[24]="Scanning for ";
        for (u8 i=13;i<24;i++)string_buf=object_path[i-11];
        PrintMessage(string_buf);
        result = f_mount(&fs,"0:",1);        /* Mount a logical drive */
        if (result != FR_OK)
                PrintMessage("Mounting Failed!");
                return;
        result = f_open(&file, object_path, FA_OPEN_EXISTING | FA_READ);
        if(result == FR_OK)
                if (file.fsize==0 || file.fsize>0x1F8000)
                        PrintMessage("File Size Error!");
                        goto close_file_exit;
                if (FLASH_If_GetWriteProtectionStatus() == 0)
                        /* Disable the write protection */
      if (FLASH_If_DisableWriteProtection()==1)
        PrintMessage("Write Protection disabled!");
                        else
                                PrintMessage("Error: Flash write unprotection failed!");
                PrintMessage("Chip Erassing");
                FLASH_If_Erase(APPLICATION_ADDRESS,file.fsize);
                PrintMessage("Chip Programming");
                uint32_t flashdestination = APPLICATION_ADDRESS;
                uint32_t packets_max = file.fsize/4096+(file.fsize%4096==0?0:1);
                for (uint32_t packets_readed=0;packets_readed<packets_max;packets_readed++)
                        result = f_read(&file, page_buffer, sizeof(page_buffer), &fnum);
                        if(result==FR_OK)
                                /* Write received data in Flash */
                                if (FLASH_If_Write(&flashdestination, (uint32_t *) page_buffer, (fnum+3)/4)  == 0)
                                        ShowProgressPercent((packets_readed+1)*100/packets_max);
                                else /* An error occurred while writing to Flash memory */
                                        /* End session */
                                        PrintMessage("An error occurred while writing to Flash memory");
                                        PrintMessage("End session");
                        else
                                PrintMessage("Error File Reading!");
                f_close(&file);
                PrintMessage("Going to the new APP within   Seconds...");
                SysTick_Init();
                for (uint8_t i=5;i!=0;i--)
                        count_ms = 0;
                        LCD_Show8x16sym(272-lcd_x*16,(lcd_y[lcd_x]-12)*8,i+'0',WHITE,BLACK);
                        while (count_ms<1000);
//跳转APP代码
                /* Test if user code is programmed starting from address "APPLICATION_ADDRESS" */
    if (((*(__IO uint32_t*)APPLICATION_ADDRESS) & 0x2FFE0000 ) == 0x20000000)
      __asm("CPSID  I");__asm("CPSID  F");
                        USBH_DeInit(&USB_OTG_Core,&USB_Host);
                        /* Jump to user application */
      JumpAddress = *(__IO uint32_t*) (APPLICATION_ADDRESS + 4);
      Jump_To_Application = (pFunction) JumpAddress;
      /* Initialize user application's Stack Pointer */
                        __set_PSP(*(__IO uint32_t*) APPLICATION_ADDRESS);
                        __set_CONTROL(0);
      __set_MSP(*(__IO uint32_t*) APPLICATION_ADDRESS);
      Jump_To_Application();
//APP跳转代码结束
        else
                PrintMessage("Error File Opening!");
        close_file_exit:
        f_close(&file);
 楼主 | 2019-5-15 15:46 | 显示全部楼层
另外说明下,APP中未用到USB功能并且我在跳转前也关闭了中断的,不知为何还是会发生异常。
 楼主 | 2019-5-16 10:46 | 显示全部楼层
欧耶问题解决了!办法就是在跳转APP前把USB的外设时钟关闭:RCC_AHB2PeriphClockCmd( RCC_AHB2Periph_OTG_FS, DISABLE) ;就不会有跳转异常的问题发生了。我怀疑原因可能是USB中断在BOOTLOADER中打开之后,跳至APP时并没有使用USB功能因此没有设置USB中断入口从而导致中断溢出,保险起见以后在跳转APP前应将所有使能的外设全部关闭。
| 2019-6-13 12:10 | 显示全部楼层
为什么u盘总是如此经久不衰呢
| 2019-6-13 12:40 | 显示全部楼层
感谢楼主分享经验
扫描二维码,随时随地手机跟帖
我要发帖 投诉建议 创建版块 申请版主
快速回复
您需要登录后才可以回帖
登录 | 注册
高级模式
论坛热帖
在线客服 快速回复 返回顶部 返回列表
