[STM32F4]
stm32f4 synchronized psram problem
1254|3
eittinfo|  楼主 | 2019-5-18 08:37 | 显示全部楼层 |阅读模式
hi guys
i work on my stm32f4discovery based on stm32f407vgt6.
i have a problem with fsmc and synchronized psram mode.
i do some test and result is here:
first i config fsmc as Sync Nor flash accourding this below config:
  FSMC_NORSRAM_TimingTypeDef Timing;
/** Perform the SRAM1 memory initialization sequence
hsram1.Instance = FSMC_NORSRAM_DEVICE;
hsram1.Extended = FSMC_NORSRAM_EXTENDED_DEVICE;
/* hsram1.Init */
hsram1.Init.NSBank = FSMC_NORSRAM_BANK1;
hsram1.Init.DataAddressMux = FSMC_DATA_ADDRESS_MUX_DISABLE;
hsram1.Init.MemoryType = FSMC_MEMORY_TYPE_NOR;
hsram1.Init.MemoryDataWidth = FSMC_NORSRAM_MEM_BUS_WIDTH_16;
hsram1.Init.BurstAccessMode = FSMC_BURST_ACCESS_MODE_ENABLE;
hsram1.Init.WaitSignalPolarity = FSMC_WAIT_SIGNAL_POLARITY_LOW;
hsram1.Init.WrapMode = FSMC_WRAP_MODE_DISABLE;
hsram1.Init.WaitSignalActive = FSMC_WAIT_TIMING_BEFORE_WS;
hsram1.Init.WriteOperation = FSMC_WRITE_OPERATION_ENABLE;
hsram1.Init.WaitSignal = FSMC_WAIT_SIGNAL_DISABLE;
hsram1.Init.ExtendedMode = FSMC_EXTENDED_MODE_DISABLE;
hsram1.Init.AsynchronousWait = FSMC_ASYNCHRONOUS_WAIT_DISABLE;
hsram1.Init.WriteBurst = FSMC_WRITE_BURST_ENABLE;
hsram1.Init.PageSize = FSMC_PAGE_SIZE_NONE;
/* Timing */
Timing.AddressSetupTime = 40;
Timing.AddressHoldTime = 15;
Timing.DataSetupTime = 255;
Timing.BusTurnAroundDuration = 15;
Timing.CLKDivision = 16;
Timing.DataLatency = 12;
Timing.AccessMode = FSMC_ACCESS_MODE_A;
/* ExtTiming */
if (HAL_SRAM_Init(&hsram1, &Timing, NULL) != HAL_OK)
_Error_Handler(__FILE__, __LINE__);
and to write data on fsmc bus use this code :
uint16_t w[] = {
0xffff, 0x0, 0xffff, 0,
0xffff, 0, 0xffff, 0xAAAA};
for (uint8_t uwIndex = 0; uwIndex < 8; uwIndex++)
*(uint16_t *) ((uint32_t)0x60000000 + uwIndex * 2)=w[uwIndex];
and i get this result :
as above image you can see not anythings on fsmc_clk pin,but i expect have fsmc clock on this pin!!!!
so i test new fsmc config as below :
/* hsram1.Init */
hsram1.Init.MemoryType = FSMC_MEMORY_TYPE_PSRAM;
/* Timing */
/* ExtTiming */
and accourding new config you can see this resulte :
i have clock in fsmc_clk pin without any data on other pins and fsmc data bus!!!!
whats problem in my code!????
thx for your advice
coshi| | 2019-5-23 11:26 | 显示全部楼层
楼主想问什么问题
zljiu| | 2019-5-23 11:24 | 显示全部楼层
这个 英文看不太好
eittinfo|  楼主 | 2019-5-18 08:41 | 显示全部楼层
i upload result images again
config mode 1 ,fsmc as nor flash config:
config test 2, fsmc as sync psram config:
thx
